 Forum index » DIY Hardware and Software » Musical Interfaces
Very simple ableton controller
Page 1 of 1 [5 Posts]
dimebucker
PostPosted: Mon May 05, 2014 6:25 am    Post subject: Very simple ableton controller
Subject description: a computer keyboard mod!
Hi all,
In my band we use ableton live to trigger midi and other samples. We use the scenes view to move through our songs.
All you need to do is to press enter to move to the next part of the song. Im trying to build some 'enter key' foot pedals so we can easily move through the songs (our hands are tied up using guitars and keys).
So far i've removed the PCB from a computer keyboard and traced the location of the enter function, if you complete the circuit from these two points and enter 'happens'.
My idea now is to have multiple pedals from one PCB.
So you could have a box with the PCB that is connected to a few stereo outputs - then all you need to do is plug something with a momentary switch in and you have an enter controller.
Here's where ive got a few concerns: presumably the keyboard circuit works with tiny amounts of power, if i add two or three pedals thats a lot of extra cable... am i going to need to amplify the signal?
If so, any suggestions on how i should go about this?
As you can probably tell im quite new to electronics, so any help would be much appriciated, cheers! Smile
DUBmatze
PostPosted: Wed May 07, 2014 10:04 am    Post subject: Re: Very simple ableton controller
i dont think so .... you just use a switch and nothing more .... the cabels dont consume that mutch - just give it a try.
In your circuit u use tip and ring for the connectors. i sugest to use tip and sleeve. (the most cheap footswitches i have seen use that)
If you want it with more style like a Banakeyboard or trigger while u drink your beer or somthing - have a look at this Project:
http://makeymakey.com/
Audio files: 574
PostPosted: Wed May 07, 2014 10:15 am    Post subject: Re: Very simple ableton controller
The only problem I can think of is that it might be sensitive to noise (or maybe even produce HF noise with long cables).
But yeah you'd just have to give it a try to see if it works. Cool
SoundCloud BandCamp Stickney Synthyards Captain Collider
dimebucker
PostPosted: Wed May 07, 2014 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool thanks!
tip and ring seems more sensible, those makey makey things are really interesting Smile
Ok, i will give this a go and report back, cheers!
dimebucker
PostPosted: Thu Jul 24, 2014 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey guys, finally got round to making this and it works great, thanks!
Except for one issue: sometimes pops and crackles can be heard within Ableton and occasionally it will freeze and crash completely!
This only happens when the device is plugged in to my laptop.
Any idea as to what is going on? electrical interference? Confused
