Joshy
alkopop79
Posted: Thu May 02, 2013 12:23 pm Post subject:
I'm on Mac but I do appreciate your work! I was just recommending it to a friend and tried to find it on the Clavia site. Thank you! |
alkopop79
Posted: Thu May 02, 2013 12:25 pm Post subject:
Quote: | My intention here is not to spark any tension with Clavia or to break any rules. |
It's a legacy product anyway. |
Joshy
Posted: Thu May 02, 2013 2:12 pm Post subject:
alkopop79 wrote: | I'm on Mac but I do appreciate your work! I was just recommending it to a friend and tried to find it on the Clavia site. Thank you! |
Glad you enjoy it and hope your friend likes using it!
Even though the software is legacy I can still see Clavia going either way with it. |
Electromagnetic Wave
G2 patch files: 38
Posted: Thu May 02, 2013 9:04 pm Post subject:
Hi Joshy!
I tried it now. MIDI modules are not working. Audio In module receive a signal when I add one but I don't send nothing to it.
Quote: | the hope that Clavia would actually release a fully functioning modular software |
If this day come I wish it would be a software to use only with a specific sound card. Same as Access Virus do with a Digi or a Poco (use DSP, not CPU).
EDIT : I forget to say : Great work !!! |
secretkillerofnames
Posted: Fri May 03, 2013 8:35 pm Post subject:
Like!
*EDIT* FYI it works on OSX Mountain Lion under Crossover 12. Which means it probably works under Wine as well. |
Joshy
Posted: Sat May 11, 2013 8:49 am Post subject:
Quote: | I tried it now. MIDI modules are not working. Audio In module receive a signal when I add one but I don't send nothing to it. |
Thanks for testing the modules out, I'll take a look into it sometime!
And thanks to all, glad you've enjoyed it! |
iPassenger
Joined: Jan 27, 2007 Posts: 1067 Location: Sheffield, UK
G2 patch files: 78
iPassenger
G2 patch files: 78
Posted: Tue May 14, 2013 12:55 am Post subject:
Hope you can keep working on this, do you think you might be able to get the input modules working? I suspect this will be tricky as there isn't a function to set the inputs from within the software. _________________ iP (Ross)
Joshy
Posted: Sun May 26, 2013 3:01 pm Post subject:
iPassenger wrote: | Hope you can keep working on this, do you think you might be able to get the input modules working? I suspect this will be tricky as there isn't a function to set the inputs from within the software. |
Don't worry, I haven't forgotten about it. Just busy with a lot of other things.
I doubt I'll be able to get those modules working, but I haven't looked into yet. I'll check it out soon. |
BigShort
Posted: Fri May 31, 2013 4:09 pm Post subject:
thx for your beautyful patch and also big respect for your work |
Roland Kuit
Joined: Sep 29, 2003 Posts: 1090 Location: The Netherlands/Sweden
G2 patch files: 127
Posted: Sat Jun 01, 2013 1:36 am Post subject:
Great work! Thank you so much! |
ian92101
Posted: Sat Jul 06, 2013 12:36 pm Post subject:
MIDI Sync |
Congrats on the work done here! amazing!
Has anyone found a way to use it as a master clock or to slave it?
I think before any other work is done getting the midi sync to work should be the priority. That way, we can integrate the software into our setups more readily. I am tired of sampling...
What do you all think? |
varice
Audio files: 29
G2 patch files: 54
Posted: Sat Jul 06, 2013 9:48 pm Post subject:
Re: MIDI Sync |
to the electro-music forum ian92101
ian92101 wrote: | ...Has anyone found a way to use it as a master clock or to slave it?... |
I have never tested the MIDI clock function of the Demo Software myself, but there is an option under the Demo menu Synth; Synth Settings to set the MIDI options for Clock Send and Ignore External Clock. Have you tried setting those the way that you want? You would also need to set the Demo menu selection Setup; Audio/MIDI to the appropriate MIDI I/O port on the host computer.
It really is a shame that the MIDI output modules are disabled in the Demo. The MIDI note and control output processing power of the G2 hardware is very impressive. It’s too bad that the Demo can’t show that. _________________ varice |
gnohm
Posted: Tue Feb 11, 2014 9:34 am Post subject:
Is there some new things on this |
First of all what a great job u done here we are some guys that are super thrilled.
Was thinkin if u had made any new stuff on it
Boom gnohm |
calande
Posted: Mon Jul 14, 2014 5:12 am Post subject:
Thanks Josh for this great job!
I installed Nord Virtual Modular along with MIDI Yoke (a MIDI utility application), BOME's Mouse keyboard (a soft keyboard), and Cubase.
When I play Nord Virtual Modular with its embedded soft keyboard, it is smooth, no problem. Same with BOME's Mouse keyboard playing the notes in the Nord Virtual Modular, it's seamless. However, when I play notes in Cubase, even slowly, Nord Virtual Modular takes a long, long time to return the sound, like 1-3 seconds between each note.
MIDI Yoke is used to interface between Nord Virtual Modular and other MIDI applications. Any idea why this is so slow when played from Cubase?
Thanks! |
gnohm
Posted: Mon Jul 14, 2014 9:03 am Post subject:
i tried with the LoopBe virtual midi interface and also had latency big time tried after that to connect a cheap usb 1in/1out to my main midi interface and route that... and wham bam thank u mam no more latency |
calande
Posted: Mon Jul 14, 2014 9:27 am Post subject:
Thanks. It seems the culprit is MIDI-Yoke. Any idea to integrate Nord Virtual Modular as seamlessly as possible inside Cubase, with automation, preset recall, and so on? |
gnohm
Posted: Mon Jul 14, 2014 9:30 am Post subject:
I think those "virtual midi interfaces" is to slow... i will try see later if i can do something here and then i will let u know |
cappy2112
Joined: Dec 24, 2004 Posts: 2466 Location: San Jose, California
Posted: Sun Jul 27, 2014 10:11 pm Post subject:
Re: Nord Modular G2 Demo Subject description: Patched |
Joshy wrote: | Hi everyone,
I've installed Virtual Nord Modular on Crossover 13.2 on Mavericks 10.9.4
It runs OK, although I haven't tested all features, and I do hear audio.
I need to get more of the demo patches in that bottle, so i can test them. _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
uyoyu
Posted: Wed Aug 20, 2014 12:18 pm Post subject:
cappy2112 wrote: | Joshy wrote: | Hi everyone,
I need to get more of the demo patches in that bottle, so i can test them. |
How did you get your USB ports to work with crossover ? |
cappy2112
Posted: Wed Aug 20, 2014 1:16 pm Post subject:
uyoyu wrote: |
[/quote]
USB ports? The demo doesn't need USB _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
uyoyu
Posted: Wed Aug 20, 2014 1:45 pm Post subject:
Sorry, thought this was the open source editor thread |
calande
Posted: Thu Oct 16, 2014 6:35 am Post subject:
Hi there, I've had success using Cubase 7.5 with LoopBe1 and Nord Virtual Modular. Automation works also seamlessly
I had to disable LoopBe1 in the MIDI inputs of Cubase, though, to prevent a loopback.
I have one question: Do you know how to save the Audio & MIDI settings of Nord Virtual Modular? Every time I start it, these settings are reset |
3phase
G2 patch files: 141
Posted: Sat Nov 29, 2014 2:07 am Post subject:
so where are the benefits of this patch in relation to the original version? you can access the locked modules but they dont work? |
