<on air> Various Artists March Equinox 2017 streaming concert
Schematics for the AniModule XXX_OR - Triple Analog XOR
Page 1 of 1 [5 Posts]
JRock
PostPosted: Thu Feb 20, 2014 6:31 pm    Post subject: Schematics for the AniModule XXX_OR - Triple Analog XOR Reply with quote  Mark this post and the followings unread
I put these up on my website
Here's the PDF with the Schematics
XXX_OR_sch
You could use this basic circuit without the opamps.
They just make it play a little nicer with your system and give you a simple comparator for the Logic Out.
JingleJoe
PostPosted: Fri Feb 21, 2014 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you sure your transistors are the right way round? Smile
JRock
PostPosted: Fri Feb 21, 2014 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
Laughing
Yes, why?
JingleJoe
PostPosted: Tue Mar 11, 2014 12:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
because I've built the same circuit in the past and put my transistors the other way round (collector and emmitter swapped) I have no idea which way is "right" though, I'd need to think about it more
JRock
PostPosted: Tue Mar 11, 2014 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
It seems to work either way round.
I had it set up on the scope and checked one way, then the other.
It looked the same at first glance.
I'd need to set both up at the same time to check it comprehensively...
But this circuit does what it needs to do.
There's a ton of videos posted and the majority of them have scope views in them. Just look up xxx_or thumb up
