  Faux Pas Quartet and friends Music From Last Thursday
CD4031 tap looper...
Page 2 of 2 [31 Posts]
Goto page: Previous 1, 2
nathanxl
PostPosted: Sat Apr 05, 2014 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi. Ive been away all summer(winter for you in the north).
The workshop is now cool enough to work in.
Ive just bought a bunch of MC14557 chips and want to try out this circuit.
While Im waiting for them to arrive, could you smart fellows perhaps shed some light on whats going on.?..
Using all of the 64bits how many gate will this get me?
Am I correct that it will allow me 64 gates passing through it and then loop them?
Sorry if this is a silly question.
noto
PostPosted: Sat Apr 05, 2014 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
check out the mc14517 too. when i saw this concept for the first time, it blew my mind! i used it to build a four part programmable drum machine for a circuit bent yamaha PS-3. my schematic is probably unreadable to anyone but me, but if you'd like, i can redraw it..
http://2.bp.blogspot.com/-LqcYmi9hPuo/Uds4K7_vvlI/AAAAAAAAAxY/JlDh9VtwXmE/s1600/Picture+074.jpg
more info on the PS-3 build
http://www.noystoise.com/2013/07/yamaha-ps-3.html
billsship
PostPosted: Wed Jun 18, 2014 9:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there a way to clear the 4031's 'memory' quicker than holding down normally-on button for the duration of it's cycle?
I'm wondering if cutting off pin 16 (+V) momentarily would help it forget.
The reason being, if feeding slower clocks into this thing, 64 steps might take a while to cycle through.
Vine username: "billsship"
Modulargrid
noto
PostPosted: Wed Jun 18, 2014 10:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
for mine, I used a 'step-erase' switch to delete steps incrementally, and a 'quick-erase' switch that opened the loop while switching the input clock to another one that was set to a significantly higher frequency. one short press and the whole sequence is gone. if you just turn the power off, some of the bits will still be stored when you power back up. I found it necessary to build an 'initial-clear' circuit and a flip flop to keep the loop open upon power up, but then closed when a 'write' signal is sensed.
billsship
PostPosted: Wed Jun 18, 2014 10:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Clever!! So, I'm guessing you manually advanced the clock input with a pushbutton, and if you saw that the bit was high, you would press the clear button?
Your way of switching to a fast clock to quickly cycle through an clear the bits, I think that's a really great idea. However, I plan on using an external clock for this. Maybe I could have a simple 40106 on board for this duty alone.
Also - did you incorporate some type of reset into this? Or did you consider any step the 1st step if they were all cleared?
Modulargrid
noto
PostPosted: Thu Jun 19, 2014 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
actually no, my 'step delete' would just delete each step as the clock advanced. you could use a push button though. the thing to remember though is that there will need to be a low state between each high state, so the clock input would need to be advanced twice per step. for mine, i used a 4017 frequency divider that was driven by the input clock. one of eight divisions could then be recorded to the shift register. i also added an inverter switch to be able to swap the 'spacer' and 'recordable' bits.
i'm not sure if you could reset the sequence to the first step... i don't think i tried that. that would be a nice function to have though. mine had four loopers synced together, but each had a switch to select between 8, 16, 32, and 64 step patterns, so the potential for messing up the synchronicity between each loopers' 'bit-0' while selecting the pattern length would be an issue.
anyway, good luck Very Happy
