Testing: U5 (78L10) getting very hot
Page 1 of 1 [9 Posts]
neilbaldwin
PostPosted: Sat Mar 08, 2014 6:16 am    Post subject: Testing: U5 (78L10) getting very hot Reply with quote  Mark this post and the followings unread
Just finished building the euro version (with the daughter board) and have been testing/calibrating.
All good so far but I've just flipped over the module to start the trimmer adjustment/calibration and noticed that U5 is very hot. I guess it's the nature of it's job but is it normal to get so warm?
Thanks,
Neil
http://marmotaudio.co.uk
http://nes-audio.com
neilbaldwin
PostPosted: Sat Mar 08, 2014 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually, just checked the voltage, +12V in but 0V out so I guess it's fried?
PostPosted: Sat Mar 08, 2014 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
It could also be a short to ground on the 5V rail. Power off and check continuity. Possibly without the 7805 in place, in case IT is the short.
neilbaldwin
PostPosted: Sat Mar 08, 2014 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply.
Doesn't seem to be a short. I've checked the gate output and that's coming out at 10V and there's no continuity between the GND and output of any of the output sockets.
Or am I barking up the wrong tree there?
Audio files: 218
G2 patch files: 319
PostPosted: Sat Mar 08, 2014 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Could be its not a hard short .. when the regulator gets hot it will shut down too.
PostPosted: Sat Mar 08, 2014 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Jan's got a good point but I meant literally measure between the 5V rail and ground to see if it registers a short.
neilbaldwin
PostPosted: Sat Mar 08, 2014 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Hang on, there are no 7805s on the build are there?
Confused
Edit: well, there appears to be continuity between the input pin of the 78L10 and the Vcc pin of the CD4066s. That's not right is it? I thought the Vcc to the 4066 should come from the output of the 78L10?
PostPosted: Sat Mar 08, 2014 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Confused
Sorry: brain saw U5 next to 78L10 and decided to read it as 7805. :/
What I meant still stands though: is there no, or very low resistance between the output of the regulator and ground?
neilbaldwin
PostPosted: Sun Mar 09, 2014 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Got it!
Oh man, there was a microscopic bridge between the output and ground pads of U5 but on the component side of the board so I had to remove it to find it!
Thanks all for the input and help.
Onwards with the calibration! Very Happy
