  Twyndyllyngs Live - postponed until tomorrow, sorry. (Dental pain) ;-( Chez Mosc
Binary Game Sequencer
Page 2 of 4 [91 Posts]
diablojoy
PostPosted: Tue Jan 28, 2014 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias been awhile since any news on this one
definitely interested in euro version pcb's main and panel control if you have any coming up.
ask where the hell am I
as good an answer as any
PostPosted: Tue Jan 28, 2014 11:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
i am working on it. the new layout gives me some headaches, though. it might be necessary to connect the circuit PCB and the controller PCB with ribbon cables...
Tech Budday at Random*Source
mcop
PostPosted: Wed Jan 29, 2014 12:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I've been wondering this too. Good to hear it's still going.
I've been playing with a homebrew 4024 divider connected to either the Barton VCA/Mixer or a matrix mixer and having loads of fun with the sequencing and chopping up possibilities so definitely up for this when it's ready.
diablojoy
PostPosted: Wed Jan 29, 2014 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes good to hear its still going
ribbon cables hmm not quite as nice as the usual headers but if things just wont line up right then so be it ,
had to do something similar with one of hexinverters postman EG's
last weekend (16HP euro panel) I etched a single layer panel board for it so no way could i line it all up for headers , so lots of cabling all running through 3 x 10mm holes in the panel board , couldnt go round the outside too close to the panel size. It didnt save me any cabling but it did suit the 9mm pots i had on hand and made board mounting a whole lot easier.
Audio files: 134
PostPosted: Thu Jan 30, 2014 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm still very keen for 2 of these as well Smile Smile (pcb only for my blue system )
epicyclus@skrogmusic.plus.com
Audio files: 134
PostPosted: Thu Jun 12, 2014 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello Matthias.
Smile
Are you still thinking of doing a small run of these binary boards ?
I'm still very interested in 2 pcb's only , if you decide to do some.
Thanks
PostPosted: Thu Jun 12, 2014 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
i hear you, dave.
the project is postponed due to lack of time/priorities. but it is not dead, i still plan to do it. i just don't have the time right now.
Audio files: 134
PostPosted: Mon Jun 16, 2014 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool , I will save a space for it Very Happy Very Happy
diablojoy
PostPosted: Fri Jun 20, 2014 3:16 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm cant save any space in my small euro case now but I will make some space when it comes out, just means another case Laughing
bubzy
Audio files: 63
PostPosted: Mon Dec 22, 2014 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
hey Matthias,
did you find the time/motivation to continue with this yet?
_Richard_ Smile
PostPosted: Mon Dec 22, 2014 8:49 am    Post subject: Reply with quote  Mark this post and the followings unread
bubzy wrote:
hey Matthias,
no, but i could upload the new schematics?
Audio files: 134
PostPosted: Mon Dec 22, 2014 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool Cool YES PLEASE Cool Cool
I saved a panel just for this Wink
Thanks in advance, Matthias.
bubzy
Audio files: 63
PostPosted: Mon Dec 22, 2014 5:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes please Smile that would be awesome, thanks matthias
_Richard_ Smile
PostPosted: Mon Dec 22, 2014 10:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
okay, here it is. however, the schmatic has no comments/notes, and the encoder section is not tested yet.
BinarySeq_v2.pdf
 Filename:  BinarySeq_v2.pdf
 Filesize:  99.67 KB
 Downloaded:  338 Time(s)
Audio files: 134
PostPosted: Tue Dec 23, 2014 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Matthias.
need to source an encoder & max313cpe then the breadboard comes out.
Was there a particular number of notches / pulses rotary encoder you had thought about using ?, I have never wired one up before but im sure it will be easy Smile .
(starts to read "rotary encoders for dummies") Very Happy
PostPosted: Tue Dec 23, 2014 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Skrog Productions wrote:
Thanks Matthias.
since this is an 8 bit system we have 254 possible stages. and if you wanted to 'move' to a paticular stage (i.e. for mixing purposes) you don want to use a momentary switch. it would be boring to push that button 250 times, no?
so i just wanted to wire the encoder as a 'rotary momentary' switch (or on/off). the rising edge of each encoders gate will then converted to a short pulse, triggering the divider IC.
so no special requirements on that encoder, it just has to be an incremental one IIRC.
Audio files: 134
PostPosted: Tue Dec 23, 2014 4:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Matthias , just to check could this do the job ? http://www.rapidonline.com/electronic-components/bourns-ecw1j-b24-ac0024l-contact-incremental-encoder-panel-mounted-49-5936
PostPosted: Tue Dec 23, 2014 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
absolutley.
Audio files: 134
PostPosted: Tue Dec 23, 2014 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Magic , thanks Smile Smile
Audio files: 134
PostPosted: Tue Dec 23, 2014 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I have been doing some price checks for UK stocked MAX313 and I have been seeing prices from about £7 to £14 per chip , I did a search on Rapid for quad analog switch and this came up , the specs seem fairly close on the PDF's ..... http://www.rapidonline.com/electronic-components/dg411dj-spst-analogue-switch-slx-82-0284
PostPosted: Tue Dec 23, 2014 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
DG411 is 'NC' (normally closed), whereas the MAX313 or DG412 is 'NO' (normally open).
so you could use a DG412. the MAX313 is just newer, faster, with less on resistance.
mcop
PostPosted: Tue Dec 23, 2014 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent, been waiting to see where this went. Thanks for sharing the schematic.
PostPosted: Tue Dec 23, 2014 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
i still hope to do a set of PCBs for this Shocked
PostPosted: Tue Dec 23, 2014 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
hope dies last.
Audio files: 134
PostPosted: Tue Dec 23, 2014 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your help Matthias, i'll get a couple of DG412dj chips for the test layout and decide from there Smile.
Have a great Xmas.
Cheers.
