Simple but fun bleepy machine
Page 1 of 2 [46 Posts]
nicolas3141
PostPosted: Wed Feb 26, 2014 4:54 am    Post subject: Simple but fun bleepy machine Reply with quote  Mark this post and the followings unread
I haven't posted on here for a while, but I am running a workshop this weekend, getting some beginners started on the soldering addiction. I have rehashed some of my simple oscillator circuits and merged them into a single (strip)board that gives an LFO and VCO with PWM and headphone output - 6 knobs to twiddle and all running off a single 9V battery. Simple to construct, but capable of a good range of bleepy type sounds. All components easy and cheap to source. Basically designed to be an easily achievable first project that is simple enough for a beginner to build in a weekend, but sophisticated enough to make quite a satisfying range of cool sounds.
Nicolas
nicolas3141
PostPosted: Wed Feb 26, 2014 4:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Please let me know if you build this and have any issues or comments or feedback.
Thanks,
Nicolas
 Filesize:  227.44 KB
 Viewed:  698 Time(s)
 Filesize:  203.37 KB
 Viewed:  518 Time(s)
nicolas3141
PostPosted: Sun Mar 02, 2014 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
The new jpeg has a couple of things moved over slightly to make sure that the pots all have spare tracks either side of them. That makes it easier/safer if you are mounting the pots on the copper side (which is what I recommend). If you are mounting the pots on the copper side the legs of the pot need to be inwards towards the centre of the board, if you are mounting them through-hole you will need to have them oriented with their shafts inwards and legs nearer the edge. Hope that makes sense.
Nicolas
nicolas3141
PostPosted: Sun Mar 02, 2014 6:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also, I meant to say, that this circuit has now been built 5 times without problems so the layout is definitely good to go and is well suited to an educational setting where you can use it as the basis for teaching soldering, component identification, basic electronics including opamps, and some aspects of analog synthesis. About right for beginner adults or teenagers as long they have a reasonably good attention span. And at the end they have a little machine that can make some very cool sounds. A beginner (adult) who has never soldered before can build this (with a little bit of coaching) in about 6 hours of soldering. Plus a bit of extra one on one time at the end with someone to help them debug it and get it working. The only issues we had were the usual: placement off by one track, polarity wrong with diodes and electros, solder bridges between tracks, copper whisker bridges between tracks where they had been cut.
Nicolas
PostPosted: Sun Mar 02, 2014 8:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Nicolas!
inlifeindeath
PostPosted: Wed Mar 05, 2014 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
looks great! thanks again for sharing
nicolas3141
PostPosted: Wed Jul 02, 2014 12:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Played a gig last week making ambient noise with this as my sound source (together with two other guys playing mini modulars based on my circuits and a third guy playing a laptop as his sound source). This circuit above is definitely capable of a very cool and quite wide range of sounds. Especially with an effects pedal or two after it you can do a lot and those six knobs offer a lot of expression. Very happy with how it turned out Smile
-minus-
PostPosted: Wed Jul 02, 2014 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey nicolas. Any chance of posting some sound clips or a video? I'm sure people would build this if some demo was available.
nicolas3141
PostPosted: Wed Jul 02, 2014 3:47 am    Post subject: Reply with quote  Mark this post and the followings unread
A recording was made at the gig, but right now that is two hours of audio that needs to get edited down by someone and I don't even have it on my computer to attack. It might be easier for me to specially record a little demo noodle to show a few of the sound possibilities. That way you could also get a chance to hear it dry and in isolation. I will see what I can do.
Nicolas
kaputtpanzer
PostPosted: Thu Jul 03, 2014 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also curious how it sounds. A soundclip would be awesome. Very Happy
L´Andratté
PostPosted: Thu Jul 03, 2014 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Nicolas!
Nice to see you posting here again!
Just wanted to say (before I examine your newest stuff), your VCF & LFO (stripboard layout) were my first REALLY cool synth circuits, I got working, maybe 2 years ago. Kept me going Laughing and I´m happy about that now!
Hope you´re well!
nicolas3141
PostPosted: Sun Aug 31, 2014 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a link to a recording of the gig.
http://www.youtube.com/watch?v=0phQk8Qoa5Y
Not a very interesting video and the sound quality isn't great, but it gives you a pretty good idea of how we sounded. Of the four of us, I was playing this mini-synth circuit above (with delay and chorus), Adam was playing a mini-modular made up of various circuits of my design (2xVCO, LFO, VCLFO, S&H, VCA, VCF, ribbon controller), Dave was playing a VCO of my design plus running the mixer to blend us all together, Malcolm was using his laptop as a polyphonic oscillator. The sustained organ-like tones are Malcolm's laptop, but all the other stuff going on is from this circuit or other circuits of mine:
http://electro-music.com/forum/topic-34550.html
The other aspect of the sound is that we were all running our outputs into amps inside brewing tanks (this gig being in a small brewery) which were then miked to pick up the sound colour of the tanks.
Nicolas
Ray_Ketamu
PostPosted: Wed Nov 19, 2014 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
awesome!!!
one question from a total greenhorn. Is C5 12nF? in germany (thats where i live) i can´t find any 12n capacitors... can i use 10nF or 15nf instead?
nicolas3141
PostPosted: Thu Nov 20, 2014 12:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Any capacitor within 10-20% should work fine, 10nF or 15nF would both work. Go for 15nF if you want a bit more bass range, 10nF if you want a bit more treble.
