Pelican Case Lunetta
Page 1 of 1 [10 Posts]
stubbyfex
PostPosted: Mon Mar 24, 2014 4:14 pm    Post subject: Pelican Case Lunetta Reply with quote  Mark this post and the followings unread
Just finished my first Lunetta. It uses three chips: a 40106, a 4093 and a 4051.
I used a Pelican 1200 box. The faceplate is 1/8" aluminum with a clear label that I printed on an ink-jet printer. I then sprayed the label with clear to keep the printing from washing off. Great sounds! The diode on the power socket is a P6KE15A that clamps the input voltage at 15v. I usually power it from my home-built modular synth's Power One switching supply. It also works great with a 9V Voodoo Lab Pedal Power Iso 5 too. All inputs and outputs of the chips have 560 ohm resistors on them. The inputs all have pull-down resistors, and the outputs have super bright red LED's. [/img]
 Filesize:  89.75 KB
 Viewed:  107 Time(s)
 Filesize:  62.83 KB
 Viewed:  108 Time(s)
 Filesize:  76.53 KB
 Viewed:  83 Time(s)
 Filesize:  1.05 MB
 Viewed:  168 Time(s)
analog_backlash
Audio files: 21
PostPosted: Mon Mar 24, 2014 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi stubbyfex.
Looks really good to me Very Happy . I was looking at the schematics and I was a bit surprised by the 9K53 resistors in it. Did you have a good reason to use these or did you just have a plentiful supply of them?
Gary
trav
PostPosted: Tue Mar 25, 2014 2:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks great. Sounds, please!
PostPosted: Tue Mar 25, 2014 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Good work. Nice & neat wiring job inside!
James.
roglok
PostPosted: Tue Mar 25, 2014 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
sounds, or it didn't happen!
stubbyfex
PostPosted: Tue Mar 25, 2014 10:47 pm    Post subject: Re: resistor values Reply with quote  Mark this post and the followings unread
Yes, I had a box of them and thought they were close enough to 10k. Same with the 560 ohm. I'll get some sounds up soon too.
stubbyfex
PostPosted: Wed Mar 26, 2014 3:30 pm    Post subject: demo video Reply with quote  Mark this post and the followings unread
Here is a demo showing the oscillators, then the Nand gates and finally the one of 8 data selector.
Lunetta1.m4v
Demo video
 Filename:  Lunetta1.m4v
 Filesize:  36.25 MB
 Downloaded:  166 Time(s)
roglok
PostPosted: Fri Mar 28, 2014 4:45 am    Post subject: Reply with quote  Mark this post and the followings unread
nice!
DUBmatze
PostPosted: Sat Mar 29, 2014 1:53 am    Post subject: Reply with quote  Mark this post and the followings unread
verry nice build!
Tycho Brahe
PostPosted: Tue Apr 29, 2014 2:06 pm    Post subject: Re: Pelican Case Lunetta Reply with quote  Mark this post and the followings unread
Nice build! Can you close the case with the patched cables in it?
stubbyfex wrote:
All inputs and outputs of the chips have 560 ohm resistors on them. [/img]
I understand the need of pulldown/-up resistors, but why a serial resistor?
