  Onewayness and Cynosure Live Jam from Cynostudios
Casio HT-700 VCF Settings
Page 1 of 1 [3 Posts]
Dudidum
PostPosted: Tue Jan 28, 2014 2:47 pm    Post subject: Casio HT-700 VCF Settings
Subject description: Parameters 12 through 16 don't change anything
Hi there!
I saw in another topic that some of you possess a HT-700 and perhaps you can help me.
I started to explore this cute little synth a few days ago and wanted to play around with the settings. I'm rather new to the synth world so there is a possibility I overlooked something.
Everything works fine except that the VCF parameters 12 through 16 don't change anything regarding the sound. Since I don't have any experience I can't even tell how the alterations in these settings should affect the sound Sad
How should it sound if I turn the VCF cutoff frequency (parameter 10) to 20 and the VCF attack (parameter 12) to 15?
Would that mean, that the sound comes out full bright (no filter) and dampens over time (from the cutoff freq. value 31 to 20) ?
I'm sorry if that sounds like complete bullsh* but I really don't know what to expect Embarassed
All in all the problem is that the sound does not change whatever settings I use in parameters 12 through 16.
Best regards,
Dud
patrickvf1976
PostPosted: Sun Feb 16, 2014 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Parameters 12-16 affect the following settings:
12 Attack
13 Decay
14 Sustain
15 Release
16 EG level (how much the envelope affects the filter thus the sound)
Try setting 16 (EG) to maximum (31?), 15 (release) to minimum, 14 (Sustain) to minimum, 13 (Decay) somewhere between 20 and 25, and 12 (Attack) to minimum. Also make sure that the VCF Cutoff is set to minimum or somewhere between 1 and 10, and the VCA Sustain is set to maximum, or alternatively the VCA Decay is set to maximum, to give the VCF EG some time to play out. Press and hold a key and you should hear the EG affect the VCF Cutoff. If not then you might have a problem with the envelope generator circuit.
Dudidum
PostPosted: Mon Mar 03, 2014 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
12 Attack
13 Decay
14 Sustain
15 Release
Sorry for the late reply!
Thank you very much for your help!
It seems that everything is in order, because it sounds like you described and for the first time I could change the sound in a wider range.
But I must say that the settings sometimes behave rather exponentially^^.
I didn't have a clue what I was doing. Just messing around without any knowledge led me to thinking that something was wrong with the hardware.
I will now study the basics Wink.
For me, this thread is closed Smile
Regards,
Dud
