Cool PCB making stuff?
Page 1 of 2 [38 Posts]
PostPosted: Tue May 24, 2005 1:13 pm    Post subject: Cool PCB making stuff? Reply with quote  Mark this post and the followings unread
I've pretty much had it with trying to make pcb's with a UV lightbox, and messing around with trying to get a decent opaque black out of a photocopier loaded with acetate.
I've seen this stuff on the net;
http://www.maplin.co.uk/module.aspx?ModuleNo=13464&doy=18m5
Has anyone had any experience with this stuff? I'd be very interested to know.
Tom
Audio files: 116
G2 patch files: 317
PostPosted: Tue May 24, 2005 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Making a decent film (or transparent, or what's it called in english) has always been the greatest problem in making my own PCB's - I actually liked the rest of the process with the light and the chemicals.
For films I used to go to a printer having a technical camera (not a print shop, but a real offset printer), for just a bit of money I got perfect films from laserjet printed paper output.
But the product you mention seems to be a real timesaver - makes me curious as well as to how good it is !
Jan.
Audio files: 107
PostPosted: Tue May 24, 2005 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks like you could make Tee-shirts with that system too. Laughing
ladislaobiro
PostPosted: Tue May 24, 2005 11:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
...and front panels as well.
Paul usually makes his own PCB with P'n'P sheets, and he says they work pretty good.
ladislao
PostPosted: Wed May 25, 2005 6:43 am    Post subject: Reply with quote  Mark this post and the followings unread
here, I found this link to the grand 'ol US of A
It's got pictures- hooray!
http://www.techniks.com/how_to.htm
Wild Zebra
PostPosted: Wed May 25, 2005 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I use PnP on mostly all my stompboxes. It works very well.
www.tonepad.com has a great photo essay on both using the PnP
to make a borad and then etching the board via ferric chloride. I
here a lot of people using the same method with glossy photo paper.
I highly recommend the PnP you can get it by the sheet at
small bear electronics
word
"your stripes are killer bro"
jksuperstar
G2 patch files: 18
PostPosted: Wed May 25, 2005 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I've used this with mixed success..but I was using "older" sheets that had sat on a shelf (after ironing, I had to double over some areas with a black marker, then after etching had to re-inforce some areas with solder/jumper wires...but it wasn't painful at all). Note: You probably don't want to use this method for a double sided board that has more than a handful of vias/thru-holes.
If you have access to a laser printer, I've heard of a different trick. Just use "Glossy Photo Paper", intended for use in bubble jets. You still use a laser jet printer though. The whole idea is that the p'n'p paper doesn't allow the laser jet ink to bind to the paper, so when you re-heat it (iron on) to a copper board, it binds then. The glossy photo-paper has a wax coating, just like the "real" p'n'p paper, that prevents the ink from binding to the paper.
In my house, at least, this glossy photo paper is more readily available than P'n'P, so the next board I do I'll try this method and report in.
Whatever you do, please post your experience here or in the "DIY" section of the forum!!
PostPosted: Wed May 25, 2005 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jan.
Jan,
I've just bought a pack- I'll post the results when I'm done (oh I wish I had a laser jet printer!). In the meantime I'll contact the makers (who don't seem to have a web address- which is a bit strange in this day and age), and find out if I can get a supplier in the netherlands for you.
PS you still have to etch the board- so there are still chemicals and watching your photo develop!
Tom
PostPosted: Wed May 25, 2005 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please do. this is fascinating!
Tom
jksuperstar
G2 patch files: 18
PostPosted: Wed May 25, 2005 6:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
The same toner is used in most photocopy machines (ala Kinko's, etc). So for 10cents/copy, you probably do have access Smile
I'd print a page first, make sure your components fit nicely (just in case a print driver decided to scale things!) then go make some copies/laser prints.
-jk*
PostPosted: Thu May 26, 2005 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
jksuperstar wrote:
The same toner is used in most photocopy machines (ala Kinko's, etc). So for 10cents/copy, you probably do have access :)
-jk*
hmm- you haven't seen the dodgy photocopiers round here! Finding a decent copier round here with toner carts that haven't been filled with gravy is hard work ;)
It sounds nice and simple- I'll give this one a go!
Tom
PostPosted: Sat Jun 18, 2005 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone tried this yet? I suppose >I< really should- now I've wasted so much money on this p'n'p stuff.
Got the p'n'p stuff back from the printers yesterday- the amount of bloody money I've just spent, I could have bought my own cheap laser printer Twisted Evil
So what mistakes have I learn't from p'n'p? Well we'll find out tonight after I've etched a board, but for some wierd reason the gif's I got from mfos are full of tiny holes which is not very good. Perhaps it's because they are 72dpi from the web?
With all those holes to be drilled afterwards, I'm beginning to wish that I had just spent the money buying some boards from Ray in the first place (and waiting 6 weeks for them to arrive!)
Will keep you all up to date on my progress Smile
Tom
PS It's f**king hot here right now. Touching on 32 degrees Celsius here in Brum- looking forward to the forecasted storms tomorrow Smile
ACHTUNG!
