CD4031 tap looper...
Page 2 of 2 [33 Posts]
Goto page: Previous 1, 2
nathanxl
PostPosted: Sat Apr 05, 2014 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi. Ive been away all summer(winter for you in the north).
The workshop is now cool enough to work in.
Ive just bought a bunch of MC14557 chips and want to try out this circuit.
While Im waiting for them to arrive, could you smart fellows perhaps shed some light on whats going on.?..
Using all of the 64bits how many gate will this get me?
Am I correct that it will allow me 64 gates passing through it and then loop them?
Sorry if this is a silly question.
noto
PostPosted: Sat Apr 05, 2014 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
check out the mc14517 too. when i saw this concept for the first time, it blew my mind! i used it to build a four part programmable drum machine for a circuit bent yamaha PS-3. my schematic is probably unreadable to anyone but me, but if you'd like, i can redraw it..
http://2.bp.blogspot.com/-LqcYmi9hPuo/Uds4K7_vvlI/AAAAAAAAAxY/JlDh9VtwXmE/s1600/Picture+074.jpg
more info on the PS-3 build
http://www.noystoise.com/2013/07/yamaha-ps-3.html
billsship
PostPosted: Wed Jun 18, 2014 9:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there a way to clear the 4031's 'memory' quicker than holding down normally-on button for the duration of it's cycle?
I'm wondering if cutting off pin 16 (+V) momentarily would help it forget.
The reason being, if feeding slower clocks into this thing, 64 steps might take a while to cycle through.
Vine username: "billsship"
Modulargrid
noto
PostPosted: Wed Jun 18, 2014 10:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
for mine, I used a 'step-erase' switch to delete steps incrementally, and a 'quick-erase' switch that opened the loop while switching the input clock to another one that was set to a significantly higher frequency. one short press and the whole sequence is gone. if you just turn the power off, some of the bits will still be stored when you power back up. I found it necessary to build an 'initial-clear' circuit and a flip flop to keep the loop open upon power up, but then closed when a 'write' signal is sensed.
billsship
PostPosted: Wed Jun 18, 2014 10:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Clever!! So, I'm guessing you manually advanced the clock input with a pushbutton, and if you saw that the bit was high, you would press the clear button?
Your way of switching to a fast clock to quickly cycle through an clear the bits, I think that's a really great idea. However, I plan on using an external clock for this. Maybe I could have a simple 40106 on board for this duty alone.
Also - did you incorporate some type of reset into this? Or did you consider any step the 1st step if they were all cleared?
Modulargrid
roglok
PostPosted: Fri Jan 16, 2015 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
this is really interesting! is there a way to reset the loop sequence?
SUGARAT
PostPosted: Fri Jan 23, 2015 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
No reset or inhibit pin on the 4031. That's too bad because there is plenty of room for one. As stated above the quickest way to clear the loop is probably to switch the clock to a really fast one while keeping data low. Sort of like erasing a tape loop. You hit record and turn up the motor speed.
Also, with enough stages you should be able to loop audio not just control signals, no? you would just be limited to as many cycles as there are stages in the shift register. also frequencies above the clock frequency won't playback properly.
Audio files: 550
PostPosted: Sun Jul 24, 2016 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I finally got my hands on some CD4031s to built my own TAP looper. Very Happy But there was one thing I didn't really like about the original circuit;
the not so standard Normally Closed switch, and the fact that it is placed within the data line so it can't be controlled by other logic. But after
studying the datasheet I figured out a way to use a more standard Normally Open switch. And because it is connected between GND and a pin
of the CD4031 it can now be controlled by other logic. The discrete OR gate (diodes + resistor) add the WRITE signal to the output so you can
directly see/hear what you are doing.
I also designed a deluxe version which has a nicer output in the form of an actual logic gate and it also sends the ERASE signal through to the
output. The spare NOR is used to drive an LED.
And I designed a stripboard layout for the deluxe version for those who like to use that.
 Filesize:  30.56 KB
 Viewed:  157 Time(s)
 Filesize:  40.6 KB
 Viewed:  168 Time(s)
 Filesize:  17.68 KB
 Viewed:  99 Time(s)
SoundCloud BandCamp AcidTrasH Stickney Synthyards
