limit on number of OSC addresses you can listen to?
Page 1 of 1 [16 Posts]
bens
PostPosted: Thu Aug 21, 2014 10:23 am    Post subject: limit on number of OSC addresses you can listen to? Reply with quote  Mark this post and the followings unread
I am working on some ChucK code using an Illucia dtr -- in short, I'm listening to six knobs, four buttons, and four toggle switches using OSC. I know the hardware is good, since I can get input from all 14 inputs using Max/MSP. My simple ChucK program only gets input from the first 12 addresses added, though -- is it possible there's a hard limit in the language?
Here's the code:
Code:
spork ~ inputs("Continuous", [1, 2, 3, 4, 5, 6]);
spork ~ inputs("Digital", [1, 2, 3, 4, 5, 6, 7, 8]);
while ( true ) {
    1::second => now;
fun void inputs(string type, int inputs[]) {
    OscIn oin;
    OscMsg msg;
    12001 => oin.port;
    for ( 0 => int i ; i < inputs.cap() ; i++ ) {
        <<< "/dtr/" + type + "/" + inputs[i] + ", f" >>>;
        oin.addAddress("/dtr/" + type + "/" + inputs[i] + ", f");
    float val;
    while (true) {
        oin => now;
        while ( oin.recv(msg) != 0 )
            msg.getFloat(0) => val;
            <<< type, val >>>;
        5::ms => now;
When I run the above code, I get data from knobs 1-6 and buttons/switches 1-6, but not switches 7 and 8. If I reverse the order of the sporks, I get data from buttons/switches 1-8 and knobs 1-4, but not knobs 5 and 6.
(By the way, I'm sporking only two instances of the function because I wondered if the problem were too many sporked functions. It would be better to spork a function for each input, so that I can identify which input is the source of a given OSC message.)
I'm fairly confident this doesn't have anything to do with the device; however, I think I'll try to write some test code that doesn't use it at all.
bens
PostPosted: Fri Aug 22, 2014 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, here's more information. The following code starts 16 OSC transmitters and 16 receivers. When you run it, you can see that transmitters 0-15 all transmit, but only receivers 0-11 receive.
Code:
for ( 0 => int i ; i < 16 ; i++ ) {
    spork ~ output(i);
    spork ~ input(i);
while ( true ) {
    1::second => now;
fun void output(int number) {
    12008 => int port;
    "localhost" => string hostname;
    OscOut xmit;
    xmit.dest(hostname, port);
    while (true) {
        Math.random2f(5.5, 8.5) => float wait;
        wait::second => now;
        xmit.start("/tester/what/" + number);
        Math.random2f(0.0, 1.0) => float temp => xmit.add;
        xmit.send();
        <<< "sent", number, temp >>>;
fun void input(int number) {
    OscIn oin;
    OscMsg msg;
    12008 => oin.port;
    oin.addAddress("/tester/what/" + number + ", f");
    float val;
    while (true) {
        oin => now;
            <<< "received", number, val >>>;
        5::ms => now;
By the way, should I be posting this to the chuck-users mailing list instead or in addition?
bens
PostPosted: Fri Aug 22, 2014 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Weird. I just ran the code from my second post again, and all listeners were operating. And then again, and the last four weren't. And then again, and all worked. And then again, and the last four didn't work. This is in miniAudicle.
Running "chuck --loop" and then adding this code seems to consistently produce the result of 16 transmitters and only 12 receivers.
PostPosted: Fri Aug 22, 2014 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't really help you with your issue (I don't have any device that sends on so many different OSC addresses), but I'm curious about the OscIn class that you are using. I've always used OscRecv myself, and that's what's used in the examples. Where can I find information about OscIn?
Also, it might (or might not) help to know what OS you are on.
Edit: sorry I quickly realize that all you have to do is write another program that sends, and that you have done just that. Will check it out.
bens
PostPosted: Fri Aug 22, 2014 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Antimon. I'm running ChucK 1.3.4.0 and miniAudicle 1.3.2 on Mavericks.
I'd noticed the different names for the OSC objects, too. I took my lead from the examples in the distribution, under File... Open Example... in miniAudicle.
PostPosted: Fri Aug 22, 2014 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, apparently I hadn't updated my ChucK installation Embarassed I updated and ran you second example and I am getting the faulty result you describe: no receive messages after sending on 11 and above:
Code:
sent 5 0.239300
received 5 0.239300
sent 15 0.954485
sent 4 0.022245
received 4 0.022245
sent 13 0.960307
sent 10 0.606250
received 10 0.606250
sent 6 0.249211
received 6 0.249211
sent 3 0.747775
received 3 0.747775
sent 9 0.320291
received 9 0.320291
sent 12 0.867480
sent 8 0.643842
sent 7 0.233511
received 8 0.643842
received 7 0.233511
sent 11 0.522583
received 11 0.522583
sent 0 0.223917
received 0 0.223917
sent 2 0.163471
received 2 0.163471
I wondered what the 5 ms wait was doing at the end of the receive loop, but removing it didn't help.
