<on air> Various Artists Live streaming concert in memory of Antimon
G2X (OS1.62) keeps resetting after power up.
Page 1 of 1 [24 Posts]
homers
PostPosted: Mon Sep 03, 2012 4:01 pm    Post subject:  G2X (OS1.62) keeps resetting after power up. Reply with quote  Mark this post and the followings unread
My G2X (OS 1.62, no PC attached, initial patches which came with 1.62) keeps resetting himself after power up.
Sometimes when I do a power cycle (on/off/on) multiple times it starts working again.
Unfortunately it falls back into resetting when I'm loading a new a new patch from the G2X memory in one of the slots, not always but quite often.
I wasn't sure if I should but the topic here or into the bug part.
Any ideas?
Audio files: 214
G2 patch files: 319
PostPosted: Mon Sep 03, 2012 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome homers. Annoying problem Confused
If I were me .. I'd open it up and look .. maybe something is loose?
Could it be your power is low, like say 90V instead of 110?
Just some wild thoughts.
homers
PostPosted: Mon Sep 03, 2012 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I already checked the connections and the switch on the power supply shows 110V other synths on the same outlet have no problems.
Audio files: 214
G2 patch files: 319
PostPosted: Mon Sep 03, 2012 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
As in you opened it up?
homers
PostPosted: Mon Sep 03, 2012 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep.
Audio files: 214
G2 patch files: 319
PostPosted: Mon Sep 03, 2012 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Damn, I'd have to think now Shocked
Pull cables and reseat 'm?
homers
PostPosted: Mon Sep 03, 2012 4:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok will do and report back tomorrow.
homers
PostPosted: Mon Sep 03, 2012 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Couldn't wait until tomorrow open the G2X unplugged all ribbon cables on both sides not only at the mainboard side as I did it the last time and it looks good so far Very Happy Very Happy
Let's for how long it will last.
Derek Cook
PostPosted: Fri Sep 14, 2012 12:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hopefully a long time. Smile
Connectors can get oxidized over time. The other possiblilty with the G2 engine as it runs quite warm (mine does anyway) is thermal creep of connectors if there are no retaining lugs/straps. As things heat up and cool down they expand and contract which can gradually work connectors/pins out of sockets over time. It happens with chips as well if they are socketed, so it's always giving them a firm push when fault finding.
Regards
Derek Cook
www.echoes-music.co.uk
www.purefloyd.co.uk
www.carregddu.co.uk
www.xfactory-librarians.co.uk
www.ex5tech.com
paalolav
PostPosted: Mon Sep 17, 2012 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I had the same problem with my G2X. Talked to a tech who recomended me to change the PSU, which I did. I had a spare one from a Nord Stage. It has worked perfectly ever since. Knock on wood!
homers
PostPosted: Mon Sep 17, 2012 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I forgot to mention, that after I put the G2X back in the rack it happened again.
I also found a trick, while doing the endless reboot you have to steady turn one of the continues controller during the reboot which will break the cycle eventually.
It is really strange, I like the idea with the psu but I don't have any spare parts, any idea where I can get one?
paalolav
PostPosted: Mon Sep 17, 2012 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Check with your local Clavia dealer. Good luck!
paalolav
PostPosted: Mon Jan 14, 2013 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Any updates?
paalolav
PostPosted: Mon Jan 27, 2014 7:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I had the same issue again. After consultation with the Clavia rep in Norway, I tried resetting the synth and installing firmware 1.40. It is now cured! Knock on wood...
Scot Solida
PostPosted: Tue Mar 25, 2014 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would love to know how you reset it. I have a brain-boggled G2 prototype unit and no reset procedure I have tried worked. Maybe your procedurewould be different from those i have tried...
varice
Audio files: 29
G2 patch files: 53
PostPosted: Tue Mar 25, 2014 9:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scot,
If factory software resets have not solved your problem, then it may be a hardware problem instead. I’ve had a few other synths (and other electronics) in the past that had intermittent problems that turned out to be just poor power supply or interconnect cable connections. Over time, it is not unusual that the contacts of the connectors may oxidize and even build up a little corrosion. I would recommend that you open your G2 and try unplugging and replugging the cable at both ends between the power supply and main PCB (with the mains AC power cord unplugged first of course Exclamation ).
varice
Scot Solida
PostPosted: Wed Mar 26, 2014 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks varice. Yes, I have done those things… I even had a new ribbon cable made to replace the one that connected the front panel to the main board.
It was my own fault that it died. I was warned that it might not respond well to any firmware updates and those warnings were not wrong. My front panel is pretty much completely useless. The keyboard works, but most of the buttons do not and most of the knobs either do not work or behave in unexpected ways.
Clavia suggested reinstalling the original firmware that was sent with the thing, but that didn't work, either. In fact, each time I tried, i got different, varying results (some knobs would work after some attempts, but not others).
I can still control it with the software editor, so it behaves as the equivalent of a G2 Engine at this point.
paalolav
PostPosted: Tue Apr 01, 2014 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahh - can't remember right now, but I found it by searching this forum! It's a combination of three buttons held down while powering the G2 on.
homers
PostPosted: Sun Jun 08, 2014 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for the late reply guys.
The first solution for my problem was to replace the fuse with the proper value. My G2 is an European Model but inside of the G2 there is a switch to change the input voltage to 110V which I did. Of course I forgot to replace the fuse with a higher one due to the higher current. After I changed that it worked well the last time when I worked with it a couple of months ago. But today it went back doing the looping Sad
homers
PostPosted: Fri Jun 20, 2014 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I found out that the G2 works fine when as long as the G2 editor is not running. When I start the editor the g2 starts reseting himself after a 5~10mins (haven't stopped the time yet).
Any ideas?
homers
PostPosted: Sat May 02, 2015 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I'm back in Germany (240V Cool ).
I think I found the issue why my g2x is behaving this strange.
After I finally decided to remove the voice expansion board the g2x started to work fine, no reboots/freezes with or without the g2x connected to the editor.
Have any of you information about faulty expansions boards in the first g2x which were shipped out?
Audio files: 214
G2 patch files: 319
PostPosted: Sat May 02, 2015 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. in the beginning .. but that was with prototypes I think .. there were issues with the expansion .. but this is from rumors only ... sorry that's all I know.
homers
PostPosted: Wed May 06, 2015 3:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I already resoldert the two connectors on the soldering side of the board but no luck so far. Maybe I should try the same with the mainboard?
I hope it is just a cold soldering because the G2X was working from time to time. I keep you posted.
kslight
PostPosted: Sun May 24, 2015 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't own a G2 anymore, but when I had one sometimes it would be weird when connected to the PC. I replaced the USB port and worked perfectly until I sold it.
Very simple job for any soldering monkey to do, and its a standard USB type B port.
