NPN transistor matcher stripboard?
Page 1 of 1 [7 Posts]
Snaper
PostPosted: Mon Jun 23, 2014 9:27 am    Post subject: NPN transistor matcher stripboard? Reply with quote  Mark this post and the followings unread
Hi Guys,
Has somebody a simple, easy to build tranny matcher for stripboard?
Can't find any, and transferring schems to stripboard is hard for me...
PostPosted: Mon Jun 23, 2014 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I wired up the circuit here directly to a pair of 4 pole switches.
https://home.comcast.net/~ijfritz/MiscProj/transmat001.pdf
No stripboard needed.
Snaper
PostPosted: Mon Jun 23, 2014 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I dont have that kind of switch...got sockets, resistors, diodes and stripboard, so after my son fall aslepp today, I will be able to put it together:)
PostPosted: Tue Jun 24, 2014 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you also have to match the gain? I thought you did, but I could be wrong.
Snaper
PostPosted: Tue Jun 24, 2014 3:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Came up with this, based on Ian Fritz's simple matcher and Rogloks layout :
Will build it today evening Very Happy
 Filesize:  82.5 KB
 Viewed:  117 Time(s)
-minus-
PostPosted: Tue Jun 24, 2014 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Handy layout, thanks. I think that middle GROUND rail which is going to R3 and PIN3 of the PNP socket, might need to be cut.
Snaper
PostPosted: Tue Jun 24, 2014 4:20 am    Post subject: Reply with quote  Mark this post and the followings unread
My bad Very Happy
Updated!
