Passive ring modulators
Page 1 of 1 [7 Posts]
Vanwonky
PostPosted: Mon Jul 07, 2014 7:01 am    Post subject: Passive ring modulators
Subject description: How to wire them up?
Howdy All,
I am keen to give the passive ring modulator a go but my peabrain is having convulsions! It looks simple enough but I can't work out the ins and outs literally. With two inputs, two carrier and two outs I am guessing some go to ground right. Square wave on the input and carrier etc? I have looked hard but can't find any schematics that don't have a whole lot of other components buffering and whatnot.
On a bright note my Lunetta is progressing nicely and I hope to have a show and tell soon. Shocked
You probably don't believe that after posing such a simple question as above!
Audio files: 216
G2 patch files: 319
PostPosted: Mon Jul 07, 2014 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah you can ground one input, one carrier and one output pin - arbitrary which.
Thee most friendly tones come out with sines on input and carrier, but squares will work too.
Vanwonky
PostPosted: Mon Jul 07, 2014 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan. I think I can handle that! Smile
JingleJoe
PostPosted: Tue Aug 05, 2014 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Is one of your diagonal diodes backwards?
Message me if you're interested in my transistor based ring modulator, I haven't tried it with analogue waves but it works perfectly with square and only uses about 5 resistors and transistors... that sounds like i mean 5 of both, i mean 5 components in total of only resistors and transistors.
Vanwonky
PostPosted: Tue Aug 05, 2014 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Who could resist! PM your way.
commathe
PostPosted: Tue Aug 05, 2014 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I would also be very interested in that!
synaesthesia
Audio files: 85
PostPosted: Tue Aug 05, 2014 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
There is a circuit I found here http://staging.edn.com/design/other/4373765/Perform-the-XOR-XNOR-function-with-a-diode-bridge-and-a-transistor. Part count is higher though, so I am interested as well.
(image removed)