Nicolas
nicolas3141
PostPosted: Thu Nov 20, 2014 12:43 am    Post subject: Reply with quote  Mark this post and the followings unread
This is a lot of fun to play with. Mine will be coming out with me again tomorrow night to a gig. One thing I have been thinking about is that the aim was to create something monotron-like and one key feature lacking is an input socket to mangle other audio signals. I think the coolest place to inject some external audio would be the R7/R8/C5/D5 node. A resistor from that node (probably somewhere in the 33-100K range) to an input socket. I will try it sometime soon, but if anyone else gets the chance to try it first, please post here your comments on whether it is sonically interesting.
Thanks,
Nicolas
Ray_Ketamu
PostPosted: Thu Nov 20, 2014 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
i had a talk with a friend of mine who is a programmer and we came up with the idea of making a arduino based keyboard controller in the cv/hz range. the whole idea is based on the octosynth
http://www.instructables.com/id/The-Arduino-OctoSynth/
as soon as we have the whole think up with code i will post it in the nicolas threads. (I know thats actually for the arduino threads but it´s a special nicolas synth related project)
also i want to mention the Pt2399 delay IC for the bleep machine... making it an monotrondelay...
So awesome for newbees!!! im allready delighted with these circuits!
Sound: https://soundcloud.com/stream Art: http://ketamuworld.blogspot.de/
nicolas3141
PostPosted: Sat Nov 22, 2014 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Question has come up ... "missing polarity markings on the capacitors c3,c4,c5. does it mean it doesnt matter?"
For these caps you need to buy unpolarised. Polarised caps like electrolytics and tantalums are marked and used for larger values. Pretty much all small value caps are unpolarised types. The 1uF cap is interesting because around that value you can get both polarised and unpolarised types, but in this case you need to make sure you get an unpolarised type and then it doesn't matter which way you solder it in.
Thanks,
Nicolas
Citezyne
PostPosted: Fri Jan 09, 2015 11:16 pm    Post subject: Substitutes? Reply with quote  Mark this post and the followings unread
Hi, electro-music'ers,
I am new to sdiy, and have an average grasp of electronics.
Is it possible to substitute any of the IC's with TL0xx IC's? sorry about the noob question.
Edit:
I ask as i have allot of TL074's lying around.
PostPosted: Fri Jan 09, 2015 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would imagine all of them, they're pin compatible even.
Citezyne
PostPosted: Sat Jan 10, 2015 12:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for that, I did notice that the pin out was the same. gonna bread board it up now with 2 TL074's.
Excited to see how much better this will be compared to my APC 8step lol.
Citezyne
PostPosted: Sat Jan 10, 2015 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the help thus far,
however due to lack of supply in my stash of gear, I don't have any of the 33k, 68k and 750r resistors how strict do I need to be? Can I play with resistors that are as close to the ones as required?
What effect would this have on the system?
PostPosted: Sat Jan 10, 2015 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
If you're building on a breadboard, I'd say just experiment and see.
The other thing is, you can combine values of resistors get get other values. Obviously series resistors add together, parallel resistors combine in a more complex way.
Some handy calculators on this page: http://cgi.linuxfocus.org/~guido/javascript/circuit-design-calculator.html
nicolas3141
PostPosted: Sun Jan 11, 2015 1:17 am    Post subject: Reply with quote  Mark this post and the followings unread
The components I used just reflect what I had in my stash at the time. For things like R1, etc the value is not too critical, certainly anything within 30% would probably work fine. If you want to push the values beyond 20% either way then push them all as it is generally the ratios that matter. So if you want to use 1K for R1 then fine, but also use something a bit on the large side for R2, say 4-5K. Same for R3-R6, the values are not critical, but the ratios are what matters. Keep R3 and R4 the same as each other and roughly half of R5 and R6 which should be the same as each other. R7 and R8 can be varied quite a lot and it will affect the freq range, but not necessarily in a bad way Smile None of the component values in this circuit are critical so have fun and make something unique by trying whatever you have to hand. The LM324 vs TL074 question is interesting, because it will almost certainly work and it may even work better, but it will probably sound slightly different at the extremes and it is at the extremes that this circuit is most interesting, ie when the LFO is almost stopped or when it is screaming in the upper audio - that is where it gets interesting - and that is where choice of op-amp may make a difference. But TL074 may be better, so go ahead and give it a go. As I said, nothing is critical in this circuit and everything is crying out for experimentation Smile
Citezyne
PostPosted: Wed Jan 14, 2015 10:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello again,
I seem to be having issues with this build as in nothing happens. Crying or Very sad
Testing with a multi meter I see power in the circuit but it looks like it might be too low or something. Could it be due to c4 cap u state 220n I only had 100n caps and as such only used one. Could or should I use more.
Still new to electronics so pardon the simple questions and ignorance.
L´Andratté
PostPosted: Wed Jan 14, 2015 10:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Citezyne!
No, c4=100n is not the problem, in worst case it would cause a little low end roll off (I don´t think so).
Check your power scheme, is the battery putting out enough voltage (7.5-9V)?
Are your supply rails (+v/-v) at +ca.4V/-ca.4V with ground at 0V?
Check IC1a and IC2b, check the right orientation of D1 and D6, I think that would be a good start for trouble shooting!
