DES
Posted: Fri Jan 09, 2015 8:52 am Post subject:
Alchemy no more... |
Looks like Camel Audio closed their doors and Alchemy Mobile is no longer available.... _________________ Dave
www.davesneed.com |
GovernorSilver
Joined: Apr 26, 2004 Posts: 1349 Location: Washington DC Metro
Posted: Fri Jan 09, 2015 11:39 am Post subject:
This was posted on the iPad Musician FB group by a member who got this reply from Camel - instructions on backing up your Alchemy stuff:
Quote: | We are currently working on a few ways to back up iOS libraries so that you'll be able to reinstall them in the future. For now, you can use a free desktop app called 'iFunbox'.
Note: Song files will need to be backed up separately via iCloud or Dropbox.
Backing up using iFunbox (http://www.i-funbox.com):
1) Connect your device to your computer
2) In iFunbox, expand 'User Applications' using the disclosure arrow (circled below)
3) Go to Alchemy / Library and drag and drop the 'Private Documents' folder to the backup location on your computer (in our example above, we've created a folder called 'iFunbox Backup'. This could take a few minutes depending on how many libraries you have saved on your iOS device
4) Next, highlight 'User Applications', to see a grid of your installed application icons.
5) Right click Alchemy and select 'Backup to .ipa package' -> 'Without Personal Data'
6) It makes sense to save it to the same place as the Private Documents folder.
Restoring Alchemy Mobile + Libraries From Backup Using iFunbox:
2) In iFunbox, select 'Install App' from the menu bar at the top of the window
3) Locate the .ipa file that iFunbox created when backing up the app
4) Double-click the .ipa file to install Alchemy to your device
5) Next, expand User Applications as above, and go to Alchemy/Library
6) Drag and drop the 'Private Documents' file across. If given the option to Replace or Merge, select 'Merge'. |
_________________ Current and recent work on Soundcloud
Some old stuff on VIRB |
DES
Posted: Fri Jan 16, 2015 7:01 am Post subject:
Has anyone been able to generate the .ipa package as mentioned in the directions? Doesn't work for me. Maybe an issue with iOS 8.1.2? Downloaded the latest i-funbox... _________________ Dave
www.davesneed.com |
