Simple VCA Amplitude?????
Page 1 of 1 [6 Posts]
mrmrshoes
PostPosted: Sat May 31, 2014 7:19 am    Post subject: Simple VCA Amplitude????? Reply with quote  Mark this post and the followings unread
I've just built the Simple VCA and it seems to be working, I think, But I haven't done any serious configuring yet apart from trimming A2 to mute input signal when the gain control is in a CCW position. When this is configured the amplitude on the output of the VCA is about ¼ of the input amplitude. Is this normal? I haven't matched the transistor pair yet just used two from the same batch for basic tests.
I know you can change the gain of the VCA with R10 & R11. I'm thinking I’ve got a working board and just need to configure these. Has anyone experienced the same behaviour?
I've check all component values on the board as well as for other problems like Shorts/Opens/Cold Joints and everything looks good.
The VCA is set-up for AC operation.
Any input would ready help me out.
mrmrshoes
Benjamin AM
PostPosted: Thu Jun 05, 2014 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Curious what the control input voltage is.
mrmrshoes
PostPosted: Sun Jun 08, 2014 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I have figured out my problem man. I spent a couple of days checking over the board, replacing parts and looking for Shorts and opens. All the wiring looked good as-well, so I was pretty stumped.
When I was testing the VCA I had all the pots and nanner sockets attached to my panel. When I eventually remove the gain pot from the panel I realized that I had the wrong value pot (10K) instead of 100k. This explains the lack of amplitude when trimming A2 trim pot.
I feel pretty stupid. Well you can't win them all. Embarassed
Benjamin AM
PostPosted: Sun Jun 08, 2014 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
You shouldn't be to embarrassed, it happens to everyone.
gdavis
PostPosted: Sun Jun 08, 2014 8:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
If it makes you feel any better, I just realized my LFO wasn't working because I put the TL074's in backwards Embarassed
Audio files: 29
PostPosted: Mon Jun 09, 2014 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hah, when I was trying to dial in my Minimoog VCF, I couldn't work out why adjusting T1 did nothing to the voltage on Q1... until I noticed the resistor attached to it was 100K, not 1k8.
