CA3080 on ebay
Page 1 of 1 [21 Posts]
LektroiD
PostPosted: Fri Feb 10, 2012 8:38 am    Post subject: CA3080 on ebay
Subject description: ..are these fakes?
I ordered some CA3080E ICs from ebay in anticipation of a new project.
However, in the photo was a Harris IC, but what arrived wasn't. I don't know how to test these without building the next project, but the PCBs haven't even been manufactured yet.
Below are photos of the IC advertised and the ones that arrived.
the seller "vila_restor" has 100% feedback, but in the comments only people are saying how the delivery times were good, nothing about the actual product functionality.
I know he's a UK seller, but I'm wondering if he bought a stock batch from china and selling them on. These are certainly not the Harris ones advertised.
The current stock is Harris branded.
...unless Harris logo changed to a letter 'i'
Has anyone else had experience with this seller?
Seller's photo of Harris CA3080E
 Filesize:  38.2 KB
 Viewed:  23717 Time(s)
My photo of what actually arrived
 Filesize:  2.02 MB
 Viewed:  419 Time(s)
LektroiD
PostPosted: Fri Feb 10, 2012 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I found a photo of an intersil (which is what the logo appears to be on the chips that arrived). However, it looks quite different...
J3RK
PostPosted: Fri Feb 10, 2012 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
That's the Intersil logo, which is who owned this design after Harris. I believe there is one more rev (visually) out there as well, but can't remember off the top of my head. That doesn't guarantee that they're good, but this is a proper part/logo. I have both of these types (Intersil/Harris) DIP package versions. There is also a metal can type, but I'm not sure what the markings on those are.
Edit: I see what you mean on the difference between the Intersil logos in those photos. I can take a look at what I have when I get home from work tonight, and tell you what mine look like.
frijitz
Audio files: 54
PostPosted: Fri Feb 10, 2012 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I believe the logo is an "H". Looks exactly like some I have.
Ian
forshee
PostPosted: Fri Feb 10, 2012 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got a few off ebay a few months ago. They were marked Harris and were DOA or fake. But to their credit they sent a new batch of chips with the Intersil marking and they seemed to work great.
I wouldn't be overly concerned about the graphics not looking exactly the same. My guess is that the silk screening is pretty easy to fake anyway. Breadboard something and see if it works. Smallbear sells them too by the way I think I'll go that route next time just to avoid the hassle. Good luck.
JingleJoe
PostPosted: Sat Feb 11, 2012 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I have a handful of archaic chips and there are vast differences between logos for the same company and the text.
As advised by forshee, test them to see.
LFLab
PostPosted: Sun Feb 12, 2012 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
is there a simple circuit to test these? or just whip up a vca and test them "in situ"?
roman_f
PostPosted: Thu Feb 16, 2012 1:58 am    Post subject: Reply with quote  Mark this post and the followings unread
i buy my CA3080s here and thy work perfect
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170586865706#ht_2743wt_1216
i think i had only 1 faulty in a pack of 50
but not fake
forshee
PostPosted: Thu Feb 16, 2012 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
There are a bunch app notes in the data sheet if I recall. Otherwise just drop in anything you have socketed.
magman
PostPosted: Sun Feb 19, 2012 6:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I had a suspicion that I have also been recently supplied with some fake Harris CA3080E's so today I built a test circuit on my breadboard that I found from one of the Elektor Formant articles (Actually the 24dB VCF, as this works best with 4 matched 3080's).
The circuit works great, but I appear to have been supplied with 30 fakes from what I had hoped was a reputable supplier (I've dropped them a note to see how they will respond to this issue, so I won't name them at present).
I'm going to knock up a Veroboard version of this test circuit, as I expect it will be very useful in the future. I'll post it on here once I've worked it out, but check out the Elektor article if you want to test your own IC's more quickly (It was in the Elektor Formant book that is available from a few sources on the web)
Regards
Magman
magman
PostPosted: Sun Feb 19, 2012 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, here goes with a first draft of the OTA Tester on Veroboard.
