  Muied Lumens Frequencies
multi-channel panning
Page 1 of 1 [17 Posts]
blinky_Palermo
PostPosted: Tue Mar 25, 2014 9:19 pm    Post subject: multi-channel panning Reply with quote  Mark this post and the followings unread
hi all -
i was wondering about how to split a single control voltage over several VCAs - i know there are probably a couple of different methods for doing this, but i couldn't find anything about it in the forums. does anyone have any thoughts on this subject?
thanks!
-bp
bubzy
Audio files: 63
PostPosted: Wed Mar 26, 2014 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
just some buffers would do it, assuming that you dont want to do anything fancy with the signal
I made a pcb a while ago for a buffer "array"
http://electro-music.com/forum/topic-51273.html
_Richard_ Smile
PostPosted: Wed Mar 26, 2014 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
a multiple! (just split)
fonitronik at
bubzy
Audio files: 63
PostPosted: Wed Mar 26, 2014 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
ill make a pcb for splitting now
0-0-0-0-0-0-0-0-0-0-0
there Very Happy
_Richard_ Smile
blinky_Palermo
PostPosted: Wed Mar 26, 2014 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm sorry, maybe i wasn't clear.. i'd like to be panning between the different outputs over a single voltage excursion, not turning them all on at the same time..
Audio files: 213
G2 patch files: 319
PostPosted: Wed Mar 26, 2014 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
You mean like http://www.schneidersladen.de/en/toppobrillo-mixiplexer.html probably ... crossfading (de) multiplexer ... it is not very easy I think as an analog module.
Probably the easiest way would be to use an arduino like thing with a couple of analog outputs to control VCA's with and an analog input to control it from. EDIT: but would bee hard to run at audio rates ...
When done all discrete maybe with one of 'm LED bar driver ICs, but it would have to use PWM then to be able to interpolate between LED outputs, and still a lot of random logic too.
PostPosted: Wed Mar 26, 2014 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
a scanner, you mean?
fonitronik at
blinky_Palermo
PostPosted: Wed Mar 26, 2014 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, i've seen some of these scanner designs - but i'm not sure it needs to be that complex, i don't necessarily need to route four different sources to four different outputs. i'm not necessarily concerned with linear interpolation. audio rate would be nice, though. Wink
i feel like there must be some simpler ways to divide a single voltage..
PostPosted: Thu Mar 27, 2014 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
a LED bar driver as blue hell suggested would be a good solution. it comprises several comparators. it would be some inverting circuitry on the outputs needed to control the VCAs, though (you only need the VCAs to be on/off, i guess).
fonitronik at
Audio files: 213
G2 patch files: 319
PostPosted: Thu Mar 27, 2014 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
It is the fading bit causing the headache Rolling Eyes
PostPosted: Thu Mar 27, 2014 3:16 am    Post subject: Reply with quote  Mark this post and the followings unread
ARs between the comparators and the VCAs? would be far from 'equal power' fading, though.
fonitronik at
blinky_Palermo
PostPosted: Thu Mar 27, 2014 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the ideas, everyone!
an LED driver might be a good way to go.. definitely considered the comparator+a/r method also.. i know there are analog multiplexing/demultiplexing ICs out there, has anyone experimented with those?
Audio files: 31
PostPosted: Thu Mar 27, 2014 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
THis is a problem that I've wanted to solve for years -- namely, how to control an array of VCA's with a single CV (i.e., a surround sound system).
The problem is that one wants a VCA to respond to a voltage range. For example, say at <2v>4v the VCA is silent. At 3v the VCA is at max loudness. To effect the cross-fade, you would need to stagger the voltage ranges: 2v to 4v, 3v, to 5v, 4v to 6v... etc.
Consider a scenario with voltage detectors at 1/2 volt intervals (could be accomplished with something similar to the Aries threshold detector switch. Now, consider the possibilities if you sum the input CV with a 2v high-frequency sine wave. This means that for an input CV of 3v, it will sweep from 2v to 4v. The 3v comparator will have the largest duty-cycle and the duty-cycle will decrease farther away from 3v.
Thus, the 2v will have small duty cycle as will the 4v, 2.5 v and 3.5 v approaching 25%, and 3v nearly 50%. Each of these steps can be used to charge a capacitor (really, just a lag circuit) and then each voltage would be summed (check the simple and effective way that a pulse wave is converted to a discreet voltage in the Paia Theremax). It may be possible to sum the square waves and then run convert to a voltage. Will have to work with it.
I am going to check the schematics for the Aries threshold detector switch -- it accomplishes the same thing without the use of a s/h. I may be able to patch something up on my synth to check the theory (even though it will have a coarse resolution).
Audio files: 213
G2 patch files: 319
PostPosted: Thu Mar 27, 2014 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yup Kevin, that was the rough idea I had.
BTW the topobrillo module seems to do it with CMOS switches .. so I guess that adds some wave to the input as well to be able to make interpolation.
wackelpeter
Audio files: 10
PostPosted: Thu Mar 27, 2014 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
first thought about this:
a CV (sine,triangle or ramp from LFO or ADSR) fed into a multilpier (or CV mixer with several outputs) then those CV(s) fed into the input of several S&h Units... those clocked via the different outputs of an 4017 that is fed by another clock... so you get different values of that cv at the S&h Outs and can vary the s&h rate manually... the 4024 as divider could also be a good choice for clocking the s&h's...
all units simple to build and could be used in many different ways...
but it seems as i understood the requested/wanted solution wrong...
cheers bastian
prgdeltablues
Audio files: 12
PostPosted: Fri Mar 28, 2014 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
This may be completely on the wrong track, but I just happened to be mulling formant filters, and wondered if the CV shaper in Jim Patchell's vocal filter might be of any value in addressing this problem. See:
http://www.noniandjim.com/Jim/synthmodules/vocalfilter.pdf
It looks as if you could set breakpoints such that the output voltage rose linearly up to 3V (say) then fell linearly down to the next breakpoint. Or the output voltagr can be held constant over a range of input voltages. One of these for each VCA? Overlap the ranges, stagger the ranges...
Peter
widdly
PostPosted: Thu Apr 24, 2014 2:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure I'm following properly but this design is pretty cool...
http://www.musicsynthesizer.com/Corpse/VCEOM.html
The dither idea is genius. Mixing a fast sawtooth with the CV creates Pwm type switching in the LM3914. Since the "VCA's" are vactrols they smooth this out and create a linear crossfade.
