  Muied Lumens Frequencies
File-handling under Chuck
Page 1 of 1 [4 Posts]
vitorgr
PostPosted: Thu Feb 20, 2014 6:34 pm    Post subject:  File-handling under Chuck
Subject description: File-handling under Chuck, equivalent way for Java InputStream
Is there a Chuck equivalent way for Java InputStream and OutputStream? Or like c++ fopen()?
fretless
PostPosted: Thu Feb 20, 2014 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
There are file examples in the example folder of the ChucK installation ChucK\examples\io
vitorgr
PostPosted: Fri Feb 28, 2014 1:35 pm    Post subject: File-handling under Chuck
Dear fretless,
Thank you for your fast answer!
My code is running now. I am able to read integers (notes) from a ascii file.
However, when I chuck some time to now (to play the notes), I get the following error at some point during execution:
(JACK) the JACK server is shutting down this client...
... stream stopped and closed!
^C[chuck]: cleaning up...
terminate called after throwing an instance of 'RtError'
what(): RtApi:: a stream is not open!
Aborted (core dumped)
Any clues?
Thank you, for your attention!
vitorgr
GrandJu
PostPosted: Wed Mar 05, 2014 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi vitorgr,
I suppose you are using Jack1.
Try Jack2, I don't know why but it works better with ChucK.
Since I use it I had no disconnect from Jack server anymore.
Have fun
Ju
