  Twyndyllyngs Live - postponed until tomorrow, sorry. (Dental pain) ;-( Chez Mosc
 Forum index » DIY Hardware and Software » Rob Hordijk DIY Designs
Zeitgeist Schematics
Post new topic   Reply to topic Moderators: Rob
Page 1 of 2 [32 Posts]
electri-fire
G2 patch files: 4
PostPosted: Wed Nov 25, 2009 9:48 am    Post subject: Zeitgeist Schematics Reply with quote  Mark this post and the followings unread
I asked for the Zeitgeist schematics, but....
Edit: I just remembered Rob mailed them to me. As he also posted the Benjolin schematics I presume he won't mind me posting the Zeitgeist.
 Filesize:  111.69 KB
 Viewed:  1783 Time(s)
 Filesize:  72.5 KB
 Viewed:  1021 Time(s)
ZeitgeistSchematic.pdf
 Filename:  ZeitgeistSchematic.pdf
 Filesize:  34.07 KB
 Downloaded:  2735 Time(s)
Ginsengbob
PostPosted: Mon Jul 04, 2011 12:59 pm    Post subject: This May be a stupid question but...... Reply with quote  Mark this post and the followings unread
How can you use the board graphic for making a pcb when it's got the component graphics on it like that?
Thanks
CJ Miller
PostPosted: Thu Mar 15, 2012 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I noticed a small error on the schematic diagram. It has C9 - pin 9 on the delay chip - as 9100nF. Looking at the overlay and photo here it appears that the extra 9 is a typo, it should probably be 100nF.
Ginsengbob
PostPosted: Fri Mar 16, 2012 10:43 am    Post subject: Seriously Reply with quote  Mark this post and the followings unread
On the Benjolin post there is a graphic with the components and a graphic for using a transfer with no components to print on the transfer paper.
Is there something I'm missing?
Please tell me.
Thanks
PickNick
PostPosted: Sun Mar 18, 2012 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
i'm still not sure what kind of regulator is 1702...
mcp1702?
can i use 7805?
Allow theex.nl
inlifeindeath
PostPosted: Sun Mar 18, 2012 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
mcp1702?
can i use 7805?
yes, it's just a 5v line for the delay chip. 7805 work fine.
PickNick
PostPosted: Mon Mar 19, 2012 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
great news!
thanks mate!
Allow theex.nl
tokyomatik
Audio files: 6
PostPosted: Tue Apr 23, 2013 8:28 pm    Post subject: Re: Seriously Reply with quote  Mark this post and the followings unread
Please tell me.
Thanks
so? no pnp transfer layout?? Sad
xiwi
PostPosted: Sat May 18, 2013 6:59 pm    Post subject: Re: Seriously Reply with quote  Mark this post and the followings unread
Please tell me.
Thanks
This might be sacrilege, but I'm currently working on an alternate PCB layout for the Zeitgeist with external pots and jacks. Here's an image. Not making it fully available yet, as I haven't had the time to confirm that it's working perfectly.
http://imgur.com/1TLzkLx
tokyomatik
Audio files: 6
PostPosted: Sat May 18, 2013 7:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
i already feel better Cool
Dogenigt
PostPosted: Sun May 26, 2013 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi can anyone tell me what these potentiometers on Rob's board is called? I often need ones this size!
And can anyone explain the 10 pin connector for the jumper if I wanted to make one myself?
www.dogenigt.com
Everything should be made as simple as possible, but no simpler. - Albert Einstein
LFLab
PostPosted: Sun Jun 02, 2013 1:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Those are 9mm pots, several manufacturers make them, Alpha too.
Just need to specify that you want vertical mount.
boundlessFX
PostPosted: Tue Jun 11, 2013 12:20 am    Post subject: n00b question Reply with quote  Mark this post and the followings unread
What exactly are the components labeled "HDR_3"? I recognize everything else and have most of it on hand, but I've never seen these before. Are they some type of transistor?
inlifeindeath
PostPosted: Tue Jun 11, 2013 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
They are headers, you can just use hookup wire.
boundlessFX
PostPosted: Wed Jun 12, 2013 6:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome. Thanks!
jmejia
PostPosted: Wed Jul 10, 2013 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Could someone describe what this circuit does? I'm having trouble finding a good description anywhere. I found a video - but it doesn't go into much detail...
inlifeindeath
PostPosted: Thu Jul 11, 2013 1:04 am    Post subject: Reply with quote  Mark this post and the followings unread
It's a delay circuit
jmejia
PostPosted: Thu Jul 11, 2013 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I know it's a delay circuit, I'm familiar with the pt2399. I was assuming this does more or is interesting or different than the other 2399 schematics floating around...?
robboten
PostPosted: Tue Aug 13, 2013 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Hows the new board layout coming along. Am curious and have a couple of 2399 laying here waiting... Wink
And also... was the "old" pcb layout with pots but without components ever released?
SteveBull
PostPosted: Sun Nov 30, 2014 7:38 pm    Post subject: power requirements of Zeitgeist and Benjolin
Subject description: what are the specifications
I've built both the Zeitgeist and Benjolin at a Harvestworks workshop years ago and now I want to fire them up again - - but I can not find the power supply. Please remind of the circuit specifications. It looks like the Benjolin wants two: v+ and a v- DC referenced to a common ground and the Zeitgeist only one v+ DC to ground. I see I have a 5 pin female DIN power connector on my chassis converted from a Sears/Craftsman tool case.
Thanks,
Steve
tokyomatik
Audio files: 6
PostPosted: Tue Apr 21, 2015 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
ehm.....anybody has the pnp transfer file for the pcb on the first post here??
tokyomatik
Audio files: 6
PostPosted: Tue Apr 21, 2015 3:23 am    Post subject: Re: Zeitgeist Schematics Reply with quote  Mark this post and the followings unread
sorry to push again, but if Rob sent u the files to build your own Zeitgeist....why u posted only schematics and parts placement and no layout for pnp transfer??...It's like an invitation for dinner with no food on the table.... Shocked
fluxmonkey
PostPosted: Tue Apr 21, 2015 10:02 am    Post subject: Re: Zeitgeist Schematics Reply with quote  Mark this post and the followings unread
it's not hard to edit the posted jpg to remove the parts outline and leave just the copper. this is DIY, afterall Laughing
b
www.fluxmonkey.com
tokyomatik
Audio files: 6
PostPosted: Thu May 07, 2015 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm checking the board with the components and I have some questions:
what are the pots function names?? (from left to right)
the CV input is to control the delay time?
what is SENSOR doing?(HDR 10)
what are the functions of JUMPER and the two HDR 3? jumpers for a different settings ?
the JUMPER next to the led says + and -, should I consider - as Ground??
I will try to etch this board in these days, not so many parts and looks also an easy build...any recomendation?
tokyomatik
Audio files: 6
PostPosted: Sat May 16, 2015 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Anybody there??
Were my questions too stupid to answer?? too much coffee
