 Forum index » Instruments and Equipment » Eventide
Eventide links
Post new topic   Reply to topic Moderators: Dougster
Page 1 of 1 [5 Posts]
Dougster
PostPosted: Sat Aug 20, 2011 4:33 pm    Post subject:  Eventide links Reply with quote  Mark this post and the followings unread
Eventide makes some of the best effects units on the market. Here are some links:
Eventide Audio Division
You'll have to register your product with them before you can download OS updates.
The official Eventide forum used to be a Yahoo Group. It still has good information in the files section:
http://tech.groups.yahoo.com/group/eventidehelps/
For editing patches on the 4000, 7000 and 8000 series Harmonizers, you can use VSIG on Windows or vSigX on Mac.
VSIG patch editor for Windows
vSigX patch editor for OS X (NOTE: Not supported by Eventide)
Communications with Eventide products involve a lot of sysex strings, so a standard MIDI connection is frustratingly slow. It is better to use the serial port. (NOTE: the RJ45 connector on the back of the bigger Harmonizers is *NOT* an ethernet connection.) I use the Keyspan (Tripp-Lite) USA-19HS USB to serial adapter.
Once you start down the modular path, forever will it dominate your destiny!
Blue LEDs are evil.
PostPosted: Sun Aug 21, 2011 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Those recent Eventide pedals that came out are things of wonder! Especially that Pitch Shifter/delay. It made me wet! Embarassed Very Happy
It's on my must get next list!
ACHTUNG!
Audio files: 346
PostPosted: Sun Apr 13, 2014 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
A little known fact (at least for me) is that some of the Harmonizer racks are actually full-blown modulars, with the ability to patch your own algoritms from scratch if you want. You can do this from the front panel or use Vsig mentioned above to create custom patches. OK so it's not a modular in the sense that the Nords are, the focus is obviously more on effects than synthesis but still - there is a damn fine selection of tools available.
Here is a pdf showing what modules you can expect to find in the 2 unit racks, from the DSP 4000 series up (not including the Eclipse):
http://cic.setileague.org/pdfs/modules_1_3.pdf
Muied Lumens Base Star
Audio files: 216
G2 patch files: 319
PostPosted: Sun Apr 13, 2014 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for that PDF link!
Audio files: 346
PostPosted: Sun Apr 13, 2014 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
NP Jan, I had a feeling you'd be interested! Wink