I've only just drawn this, I will be building it and testing it later.
The Original text from the Elektor Article is as follows:
A test circuit for OTA's is attached. This should be fed with a sinewave of about 2V peak-to-peak (or 0.7V measured on an AC Voltmeter) from a signal generator or from one of the VCO's. The output should be monitored on a 'scope or AC Voltmeter. With a control current of 100uA, measured on the multimeter in series with R5, the output voltage should be between 0.7V and 1.3V peak-to-peak.
The circuit can also be used to check the linearity of the transconductance v.control current characteristics of the OTA's, e.g. doubling the control current should double the output of the test circuit and halving the test current should halve the output.
A few issues I found when testing this on my breadboard is that most of my multimeters don't actually measure down to 10's of uA, so you may have to be a little less precise in this measurement depending on your meters. Also, I was able to test this with a multimeter and a scope, but if you haven't got a scope you are likely to need 2 meters, as the uA meter needs to stay in-circuit for the tests. This uA meter connection is also quite critical, if you don't have a good connection here, the circuit won't work.
Last but no means least, you can mount VR1 off board if you want. I actually used a 15-turn preset here, for a degree of precision when setting the test current, though this was a little slow to change when testing the linearity.
Hope you find this useful.
Magman
Veroboard layout for Elektor OTA Tester
 Filesize:  18.22 KB
 Viewed:  1054 Time(s)
hexadec
PostPosted: Sat May 16, 2015 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hellooooo Very Happy
I know this is an old thread but I came here and fell for it so I thought I'd make sure no one else does...
The ICs shown above are reversed (IC1 should be the OTA under test and IC2 the 741/071).
Other than that the circuit layout works fine.
Been lurking here for a while now so hi everyone Smile
LFLab
PostPosted: Tue May 19, 2015 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Welcome and thanks for the good tip!
I bought a bunch of them on eBay in Germany, and one of them didn't work in a circuit I built (can't remember which circuit), plugged in another one (I got a bunch of old stock items from a colleague of mine Very Happy ), and it worked.
Been sitting on those 20 odd 3080's ever since meaning to either chuck them or test them. Maybe one of these days.
hexadec
PostPosted: Tue May 19, 2015 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the welcome mate.
I think I've been quite lucky...I've bought quite a few from China and so far they all work and are not fakes. Very Happy
magman
PostPosted: Sun Jun 14, 2015 11:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for spotting this Embarassed
To be honest, I never got round to building this, I just left the circuit on one of my breadboards.
I have managed to accumulate a stock of good 3080's though. In fact I might give some of them as a raffle prize for the next Synth DIY meeting in Cambridge next month.
All the best
Magman
hexadec
PostPosted: Mon Jun 15, 2015 12:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I did...it works great Laughing
You can buy CA3080s in an SOP8 package from China cheap as errrr chips... Rolling Eyes (about 0.13p each)
...or you can buy DIP8 versions for about 0.65p each.
Just the usual problem of waiting for a month before you get them.
jurekprzezdziecki
PostPosted: Thu Dec 12, 2019 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I had some issues with 3080s bought on eBay. 2 faulted and few hours of the testing circuit to find it. Will do the test circuit for sure before I will plug the IC next time.
hexadec
PostPosted: Thu Dec 12, 2019 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I always buy from Aliexpress. They are usually cheaper and I really have had no problems with 100s of orders. It's just the wait for deliveries that can be a problem if you're impatient like me. Very Happy
PostPosted: Thu Dec 12, 2019 9:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another option is to wire up half a LM13700.
vladosh
Audio files: 46
PostPosted: Fri Dec 13, 2019 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
i got CA3080 from Ali in smd and TH and both work fine ,also some PT delay chips, LM4250 and so on..never had an issue
PostPosted: Fri Dec 13, 2019 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
My understanding is that Ali is a bit like Amazon or Ebay -- many vendors, all operating under one website. So, different vendors have differing reliability.
