FS: Macumbista Benjolin V3 2015
Page 1 of 1 [2 Posts]
macumbista
PostPosted: Thu Mar 26, 2015 11:55 am    Post subject: FS: Macumbista Benjolin V3 2015 Reply with quote  Mark this post and the followings unread
Invite a little chaos into your life!
This handmade Macumbista Benjolin is for sale as of today. Price is EUR 495 (incl. 19% EU VAT) / EUR 416 (shipped outside the EU) plus registered+insured shipping from Berlin DE.
My Benjolins are produced under licensed agreement with Rob Hordijk. They have been further customized with a patchbay, which can be used to interface with other modular synthesizers or to setup further control voltage feedback systems within the Benjolin itself, attenuators on the three control voltage input and LEDs displaying the internal state of the Rungler.
You can watch a short demo of two of these Benjolins in action here:
http://vimeo.com/70111383
Complete information on the Macumbista Benjolins can be found here:
http://macumbista.net/?p=3935
macumbista.net
macumbista
PostPosted: Fri Mar 27, 2015 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
The patchbay of these Benjolins has banana jack connections for the square and triangle waveforms of each of the two oscillators, the Pulse Width Modulation output of the two oscillators, the Rungler output, the XOR (exclusive/or) logic operation of the two oscillators and the output of the filter.
There are also banana jack control voltage inputs with attenuators for the frequency of each of the two oscillators and the filter cutoff frequency. The layout of the panel is designed to be both intuitive and playable (unlike many EuroRack modules, for example…). And finally, the three output bits of the Rungler have been visualized with red, green and blue LEDs.
All Benjolins use a Neutrik 6.3mm (1/4″) output jack (two in the case of the Butterfly Benjolin), an additional GROUND banana jack to interface with other modular systems and a 12 VAC “wall wart” power supply (mainland European and North American versions available).
macumbista.net
