Joined: Jan 07, 2009 Posts: 1196 Location: Scottish Borders
Audio files: 155
Posted: Mon Apr 07, 2014 10:34 am Post subject:
CGS89 Gate Sequencer's & some division Subject description: For the Blue tower |
Hi there
Recently I've been patching Gates from 4 of my diy sequencers through a sequential switch for some changing patterns for 1 bass line , I really like the changing patterns but I'd also like to free up 3 sequencers .
While browsing the net for diy solutions , a popular search return was the CGS89 Gate sequencer with a couple of add on switch banks/ buffers (like Thomas White's 4 channel CGS89).
spent the last few weekends trying ideas for my panel, I think I'm close now , Ordered some boards from Ken and I need to knock together a couple of veroboard divider circuits , one is on the test layout panel already , the space at the lower right is for a rotary selectable/ single out divider.
I'm going for a 4 channel for sequencer 1 and a 2 channel for sequencer 2 , I'm limited by a panel of 250mm high by 200mm wide for this module , I would have made Seq2 a 4 channel too but I will be tight for space , also there are no individual step outs , I had a long hard think about them and decided I'd be using probably just 1 out per cycle , so I went for a rotary to select the desired step & 1 out socket (to trigger my burst generator ) .
Here is the blue test panel layout so far ....
Description: |
Filesize: |
408.9 KB |
Viewed: |
803 Time(s) |
Audio files: 155
Posted: Sat Apr 12, 2014 10:27 am Post subject:
CGS boards arrived yesterday , , decided to stuff the sequencer boards with components this afternoon & make an order to Rapid electronics for some panel switches & sockets etc.
Hope to get panel finalised through the week and get drilling next week .
Description: |
Filesize: |
448.51 KB |
Viewed: |
702 Time(s) |
Description: |
Filesize: |
423.31 KB |
Viewed: |
749 Time(s) |
Description: |
Filesize: |
456.52 KB |
Viewed: |
712 Time(s) |
Audio files: 155
Audio files: 155
Posted: Sat Apr 19, 2014 7:48 am Post subject:
Extra buffers for gatemix / pulse rows C1 & D1 and a 4024 divider (Fonik) & 4017 divider (Yusynth) done & wired ready on vero-board .
Also got an off cut of 3mm aluminium 250mm X 200mm from Engineers/ metal workshop in town, needs a clean with solvent then ready for the drill template mid week after work.
Description: |
Filesize: |
483.08 KB |
Viewed: |
729 Time(s) |
Description: |
Filesize: |
203.96 KB |
Viewed: |
702 Time(s) |
Audio files: 155
Posted: Wed Apr 23, 2014 2:33 pm Post subject:
Got the stickers done , 2 sets one drill template & one clean finish .
Raced to the shed after work and centre punched the panel(s) , started with the 4mm drill and piloted all crosshairs , then went over the switches / sockets with 6.5mm bit , then 8mm bit for led bezels , and finally 11mm for the 1/4" sockets , I give the face of the template sticker a good spray with cutting oil, messy , but the drills glide through the 3mm alum plate , there are burrs on the exit side but easy to take off , I use a very sharp old wood chisel to plane them off , then the back side of the panel gets a quick rub with wet n dry sandpaper , finally a spray all over with automotive carburettor cleaning spray , great for getting fine grit & swarf off the front surface , don't light a cigarette after spraying , a final wash with soapy warm water and the plate is good for the final finish sticker application .
More at the weekend .
Description: |
Filesize: |
287.89 KB |
Viewed: |
668 Time(s) |
Description: |
Filesize: |
228.08 KB |
Viewed: |
696 Time(s) |
Audio files: 155
Audio files: 155
The Bad Producer
Joined: Mar 08, 2009 Posts: 282 Location: The Manhole
Audio files: 155
Posted: Tue Apr 29, 2014 12:35 pm Post subject:
The Bad Producer wrote: | Great project and love the write up! |
thanks , it's going smoothly so far, hope to have the wiring done by the weekend...... then de-bug if needed
Dave |
Audio files: 155
Posted: Tue Apr 29, 2014 12:46 pm Post subject:
Wires..............
The tedious but necessary part of overtly switchy & sockety projects . a few pics of the wiring stage.
Description: |
Filesize: |
365.1 KB |
Viewed: |
550 Time(s) |
Description: |
Filesize: |
324.01 KB |
Viewed: |
517 Time(s) |
Audio files: 705
wackelpeter
Audio files: 10
Posted: Wed Apr 30, 2014 1:01 pm Post subject:
second that what Phobos said, looks really impressive and also like a lot of work... guess i would spend a year to build such a thing
but one question: this is only giving variable gate or trigger pulses no CV's right?
i'd also like to see/hear what you're able to do with this nice pattern generator/sequencer when ready... |
Audio files: 155
Posted: Thu May 01, 2014 12:35 pm Post subject:
PHOBoS wrote: | looks good Dave! |
Thanks Phobos |
Audio files: 155
Posted: Thu May 01, 2014 12:55 pm Post subject:
wackelpeter wrote: | second that what Phobos said, looks really impressive and also like a lot of work... guess i would spend a year to build such a thing
Hi ,thanks , yes that's right , just gates & pulses.
This unit will mainly be used with a sequential switch and 1 or 2 separate diy sequencers in my system .
Dave. |
Audio files: 155
Posted: Thu May 01, 2014 1:11 pm Post subject:
Yessss.
On the home stretch now , tested & powered up the CGS boards last night , both working a treat , yay ,Quick test set up as 2 X 8 step sequencers, after testing both, I tried patching end out to reset in on each sequencer (1 to 2 / 2 to 1) + setting both the switches to hold and it works great as a 16 step with the outs "or" switched to A1 & B1, fab .
Now to connect up & test / debug my veroboard then cable tidy with some ties and give final checks / tests .
pics & some sounds of it working the modular in next post over the weekend.
Dave. |
wackelpeter
Audio files: 10
Posted: Thu May 01, 2014 1:19 pm Post subject:
if someone had read the description and the title carefully this question would be obvious... my fault sorry... but neverless thank's for your reply even to such stupid questions... |
Audio files: 155
Posted: Thu May 01, 2014 2:28 pm Post subject:
no such thing as a stupid question |
Audio files: 155
Audio files: 155
Posted: Sat May 03, 2014 10:08 am Post subject:
Quick pic of the finished front panel of the dual CGS89 sequencer (Ken Stone)
Middle divider (Fonik) and the lower right single divider (Yusynth).
Before installation into the modular, a pic of it relaxing on the couch
Description: |
Filesize: |
529.65 KB |
Viewed: |
450 Time(s) |
Description: |
Filesize: |
279.79 KB |
Viewed: |
484 Time(s) |
Audio files: 155
Audio files: 155
Audio files: 278
Posted: Sun May 04, 2014 8:19 am Post subject:
Nice track! and that wall of synth is getting very impressive
edit: some nice patterns on the gate sequencer test mp3s. _________________ Jan
Audio files: 155
Posted: Sun May 04, 2014 8:22 am Post subject:
Thanks Jan , , glad you enjoyed the track
Dave. |
Joined: Dec 11, 2010 Posts: 966 Location: Toronto, Ontario - Canada
Posted: Sun May 04, 2014 8:32 am Post subject:
Awesome track! Just what we needed for the new playlist |
Audio files: 155
Posted: Sun May 04, 2014 8:33 am Post subject:
Thanks Jake
Dave. |
