and70it
Posted: Wed Mar 02, 2005 4:38 am Post subject:
sequencer with note duration regulation |
hello, i have a problem with my g2x.
I want to build a sequencer with the same function of the arturia
moog modular. My seq work but in the MMV i can regulate the duration of the notes.
Can you help me?
Thanks
Andreas
P.s.: sorry about my bad english.  |
egw
Joined: Feb 01, 2003 Posts: 1506 Location: Asheville NC
G2 patch files: 8
Posted: Wed Mar 02, 2005 5:38 am Post subject:
Do you want one knob to regulate the length of all the notes,
or a separate control for each step in the sequence? |
and70it
Posted: Wed Mar 02, 2005 6:10 am Post subject:
I want one knob to regulate the length of all the notes, but also your second version is interesting.
Thanks
Andrea |
Rob
Joined: Mar 29, 2004 Posts: 578 Location: The Hague/Netherlands/EC
G2 patch files: 109
and70it
Posted: Wed Mar 02, 2005 8:27 am Post subject:
thanks
i will try it |
Sander_k
Joined: Jan 28, 2005 Posts: 53 Location: The Netherlands
G2 patch files: 8
Posted: Tue Mar 08, 2005 9:04 pm Post subject:
I haven't seen the patch yet, but i usually put a pulse module behind the sequencers output. This works great for controlling other synths!
(wow, Rob's patch is really useful ) |
cappy2112
Joined: Dec 24, 2004 Posts: 2106 Location: San Jose, California
Posted: Thu May 19, 2005 2:14 pm Post subject:
sequencer note lengths |
removed Last edited by cappy2112 on Thu May 19, 2005 3:17 pm; edited 1 time in total |
Joined: Jan 31, 2003 Posts: 17341 Location: Allentown, PA
Audio files: 107
Posted: Thu May 19, 2005 2:49 pm Post subject:
The original MOOG sequencer also had a jump button. It is a momentary push button (one for each stage) that would instantly jump the sequencer to that stage. Any way to hook that in? _________________ --Howard
my music and other stuff |
djfoxyfox
Joined: Feb 05, 2003 Posts: 774 Location: Nazareth, Pennsylvania, USA
Posted: Fri May 20, 2005 9:53 pm Post subject:
| Rob wrote: | | Here is one that has variable note length and the possibility to skip steps. Might be a starting point. | Where did this patch go? http://electro-music.com/forum/download.php?id=1737 seems to be missing!
Bill _________________ Bill Fox------------------|\--------------
--|_)| -----|-----()----------------------
-----------()----soundscapes.us/bill |
Audio files: 107
Posted: Sat May 21, 2005 8:08 am Post subject:
It's there, Bill. We were having a file server problem. There was a notice at the top of every forum page. _________________ --Howard
djfoxyfox
Posted: Sat May 21, 2005 8:33 am Post subject:
| mosc wrote: | | It's there, Bill. We were having a file server problem. There was a notice at the top of every forum page. | Thanks. I didn't notice the note until after I had made the post. BTW, how do I upload and under what conditions should I do so?
Cheers, _________________ Bill Fox------------------|\--------------
Audio files: 107
Posted: Sat May 21, 2005 11:04 am Post subject:
Use the "Add an Attachment" button (just above the "submit" button when posting a message to the forum. It works most of the time unless we are having technical problems. _________________ --Howard
djfoxyfox
Posted: Sat May 21, 2005 12:04 pm Post subject:
Do you like my new hat? I uploaded a photo of me wearing it as my new avatar. It goes quite well with my outfit, don't you think?  _________________ Bill Fox------------------|\--------------
Joined: Apr 03, 2004 Posts: 19620 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sat May 21, 2005 1:06 pm Post subject:
Ah of course it's the new hat, I thought you might have lost some pounds :-)
Jan. |
davep
Joined: Jul 05, 2004 Posts: 465 Location: Oakland, CA
Audio files: 10
G2 patch files: 73
Posted: Sat May 21, 2005 4:39 pm Post subject:
| djfoxyfox wrote: | Do you like my new hat? I uploaded a photo of me wearing it as my new avatar. It goes quite well with my outfit, don't you think?  |
Whoa. That is one creepy avatar, Bill. Say 'hi' to Dr. Moreau for me  _________________ Dave Peck |
Audio files: 107
Posted: Mon Aug 22, 2005 9:21 am Post subject:
Talking about avatars on the forum is pointless unless you copy the avatar into the post. Reason: when a user changes the avatar, it is changed everywhere.
Also Gomidas posted a request to have this for the NM Classic. That topic is here http://electro-music.com/forum/topic-5476.html _________________ --Howard
dasz
Joined: Oct 16, 2004 Posts: 1624 Location: vancouver, canada
Audio files: 29
G2 patch files: 56
Posted: Mon Aug 22, 2005 8:01 pm Post subject:
Gate sequencer |
One very useful module (which is patchable currently but not very elegant, and not 100% perfect) is a clocked gate module.
It holds a gate for n clock cycles. has a reset and a modulation input & with depth and gate hold time knob (0..127 cycles). output is gate
right now this involves using a clock divider modulated via midi assign. the modulation source. the clock divide is inverted and is used to hold the sample (S/H module).
The flaw is that all notes (if they occur more frequently than their duration), are held. But in this case I use a 2nd sequencer (usually seq#2 from event sequencer) as my switch as an envelope reset.
But blast it, the clocked gate opens (no pun intended) a world of fun and happiness. As does my recent Arctic proprietary sequencer design.
/dasz _________________ http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/ |
Posted: Tue Aug 23, 2005 5:10 am Post subject:
What do you need the second sequencer for? You could have each note reset the clock devider and have a pulse on the trigger out break the gate for a sample length.
If you know ahead what length notes will have you can also implement a little polyphony engine and be rid of that problem altogether. _________________ Kassen |
dasz
Audio files: 29
G2 patch files: 56
Posted: Tue Aug 23, 2005 10:11 am Post subject:
Unless I'm missing something I think that could be done more efficiently with one sequencer in trigger mode and some logic pulse/edge delay trickery. That might not be more efficient zero-page-wise but it'd be far more convenient to program. _________________ Kassen |
dasz
Audio files: 29
G2 patch files: 56
Posted: Tue Aug 23, 2005 1:34 pm Post subject:
Kassen, everyone's setup is different.
Due to my RSI (repetitive stress injury , and mousing is a pain for me, literally) I do not get enough patching time (I'ma G2 panel surfer) to nail all my designs dead on, thus my designs have certain sideeffects (aka features).
These side effects are where the magic happens.
One day I hope to get enough patching time, but until then, I can only gather ideas, concepts and prototypes.
I think your point initally was that some of the modules in the clocked gate are not necessary, and maybe I missed your point (as I was referring to my implementation).
/Dasz _________________ http://www.clavia.se/misc/users/daszgarncarz.htm
