Eurorack Power
Page 1 of 1 [3 Posts]
ArcaneDevice
PostPosted: Sun Aug 10, 2014 11:57 am    Post subject: Eurorack Power
Subject description: Power for tiny setup
I'm putting together maybe 4 Eurorack modules (Pittsburgh Modular mostly) in a tiny box for, well, pretty much noise music. I have used 2 - 12VDC adapters straight onto the power bus for such a purpose before with perfectly good results. But I get the sense that a lot of people will balk at this. Am I going far wrong? TIA.
PostPosted: Mon Aug 11, 2014 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
The easiest option would be a small power supply like the Micro Zeus:
http://www.tiptopaudio.com/zeusmicro.php
If you want to diy something, then you could make something similar to this:
http://electro-music.com/forum/phpbb-files/dual_supply_946.gif
Change the 5V regs for 7812 and 7812 (the large 1 amp package) and power it with a 9V AC adapter (NOTE: AC output - not DC).
It will be limited a bit by the current that the adapter can supply, so make sure that you get one that can supply enough for your modules.
ArcaneDevice
PostPosted: Wed Aug 13, 2014 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks C, ultimately just decided to go with a Pittsburgh Modular powered box. Not much more than the Zeus, getting a box together, wiring etc.
