Electromagnetic Wave
G2 patch files: 38
Posted: Sun Dec 07, 2014 11:52 am Post subject:
Hi Joshy,
What did you used to see the code and to make these changes? Are you working directly with the .exe with something as Reshacker? Or you decompile and recompile the code with a tool ? |
bananabreadman
Joined: Feb 15, 2015 Posts: 6 Location: Hamilton Ontario
Posted: Sun Feb 15, 2015 1:15 pm Post subject:
Virtual Modular on Bootcamp :) |
Joshy:
Your Virtual G2, with the unlocked modules, is a blessing. It works very well in Windows 7 on Bootcamp. The audio playback is coming through my M-Audio Firewire 410.Any improvements you decide to make would be most welcome! Especially, how to increase the Patch Load capacity. In Windows 7 / Bootcamp on my Intel i7 MacBookPro, the Patch Load maxes out when the CPU Load has only reached about 30%.
Steve Last edited by bananabreadman on Thu Feb 19, 2015 1:56 pm; edited 2 times in total |
Joined: Jan 31, 2003 Posts: 18197 Location: Durham, NC
Audio files: 212
Posted: Sun Feb 15, 2015 4:10 pm Post subject:
bananabreadman
Great to have you here. _________________ --Howard
my music and other stuff |
madmoments
Posted: Sun Apr 26, 2015 9:20 am Post subject:
thank you so much!!! |
calande
Posted: Sat May 02, 2015 3:50 am Post subject:
It works like a charm with Cubase and LoopBe1 in-between, but having to load everything each time I start Cubase is a pain, and time-consuming...Do you think it could be possible to embed Nord Virtual Modular in an application seen by Cubase as a VSTI? (e.g. nordmodular_loader.dll) This way, when you load your track, Nord Virtual Modular is loaded automatically, with the right patch, and with the right knob positions. That would be a great milestone! Thanks. |
monobass
G2 patch files: 12
Posted: Sun Jun 07, 2015 11:00 am Post subject:
Has anyone got this working via Wine in OSX? Someone kindly gave me a 'Wine Bottle' version which they are running fine... but I can't get it to run, it asks me if I want to check for updates on boot.. but whatever I select it then basically just freezes and quits.
Apparently it's the demo version 1.4, the .app was created on 27th Dec 2013 _________________ Steve |
monobass
G2 patch files: 12
Posted: Sun Jun 07, 2015 11:20 am Post subject:
ok nothing to see here... I got Joshys version as attached running fine in the full version of Wine (rather than the 'bottled' version) _________________ Steve |
marioisaac
Posted: Fri Feb 05, 2016 12:23 pm Post subject:
Is there a new release for this? Any update? I would love to try it |
Audio files: 212
Posted: Mon Feb 08, 2016 11:03 am Post subject:
There is no new release AFAIK. Try it anyway. _________________ --Howard
marioisaac
Posted: Mon Feb 08, 2016 2:48 pm Post subject:
I did try it, and use it already.
The MIDI Modules work, but the others don't .
Would be cool to enable the Audio IN, and use the G2 as an FX Processor
Anyway, there is still a lot to experiment within the "Monophonic limitations" of the G2, so that will keep me busy for a while
Although I don't lose hope to someday be able to use it as an FX Processor |
Audio files: 212
Posted: Tue Feb 09, 2016 3:42 pm Post subject:
If I remember correctly, the audio input function never worked on the demo. _________________ --Howard
marioisaac
Posted: Wed Feb 10, 2016 9:27 am Post subject:
That is correct.
In my previous post I was refering to the hacked version.
The only difference between the Demo and this hacked version, is that the MIDI Modules work on the hacked version. |
docsample
Posted: Tue Feb 23, 2016 5:57 pm Post subject:
awesome, thanks for this and hope you continue to hack this!! |
Yot
Posted: Wed Jan 18, 2017 10:40 am Post subject:
EDIT :
I made bottled wine versions of the official Nord G2 Demo and the Nord Virtual Modular modified by Joshy that both work on OSX. You don't need to install bootcamp or any virtual OS. No need to install anything.
It contains all the Wine binaries so the app can run without prior install of Wine.
Get them here (scroll down under the G1 Editor, then Nord G2 Demo, then Nord Virtual Modular by Joshy)
http://www.stage-engine.com/micro-modular-1/
Enjoy! |
indigenous
Posted: Thu Apr 27, 2017 12:26 pm Post subject:
Not enough memory to perform requested action |
Hi JP
I was hoping someone might do this one day. I contacted Clavia years ago and suggested they release a VST/AU version of the G2 given it was out of production. They where pretty snobby about it and said 'we only make hardware synthesizers' to which i replied, DSP is hardly a hardware synth, given it is all software...
I was hoping to get this working, but it pops up an error message:
"Not enough memory to perform requested action"
When selecting the MIDI/Audio options in the menu...
Any idea what is wrong?
K |
nuts
Posted: Sun Feb 11, 2018 1:34 pm Post subject:
Re: Not enough memory to perform requested action |
indigenous wrote: |
K |
Same here, i even got this message when i open the software.
I'm running an old dual core PC with 2gb of ram, out of specs maybe ?
Please, if someone can help that would be great. |
tomhall
Posted: Sat Apr 07, 2018 12:21 pm Post subject:
seems that the DX modules aren't working |
pajzd
Redline
Posted: Mon Sep 19, 2022 4:12 am Post subject:
Yot wrote: | EDIT :
Should the Audio In work on this? Or was that never actually working in the original demo version?
The bottled version works fine but the Audio In emits a high pitched signal with nothing going into my soundcard, just wondered that was to be expected? |
cebec
G2 patch files: 31
Posted: Wed Sep 21, 2022 5:41 am Post subject:
Hi -- As far as I can recall, Audio In was never enabled in the G2 Demo. _________________ http://www.soundcloud.com/cebec |
