  PHOBoS presents: Deep Journey 3 {Going Deeperer}
voltage regulator precision
Page 1 of 1 [10 Posts]
aletropot
PostPosted: Tue Mar 18, 2014 6:32 am    Post subject: voltage regulator precision Reply with quote  Mark this post and the followings unread
Hi all?
How precise needs to be a synth psu?
A 15V bipolar with 14.75V and -15.05V its acceptable?
If not, what kind of problems this can make?
cheers
Audio files: 218
G2 patch files: 319
PostPosted: Tue Mar 18, 2014 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, those voltages will be fine.
aletropot
PostPosted: Tue Mar 18, 2014 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
Even if the diference its bigger, like 13v and -15v?
Audio files: 218
G2 patch files: 319
PostPosted: Tue Mar 18, 2014 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
13 Volt would be a bit low, and could be due too overloading the supply a bit or indicate a wiring problem ... I'd look into that ...
When a 15 Volt regulator really outputs 13 Volt (measured on the device itself) I would replace it.
When however the voltage at the regulator is about 15 Volt but the voltage on the synth parts is only 13 Volt I'd have a look at thee wiring and the current consumption.
xpmtl
PostPosted: Tue Mar 18, 2014 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also, and Blue Hell correct me if i'm wrong, you need to measure your voltages under load cause it can make quite a difference in the readings.
http://sdiy.xpmtl.net
Audio files: 218
G2 patch files: 319
PostPosted: Tue Mar 18, 2014 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, measure under load.
Audio files: 573
PostPosted: Tue Mar 18, 2014 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
The voltage levels themselves aren't that important as long as they are stable and of course within a certain range (feeding something with +/- 9V
which requires +/- 15V is not really a recipe for success). Sometimes there are reference voltages derived from the powerrails (not really a good method
btw) but a good circuit should have an option to adjust it if it's a level that needs to be very accurate (V/Oct VCO's come to mind). So as long as your
supply gives out a stable voltage you should be good to go.
aletropot
PostPosted: Tue Mar 18, 2014 4:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was getting the first values, I was just wondering what kind of fails a lower voltage gives.
For sure the p-p waveform voltage its lower, right?
Audio files: 573
PostPosted: Tue Mar 18, 2014 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
That depends very much on the circuit itself. For a circuit with digital chips for example the output is very close to the supply voltage so if that's lower the
output will be too. However circuits that process a signal often have an output voltage independent of the supply voltage but related to the input
voltage. Of course the supply voltage has to be high enough else the signal would clip and then it does effect the output level.
new voodoo
PostPosted: Thu Mar 20, 2014 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
this should be in the data sheet. Ive forgotten the terminology, but generally i think its less than certain voltage of the regulator's last two digits.
You'll be able to tell..it'll put out a straight line on the scope and you can lower the voltage a bit, etc then suddenly it'll go all wonky. Thats where it fails. (this all refers to a fixed reg of course)
www.newvoodoodesign.com
-my creations, bends & bendable pieces
-vintage parts & tubes, IC's & audio chips
-oddities & weird
newvoodoo.blogspot.com
-bending DIY/projects
-crap
