XCenter
Posted: Fri Jun 20, 2014 3:42 am Post subject:
"Wind" for noise is superb.
Would have been "Schietwetter" for a hamburgian synth.
For an austrian synth it could have a bit more Schmäh.
Oh man, I love this! _________________ --
How may I be of disservice?
Music for conscious listening @ http://www.fmdelight.de/ |
dave the butcher
Posted: Fri Jun 20, 2014 3:47 am Post subject:
german |
i should have asked first, i see. although MULTIPLE is a compromise due to the space i had for the writing. Amplitude seems german enough to me, although your suggestions are better. i think i will change that.
Beste Grüße!
David |
XCenter
Posted: Fri Jun 20, 2014 3:56 am Post subject:
Re: german |
dave the butcher wrote: | i should have asked first, i see. |
Sorry, I just haven´t noticed the mockup design you posted before.
Klasse Panel! _________________ --
yusynth
Posted: Sun Jun 22, 2014 7:17 am Post subject:
Great built and nice original panel, all these german labels reminds me of my beloved PPG 100 modular ! _________________ Yves |
dave the butcher
Posted: Mon Jun 23, 2014 10:50 am Post subject:
Quote: | Great built and nice original panel, all these german labels reminds me of my beloved PPG 100 modular ! |
I have to confess that i had a close look at your photos of the PPG and was inspired. coolest place on the internet is the yusynth-site!
all the best from austria!
david |
billsship
Joined: Apr 14, 2013 Posts: 21 Location: Arkansas, USA
Posted: Fri Jul 04, 2014 10:43 am Post subject:
One of my first contributions here! I've been building kits in Eurorack format, and slowly designing my own circuits. My goal is to have my whole system DIY.
Here's a few from Barton Musical Circuits.
Thanks for all of your inspiration and help and an awesome community!
Description: |
Barton Dual LFO and S&H billsship |
Filesize: |
49 KB |
Viewed: |
419 Time(s) |
Description: |
Barton Dual LFO and S&H billsship 2 |
Filesize: |
73.67 KB |
Viewed: |
562 Time(s) |
Description: |
Barton Quad VCA / Mixer billsship |
Filesize: |
45.54 KB |
Viewed: |
437 Time(s) |
Description: |
Barton Full Wave Dual Rectifier wood panel from a clipboard billsship |
Filesize: |
109.93 KB |
Viewed: |
465 Time(s) |
Description: |
Four Barton Analog Drums spraypainted billsship |
Filesize: |
210.81 KB |
Viewed: |
480 Time(s) |
_________________ Vine username: "billsship"
Modulargrid |
billsship
Posted: Fri Jul 04, 2014 10:57 am Post subject:
Also sduck your panels looks amazing.
I think I'll start using FPE to make custom panels. _________________ Vine username: "billsship"
Modulargrid |
DickyKnee
Posted: Tue Jul 15, 2014 8:37 am Post subject:
SDS-3 clone in 5U |
SDS-3 clone PCBs from xpmtl
SOCK4 PCBs from Oakley
panel from FPE natural finish with white infill.
brushed aluminium knobs from altronics
White LEDs
Description: |
Filesize: |
114.5 KB |
Viewed: |
454 Time(s) |
Description: |
Filesize: |
188.37 KB |
Viewed: |
397 Time(s) |
Audio files: 705
isak
Posted: Thu Jul 24, 2014 7:48 am Post subject:
hi PHOBoS
nice work man!
it is a beauty!
i see in head how my kids play with it and making cool sounds _________________ http://www.myspace.com/mgmtrance |
Posted: Mon Jul 28, 2014 7:44 pm Post subject:
This is Tom Gamble's Electronics For Musicians 3046VCO, laid out by me. About as simple as it gets, really.
Yves Usson's Steiner Parker VCF (my layout.) Not quite as simple. Lots of fun, though.
Thanks to both original designers |
isak
Posted: Tue Jul 29, 2014 2:10 am Post subject:
AlanP wrote: |
Nice job!
I love how people work hard on their moduls, keep up the good work! _________________ http://www.myspace.com/mgmtrance |
prgdeltablues
Audio files: 12
Posted: Thu Jul 31, 2014 2:04 pm Post subject:
Latest addition: a module I've called Second String. Basically an 8 step sequencer with three separate outputs, each step of which is independently controllable to put out between 0 and 16 semi-tones of CV. Intended to allow chords to be built using 3 or 4 VCOs (one to supply the root note, either 2 or 3 for the notes of the chords). Alternatively, one output can control a separate VCO, eg as a bass, in the attached sample.
Rats nest of wiring as you can see. And as for the panel - that's 24 4-way DIP switches, and 96 resistors!
Description: |
Filesize: |
991.95 KB |
Viewed: |
184 Time(s) |
Description: |
Filesize: |
1018.4 KB |
Viewed: |
362 Time(s) |
Description: |
Filesize: |
986.97 KB |
Viewed: |
252 Time(s) |
Description: |
Filesize: |
842.72 KB |
Viewed: |
227 Time(s) |
Description: |
Psynth - Second String noodle Monkey Cymbals, Bass++ at 15s, Since VCO Bass line controlled by Second String at 25s, Root square wave VCO at 37s, 2nd and 3rd strings at about 1 min. |
Download |
Filename: |
second string sequence.mp3 |
Filesize: |
4.2 MB |
Downloaded: |
796 Time(s) |
Posted: Thu Jul 31, 2014 10:30 pm Post subject:
prgdeltablues wrote: | Latest addition: a module I've called Second String. Basically an 8 step sequencer with three separate outputs, each step of which is independently controllable to put out between 0 and 16 semi-tones of CV. Intended to allow chords to be built using 3 or 4 VCOs (one to supply the root note, either 2 or 3 for the notes of the chords). Alternatively, one output can control a separate VCO, eg as a bass, in the attached sample.
