My current VCO - comments/help appreciated
Page 1 of 1 [14 Posts]
m.o
PostPosted: Sun Aug 03, 2014 8:40 am    Post subject: My current VCO - comments/help appreciated Reply with quote  Mark this post and the followings unread
Hi guys,
This is what I currently have for VCO in my "poly project".
This is not a unique design in any way, I have been reading schematics and experimenting trying to understand how a basic VCO works, so I have borrowed from multiple sources (MFOS, Yusynth, etc etc).
It works mostly fine over about 4 (low) octaves as far as I've tested it.
* During breadboarding I had lots of trouble getting a FET to work for resetting the integrator capacitor, that's why I ended up using a 2n3904 - it works but the reset-part of the waveform is a bit "bouncy".
* The Cap in the reset-path from the comparator was something that came from experimenting with the circuit on breadboard (LTSpice doesn't seem to need it really).
* The V5 source was used for testing/simulating sync input.
* The relationship between the current through R15 and the size of the C2 cap seems to work, but I'm wondering if I should lower the current (and decrease the cap value) as I see many designs using a much higher value for R15 (470k -1M ?).
* The D2 + U6 path (disconnected in this pic) was supposed to be the "HF compensation" (again I started by copying/looking at existing circuits) but with current values it seems to give way too much current - I have to got to several Mega-Ohms for it to calm down - this is why I'm wondering if I should change the R15 - C2...
Any thoughts/comments?
 Filesize:  410.61 KB
 Viewed:  343 Time(s)
JovianPyx
Audio files: 190
PostPosted: Sun Aug 03, 2014 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
A 2N3904 needs current to turn it on, whereas an FET (Or MOSFET) needs only a voltage. The bounciness is probably because of the extra current needed to turn the 2N3904 on during the discharge pulse.
Looking on the web, I see a lot of schematics for VCOs that use a FET for discharging the cap so it is something that has been done before and is known to work.
IMO, FET should work better than BJT mainly because it doesn't draw current through it's gate. (well, there is leakage, but the current is far smaller than the BJT base current).
Time flies like a banana.
corruptio optimi pessima
m.o
PostPosted: Sun Aug 03, 2014 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
You are probably right, I'll just have to keep at it (I know this should be basic knowledge) but I've had some difficulty finding explanations about FETs that go beyond "they turn things on with a voltage", for example the relationship between the gate voltage and the voltage/polarity across the drain-source...
m.o
PostPosted: Mon Aug 04, 2014 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tested swapping R15 to 1MOhm and C2 to 270pF.
With this configuration it didn't quite work until I removed C3 (from the reset path), but when I did I got quite a nice looking saw (I'm thinking that if it needs to be there, it should probably be the same order of magnitude as C2...).
The range of the oscillator dropped down to something like 6Hz - 1kHz (about), which I didn't quite expect (I reduced the reference current to 1/10th and the cap size to less than 1/10th so I expected a higher frequency).
I still need to calibrate this properly to see if the HF trim network works...
m.o
PostPosted: Sun Aug 10, 2014 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I went back and tried using a JFET (BF245B, what I had lying around) for the reset as advised (There are definitely reasons why this is what is generally used).
Any recommendations for a commonly available FET to use (IIRC the BF245 are discontinued), 2N7000 ?
This worked great for the reset with just a 100k resistor in the path from the comparator, it also removed my problem with the oscillator going drastically flat after 4 octaves or so.
I would like to understand what was actually happening with the bipolar transistor - I suppose the reason it (kinda) worked with the diode and cap was that the "shape" of the reset-pulse/current is more important...
My concerns with the reference current and the integrator cap size came from how I had my CV summing set up (not shown in the SPICE -screenshot, I had quite a bit of bias towards V-) , so I think most major problems are sorted out now.
I still need to establish the HF-compensation part though, so I'll probably go back to that.
JovianPyx
Audio files: 190
PostPosted: Sun Aug 10, 2014 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
For JFETs, 2N3819 or MPF-102 might work.
I would think that 2N7000 works too, it's a MOSFET so has even lower gate current.
m.o
PostPosted: Wed Sep 03, 2014 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just posting the updated schematic here.
vco-basics 2.pdf
 Filename:  vco-basics 2.pdf
 Filesize:  36.3 KB
 Downloaded:  300 Time(s)
okelk
PostPosted: Thu Sep 04, 2014 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the update.
I'm very interested in basic vco designs at the moment as I'm working on one too (basic tricore... more to fully understand it than to do anything better than others...)
m.o
PostPosted: Fri Sep 05, 2014 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
So kind of the same reason as me then.
I haven't looked too hard at tri-core oscillators, what is your approach to "reversing current" (is that how they work generally?) - I have seen OTAs and I think some ones using some kind of analog switch...
Baloo
PostPosted: Tue Sep 30, 2014 5:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did you get a fine v/oct tracking ?
m.o
PostPosted: Wed Oct 01, 2014 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
They track pretty well over 5 octaves.
(I have tested/calibrated them using a Doepfer A-190-2 Midi to CV which has 0-5V output which is why I haven't tested larger range.)
I haven't gone into the high-frequency compensation yet (hasn't needed to in the range I've used it, < C5).
The simulation with the 2N7000 gives much longer reset time than the actual MPF102 / BF245 I have used, so there's something to look into further.
Also choosing a lower value cap and/or lower trigger level for the comparator (less total charge to dump) would probably also help improve the reset time.
m.o
PostPosted: Wed Jul 08, 2015 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Another note about this schematic:
You need a path to ground somewhere after the integrator op-amp, otherwise it will eventually stop oscillating (a matter of seconds in real life).
I put a large value resistor (1M or so) at the input to the comparator op-amp - this provides a path for both the reset signal from the comparator as well as for the path to the saw-buffer op-amp (not sure which one was causing the actual problem though).
L´Andratté
PostPosted: Sun Sep 06, 2015 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
For purpose of study: J. Haible´s Living VCO uses also a NPN- transistor for resetting the sawtooth core...
I personally have used the 2N5457 jfet with success, but I think the fet-type is really not important unless you really want a super high precision VCO.
m.o
PostPosted: Thu Sep 10, 2015 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the tip, indeed he used regular NPNs for reset, he has some more stuff going on there than I did;
First there is a LM311 dedicated comparator, which as I understand it has it's output as an "open collector" i.e. the collector of an npn (with the emitter internally routed to GND), and when the comparator triggers it's base is set high.
(Generally, I maybe should reconsider using such a dedicated comp., it seems quite popular)
Second there's the 3.3k resistor to V+ also one the base of the reset NPN...
Perhaps what is happening is:
The comparator is actually wired "inverted" so that while the saw-wave is rising, but below the trigger voltage, the output is shorting to ground - and thereby holding the base of the reset npn at zero (there will be a current running through the 3.3k into the comp. output).
Then when the saw-wave passes the comp trigger voltage, it will open it's input - no current flows to the comp output, so the base of the reset npn will go high...
... But why my circuit didn't work as expected I still can't say.
