<on air> Twyndyllyngs - Live in person Chez Mosc
Buchla VCO
Page 7 of 7 [162 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7
Snaper
PostPosted: Thu Aug 14, 2014 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
vladosh wrote:
Snaper you can use SSM2220 in the v/oct expo converter and use matched 2N3904 for the other as it's in the original Mark Verbos pdf somewhere on this thread if it isn't removed just gotta watch for the pinout ,thanks L1 for sharing the layout ,it is a great VCO ,i wonder what is the best choice for initial freq pot ,my 258 sounds great to me but the init freq pot can act bit weird when moving from zero ,and soldering those SMD isn't much of big deal ,they are really tiny , but it is actually easy once you try few times
Thanks for the info.
Can I use matched 3904 in both places with a tempco?
For me V/Oct tracking isnt that important :S
vladosh
PostPosted: Thu Aug 14, 2014 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
you can use 2N3906 for the other as it's a PNP ,but i'm not an expert really ,well matched transistors are well matched it's up to how good is your DMM and if you've made the Moog matching circuit or other and making it precise ,if you couple them thermally and all that ,i think it's not only about v/oct tracking.. match 2 x 2N3906 and try it ,i sourced those SMD somehow
cheers
Snaper
PostPosted: Mon Oct 20, 2014 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Did somebody built this?
I think I've wired wrong the switch...
No sound...just kind of "buzz", hum...and...weird...but it seems that I can receive local AM radios with this :S
Snaper
PostPosted: Mon Dec 15, 2014 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
My last silly question.
Is it possible to do a mod to avoid the switch?
I mean, Im ok with one waveform, but I think the cause of my not working modules are those damn switches. Hate them:)
thermionicjunky
PostPosted: Tue Dec 16, 2014 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
The switch is a mod. Simply install either the resistor values listed for saw or square in the schematic. And of course, infinite resistance means that no resistor is installed.
J3RK
PostPosted: Fri Dec 19, 2014 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I agree 100%. Ditch the switch. It's a nice idea, but the execution is very unreliable. Lifting resistor ends, and wiring a 3P switch... IMO it's not worth it. If you want both square and saw versions, I'd say it's easier to build both, one per PCB.
Snaper
PostPosted: Sun Dec 21, 2014 9:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see. I think I should buy 2 of your pcbs instead.
Have you some spare?
J3RK
PostPosted: Mon Dec 22, 2014 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Unfortunately I don't stock the 258J anymore. I believe Synthcube and Thonk should have some. (I send these to them every so often.) The reason for that is that I did the UltraFade VCO as a successor. It refines and fixes things, as well as provides more features. It's also a lot easier to build and wire. There's a thread on Muff's in the DIY forum, if you'd like to see more details on it.
FYI: In case my comment wasn't clear, my 258J boards still need to be modded in the same way if you want to add that waveform select switch. It still requires lifting the resistors, and using a 3 pole switch.
The UltraFade uses a different crossfade circuit, and only uses a simple SPDT switch for selecting the faded waveform.
akrearke
PostPosted: Sat Mar 14, 2015 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
does anyone have any idea on a low frequency setting for this vco? possibly increasing the .0047 uf capacitor in the core?
m.o
PostPosted: Sun Mar 15, 2015 9:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, that would seem like the first and best approach.
Possibly you could start messing with the expo converter currents, maybe increase the 1.5M resistor in the lower left beside the 3140...
J3RK
PostPosted: Mon Mar 16, 2015 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
You should have no problem doing this with a capacitor. What I would do is connect one lead of a 100nF cap to one lead of the 4.7nF cap. Then use an SPST switch between the other two ends. That way you can switch the low frequency cap in and out.
When they are connected in parallel the slower speed will occur. When you disconnect the 100nF cap, only the 4.7nF will be used.
It's not terribly critical which type of cap you use for the LFO cap. I'd still use something fairly stable though. MLCC, Styrene, Polypropylene or the like. (though even a standard ceramic or Polyester will be fine.)
Karlisss
PostPosted: Sat Aug 29, 2015 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can it run from 12v dual?
