MIDI-transport (play/record) assign ?
Page 1 of 1 [2 Posts]
FaschingsPrinz
G2 patch files: 4
PostPosted: Fri May 23, 2014 8:32 pm    Post subject: MIDI-transport (play/record) assign ? Reply with quote  Mark this post and the followings unread
Hello friends,
I use Reaper (daw) to record MIDI-data of some noodles I´ve done if I like what I hear.
At the moment I use the mouse to click record.
But is there a way to assign record, stop, rewind and play commands to the front panel of my g2 to be able to start recording and playback from the g2 ?
Thanx a lot in advance,
Marcus
"If I have an apple, and you have an apple, and we exchange apples, then you and I still have ONE apple.
But if I have an idea, and you have an idea, and we exchange ideas, then we BOTH have TWO ideas."
G.B.SHAW
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Jun 10, 2014 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
you need a midi translator or event processor box. MIDI solutions make something like that. That will map any midi message to any other midi message (ones that the G2 can't output). the only thing with such a box is that it's midi powered, and the G2 doesn't provide enough power. You have to buy a MIDI solutions Power box as well.
Yeah it's a little bit clunky, but it works.
Dasz
http://www.dasz.com
Electronic Music Instruments From Vancouver, Canada
(Cycling log - https://www.strava.com/athletes/5681257 )