Rats nest of wiring as you can see. And as for the panel - that's 24 4-way DIP switches, and 96 resistors! |
That's a pretty neat idea!
I'm frightened to ask how long wiring it up must have taken, though |
prgdeltablues
Audio files: 12
Posted: Fri Aug 01, 2014 3:25 am Post subject:
Quote: | I'm frightened to ask how long wiring it up must have taken, though Shocked |
A fair few hours
Actually, debugging was the worst part. All those resistors and wires soldered to a small piece of stripboard = plenty of opportunity for shorts. Also, I had some msyterious errors in voltages which I finally tracked down to the residue from the no-clean solder, forming a resistance in parallel with my supposedly matched 100k's. |
sduck
Posted: Thu Aug 14, 2014 9:53 am Post subject:
billsship wrote: | Also sduck your panels looks amazing.
I think I'll start using FPE to make custom panels. |
Thanks! Yes, I like FPE, after getting over the learning curve part of their design program. Kind of expensive, but the results are great, so it's worth it.
Haven't checked in here in a while, and forgot to post this here -
vladosh
Audio files: 46
Posted: Fri Aug 29, 2014 12:05 pm Post subject:
this new build has 2 x 258 VCO's ,TZERO VCO from Electronotes ,Serge VCS ,2 x LFO's , MFOS VCA x 2, ARP VCF , Analog Neuron ,Mixer , Roland 100M ADSR ,Portamento and lot of wires ,happy with how it turned out ,the colorful panel pic is photoshop
Description: |
Filesize: |
1 MB |
Viewed: |
234 Time(s) |
Description: |
Filesize: |
1009.29 KB |
Viewed: |
227 Time(s) |
Description: |
Filesize: |
1.61 MB |
Viewed: |
228 Time(s) |
Description: |
Filesize: |
1.03 MB |
Viewed: |
247 Time(s) |
Description: |
Filesize: |
1.47 MB |
Viewed: |
267 Time(s) |
_________________ http://synthacks.blogspot.com/ шематикс |
Audio files: 278
Posted: Fri Aug 29, 2014 3:28 pm Post subject:
Nice synth Vladko! _________________ Jan
Joined: Apr 24, 2009 Posts: 2492 Location: Bristol UK
Audio files: 495
Posted: Fri Aug 29, 2014 3:42 pm Post subject:
vladosh wrote: | this new build has 2 x 258 VCO's ,TZERO VCO from Electronotes ,Serge VCS ,2 x LFO's , MFOS VCA x 2, ARP VCF , Analog Neuron ,Mixer , Roland 100M ADSR ,Portamento and lot of wires ,happy with how it turned out ,the colorful panel pic is photoshop |
That looks great! The shopped one too.
Any audio coming this way soon? _________________ Muied Lumens Sub Forum
Bandcamp |
vladosh
Audio files: 46
Posted: Fri Aug 29, 2014 3:59 pm Post subject:
Thanks ,i'm happy with this build overall ,could have picked other wood material for the case maybe ,audio i have some but i gotta say poor quality from my cheap souncard ,some noise in the back, i'm posting it anyay ,these are the buchla 258's ,in tune ,and some other patch ,btw using a 208 Random just to play a seq ,this box is missing a s/h for sure ..btw made some great glithy patches but the soundcard is so bad didn't dare to record , the neuron has anextra input and the mixer has 3 outputs for lot of feedback crazyness
Description: |
Download |
Filename: |
B258Pattern.flac |
Filesize: |
6.97 MB |
Downloaded: |
972 Time(s) |
Description: |
Download |
Filename: |
Perkusii.ogg |
Filesize: |
6.53 MB |
Downloaded: |
961 Time(s) |
Description: |
Download |
Filename: |
erere.flac |
Filesize: |
3.37 MB |
Downloaded: |
1003 Time(s) |
Description: |
Download |
Filename: |
click.flac |
Filesize: |
2.78 MB |
Downloaded: |
1003 Time(s) |
Description: |
Download |
Filename: |
Drone.ogg |
Filesize: |
3.83 MB |
Downloaded: |
943 Time(s) |
Audio files: 705
Audio files: 495
vladosh
Audio files: 46
Posted: Sat Aug 30, 2014 7:23 am Post subject:
Thanks Phobos i enjoyed making it .Muied Lumens i didn't had the chance really to explore it's sounds well ,i think it is capable ,but you can hear the recordings are noisy and i also think missing a lot of detail ,anyway ...what's next to build _________________ http://synthacks.blogspot.com/ шематикс |
Audio files: 495
Posted: Sat Aug 30, 2014 7:27 am Post subject:
vladosh wrote: | Muied Lumens i didn't had the chance really to explore it's sounds well ,i think it is capable ,but you can hear the recordings are noisy and i also think missing a lot of detail ,anyway |
Even when listening on my iPad I could hear the potential. _________________ Muied Lumens Sub Forum
Bandcamp |
Posted: Sun Aug 31, 2014 1:59 am Post subject:
So, what did you spend your weekend on?
The synthcube box arrived Friday, and I got a case of the enthusiasms.
Some problems arose.
One, Gate Bus 3 didn't work. A bit of time with the multimeter and the cable charts from the original build doc, and I found that stabbing one of the crimped connectors hard with a screwdriver fixed it.
Two, 4 Oct won't bloody calibrate. Oh well, I don't care. I'll use the variable range for that.
Three... my ghetto diy case has now run out of room |
