  Live electro-music improvisation by Twyndyllyngs Chez Mosc
export.ck not found
Page 1 of 1 [7 Posts]
opabecker
PostPosted: Fri May 02, 2014 8:32 am    Post subject: export.ck not found
Subject description: Unable to export wav file in miniAudicle 1.3.2
I just updated to the latest version of ChucK (1.3.4.0) and miniAudicle (1.3.2) for MacOSX. Now, when I try to export to a WAV file, I get the error message "[export.ck]: no such file or directory". I had never gotten this message before - can anyone point me toward a solution?
Anthony
jkant
PostPosted: Tue May 13, 2014 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Sometimes happens to me too...
Spork this (along with what you want to export):
Code:
dac => WvOut2 w => blackhole;
"chuck-session" => w.autoPrefix;
"special:auto" => w.wavFilename;
<<<"writing to file: ", w.filename()>>>;
.5 => w.fileGain;
null @=> w;
while( true ) 1::second => now;
Best
Random Bitz
opabecker
PostPosted: Tue May 13, 2014 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi jkant,
Thanks for taking the time to respond.
Should I be saving that code snippet as export.ck somewhere (and if so, where)? I've tried saving it in the directory with my other files and sporking it from one of them - I've also tried just adding it to my main driver.ck file instead of sporking it directly - I've also tried manually sporking it before starting the export - but none of those helped.
Anthony
jkant
PostPosted: Tue May 13, 2014 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
No you have to spork it before the thing you want to record. That shred will record in realtime your stuff in a stereo wav file.
Best
Random Bitz
opabecker
PostPosted: Tue May 13, 2014 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I appreciate your willingness to help, but perhaps there is a misunderstanding here. To restate my problem:
Under the previous version of miniAudicle/ChucK, I *had* a working shred that I would spork to record my audio in realtime (this shred was very much like the one you suggested to me). This shred was sporked from a driver file (using a call to Machine.add()). At least, this shred had worked *some* of the time: occasionally, it would just produce an empty .wav file, in which case I'd have to shut miniAudicle down and restart it, and then it would create a proper .wav file. As an alternative, I could export from my driver file, which would also create a proper .wav file.
Since upgrading to the latest version of miniAudicle and ChucK, my once-working shred for recording does not work at all anymore (it *always* creates an empty .wav file), and when I try to export, I get the error message, so that does not work anymore either.
In short, the problem is NOT related to my not having a shred to initiate the sound recording; the problem is more related to what changed between ChucK 1.3.3.0 and ChucK 1.3.4.0, and what adjustments I need to make to my programs because of that (or what changes need to be made to ChucK 1.3.5.0 to fix it Wink.
Anthony
opabecker
PostPosted: Thu May 29, 2014 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
bump?
opabecker
PostPosted: Fri May 30, 2014 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi everyone,
Well, panic mode is averted for now.
It turns out that my recording shred is not producing an empty wav file as I'd thought; instead, it produces a file that Audacity cannot import as a wav file. So, I tried importing it as a raw 16 bit pcm file, and I see now that the file contains the sound that ChucK had produced, and I can play it back. Whew!
Perhaps there is some header information that ChucK should be putting into the file when it records a wav file (and maybe something I need to do to my recording shred to make that happen?). Here is my recording shred, which is sporked from another thread and controlled from that thread:
Code:
// aufnahme.ck
// This script will record the output of the calling program.
// access globals
Globals glob;
// get name of output file
"mech_"+glob.seedValue => string outputFile;
// pull samples from the dac
dac => Mix2 g => WvOut2 w => blackhole;
me.dir()+"/"+outputFile+".wav" => w.wavFilename;
// start recording
1 => w.record => glob.recFlag;
// keep recording until told to stop
while (glob.recFlag)
    1000::ms => now;
// stop recording
0 => w.record;
w.closeFile();
I still have the "export.ck not found" error, and would really like to fix that. However, it looks like I can stop thinking about reverting back to the previous version of ChucK/miniAudicle to record.
