Can I hook up a guitar effects pedal to my keyboard?
Page 1 of 1 [7 Posts]
Dagrith
PostPosted: Sun May 04, 2014 4:33 pm    Post subject: Can I hook up a guitar effects pedal to my keyboard? Reply with quote  Mark this post and the followings unread
Hey, I have a keyboard (OPTIMUS MD-1600) hooked up to my mixer with one of the 3 pronged mic cords (the end in the piano is a 1/4 inch jack). If I get a Boss GT-6 will I be able to hook it up so that it effects the keyboards sound?
Audio files: 218
G2 patch files: 319
PostPosted: Sun May 04, 2014 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome
Sure the effect would affect the sound .. the effect being a guitar type thingie prolly means you would have to set the ingoing volume low to avoid distortion.
Dagrith
PostPosted: Sun May 04, 2014 9:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks
Thank you for the helpful reply
PostPosted: Sun May 04, 2014 9:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
levels are a big deal, depending on the pedal synth levels of 10Vpp could fry something expecting much much less. There is a common solution:
http://www.cgs.synth.net/modules/cgs60_sba.html
It's easy to build on stripboard if you don't want to order from far far away. Smile
Dagrith
PostPosted: Sun May 04, 2014 9:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
the keyboard has a 1/4 inch jack labeled "effects pedal". Would that help with the pedal I am looking into using?
PostPosted: Sun May 04, 2014 10:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I re-read your original post.
If you're going into a mixer, you are likely better off using the mixer's (presumed) send/return effects loop.
I was thinking in terms of having a synth going 1/4" out to pedal to mixer. Even then, the circuit I've linked to is necessary in the modular world where signals are usually 10Vpp more than it would be with a standalone keyboard like the MD-1600 which is likely only outputting line level signals (a couple volts peak to peak max).
Sorry to confuse things :/
Zodiak
PostPosted: Thu May 08, 2014 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not necessarily, it could just be a way of using an external device to control an effect actually on the keyboard. What make and model is it?
Stephen
www.Rainsbury.Net