PostPosted: Fri Aug 22, 2014 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm thinking that there may be a bug in the new OscIn class. Googling around I found stuff like this:
https://lists.cs.princeton.edu/pipermail/chuck-users/2014-May/007609.html
Spencer Salazar is a guy working with implementing the language I think. If you want, you can report this as a bug to the ChucK mailing list:
https://lists.cs.princeton.edu/mailman/listinfo/chuck-users
Lately the developers have been fairly quick to notice bug reports there, and fix them.
In the meantime, you could try creating new instances of OscIn for each message you want to listen to (i.e. never call .addAddress() more than once for each OscIn instance). Not sure if that will help but it's worth a try.
Alternatively try to use the old OscRev class - luckily the exampes on the web page haven't yet been updated, so you can find them here:
http://chuck.cs.princeton.edu/doc/examples/
(the OSC examples are close to the bottom).
PostPosted: Fri Aug 22, 2014 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Incidentally, it took me a bit longer than I wanted to respond to this, because I got derailed looking at the Illucia dtr. A very interesting project!
bens
PostPosted: Fri Aug 22, 2014 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, isn't illucia cool?
Those are all good ideas -- thanks. I was wondering whether this or the mailing list would be the better place to ask -- I'll post over there, too.
jwmatthys
PostPosted: Fri Aug 22, 2014 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I posted a reply on the chuck list, but I'll comment here too. It appears that the limit of 12 is hard-coded into chuck. One of the devs may be willing to raise that number--I can see the value of allowing more than 12 listeners.
Just out of curiousity, have you tried with the older OscRecv methods?
bens
PostPosted: Fri Aug 22, 2014 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the response both here and there. I'm going to experiment with OscRecv next -- stay tuned.
bens
PostPosted: Fri Aug 22, 2014 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
The problem does not occur with OscRecv. All 16 listeners work when you replace the input() function with this one:
Code:
    OscRecv recv;
    12008 => recv.port;
    recv.listen();
    recv.event("/tester/what/" + number + ", f") @=> OscEvent oe;
    float val;
    while (true) {
        oe => now;
        while ( oe.nextMsg() != 0 )
            oe.getFloat() => val;
        5::ms => now;
bens
PostPosted: Fri Aug 22, 2014 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another approach I just found in Ajay Kapur, Perry Cook, Spencer Salazar & Ge Wang, Programming for Musicians and Digital Artists is
Code:
OscIn oin;
6449 => oin.port;
oin.listenAll();
I haven't tested this yet. (Now I have. It works fine.)
PostPosted: Sat Aug 23, 2014 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice to see that there is progress. Smile
PostPosted: Sat Oct 04, 2014 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I became inspired by you bens and got me an illucia of my own! :D Here's my first little test program that just allows you to connect jacks 12-15 to 0-3 (I get uneasy with 1-based indexes) and have them flash the leds. In this solution I could reuse the OscSend and OscRecv objects, meaning I don't open up lots of ports.
It would be interesting to see more of what you're using this fun little gadget for. :)
Code:
OscSend xmit;
xmit.setHost("localhost", 12000);
OscRecv orec;
12001 => orec.port;
orec.listen();
int i;
class ValueEvent extends Event {
   float value;
fun void sendToThing(string thing, int index, float state) {
   xmit.startMsg("/dtr/" + thing + "/" + (index+1), "f");
   state => xmit.addFloat;
fun void listenOnThing(string thing, int index, ValueEvent@ valueEvent) {
   orec.event("/dtr/" + thing + "/" + (index+1) + ",f") @=> OscEvent jackEvent;
   while (true) {
      jackEvent => now;
      <<< "Hup! ", index>>>;
      while (jackEvent.nextMsg() != 0) {
         jackEvent.getFloat() => valueEvent.value;
         valueEvent.signal();
fun void listenOnJack(int index) {
   new ValueEvent @=> ValueEvent @valueEvent;
   spork ~ listenOnThing("InputJack", index, valueEvent);
   while (true) {
      valueEvent => now;
      sendToThing("LED", index, valueEvent.value);
for (0 => i; i < 4; i++) {
   spork ~ listenOnJack(i);
fun void pulseJack(int index, dur on, dur off) {
   while (true) {
      sendToThing("OutputJack", index, 1.0);
      on => now;
      sendToThing("OutputJack", index, 0.0);
      off => now;
spork ~ pulseJack(12, 100::ms, 100::ms);
spork ~ pulseJack(13, 100::ms, 300::ms);
spork ~ pulseJack(14, 200::ms, 200::ms);
spork ~ pulseJack(15, 300::ms, 100::ms);
sendToThing("LED", 0, 1);
sendToThing("LED", 1, 0.8);
sendToThing("LED", 2, 0.4);
sendToThing("LED", 3, 0.2);
while (true) {
   1:: week => now;
bens
PostPosted: Sun Oct 05, 2014 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent! Congratulations! And thanks for the code.
I'd show you something new, except this project has taken a backseat to the modular obsession. What I'm planning for the Illucia and ChucK is a sonification of web and possibly other logs. At the moment, I think I'm going to set up the patchbay in Max; ChucK will handle the audio.