PostPosted: Sat Jun 18, 2005 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
here are are some photos of my 'iron-on press n peel experience'.
As you can see from the first, the transfer is pretty crap. This image you see here is infact two layers one on top of the other because the first layer was so terrible. It's improved but not much.
The second is a close up
The third is a photo through the film. I don't think it should look like this. This was the gif taken directly from mfos which was uploaded to quarkxpress and printed off. It's at 72dpi (I seem to remember seeing something about this on Ray's site- I might ask him for a 300dpi copy).
I've also done another print from intaglio at 300 dpi for my wp20 board and the black is really solid there. Perhaps its a resolution thing and is showing up the shortcomings of the pcb design software? I'm gonna email Ray on this one.
ACHTUNG!
PostPosted: Sat Jun 18, 2005 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why has that loaded twice? Don't get this website attachment system.
 Filesize:  323.72 KB
 Viewed:  6003 Time(s)
ACHTUNG!
PostPosted: Sat Jun 18, 2005 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
and the 3rd (most important! -Should this be an opaque black?)
 Filesize:  386.93 KB
 Viewed:  6000 Time(s)
ACHTUNG!
Audio files: 116
G2 patch files: 317
PostPosted: Sat Jun 18, 2005 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Preferably yes of course, but that doesn't seem to be your only problem - the transfer sucks as well.
A while ago I saw better results on some website that I forgot to bookmark .... so this is more hairy than one would expect I guess, damn ...
I'll remove your duplicate attachment, I'll try :-)
Jan.
PostPosted: Sat Jun 18, 2005 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jan.
It looks like you've removed both images Jan. But you're right- the transfer is utter shite.
I'm gonna have to wait until the printer opens on monday to see what can be done. It would also be great if I never threw out that dry mount heat press that I used to own (for black and white prints)- doh!
ACHTUNG!
Audio files: 116
G2 patch files: 317
PostPosted: Sat Jun 18, 2005 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm very sorry about that Tom, it didn't look that way at first, I don't get it. It looked Ok at first, but not anymore. This user interface is not the most intuitive one 've seen around.
What I remember from the website (the one I didn't bookmark) the transfer part was rather tricky, with first absolutely getting rid of all dirt and fatty stuff, but also pre-heating the PCB and what not.
BTW you can always go in and edit your 'old' message including any attachments.
Sorry again for the mess I made.
Jan.
PostPosted: Sun Jun 19, 2005 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
you're right there- it isn't. I can't work out how to add more than one attachment. The explanation and instructions of how to is gobbledegook.
Mess? Its not your fault :)
Must post in plain text. Really must! I dislike these html emoticons- or whatever they are called- I find them really cheesie (the even look like baby-bel's!!)
ACHTUNG!
PostPosted: Sun Jun 19, 2005 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
here's that first image again;
 Filesize:  333.23 KB
 Viewed:  5969 Time(s)
ACHTUNG!
Audio files: 116
G2 patch files: 317
PostPosted: Sun Jun 19, 2005 7:03 am    Post subject: Reply with quote  Mark this post and the followings unread
In principle by keeping clicking on "Add an attachment", I think I always use the topmost "add an attachment", ignoring all feedback and having faith, maybe keep your eyes closed. Oh and the attachments show up in inverse attach order ... so start with the last one.
Glad you don't like 'm. You can disable Smilies in your profile, it's possible to overrule those settings for each individual post again. More people should turn 'm off ... that would be a great idea ...
BBCode and HTML don't do much harm though.
Jan.
PostPosted: Sun Jun 19, 2005 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I used to make my own PCBs. The old standard method with photoemulsion and all that. You can make those perfect films yourself too. What you need is "lithographic" film, and you can get that in most pro photo gear shops that sell darkroom stuff. Jan is right about most reprographic studios can do this too.
Audio files: 107
PostPosted: Sun Jun 19, 2005 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Disabling BBCODES only means that in your posts, the bbcodes will not be expanded, not in other peoples' post that you are looking at. Turning it off makes the quote and image inclusion features also not work, so it's more or less pointless to turn it off. The only reason I can see for turning BBCODES off is if you want to use text emoticons.
Personally, I think HTML and BBCODE provide a method to make your posts more expressive. At times, creative use of emoticons (the term originally applied to text-only figures) has been raised to an art form here at electro-music.com.
PostPosted: Sun Jun 19, 2005 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
The latter is definately the cheaper option- and that's quite expensive already. What one needs are friends in the business, and I moved away from them years ago. Unless of course you have a few grand handy for a 10x8 Sinar technical camera complete with 210mm lens or a reprographic overhead camera -or whatever those things are called?!
I've emailed some more copies to the printer. The original one and the 300dpi version. I will have another go later this week- Jan, I'm sure it isn't that hairy- we can work it out :)
Just need to get the knack back of dry mounting using an iron and working out that I shouldn't mess with images in photoshop too much (but mummy, it's sooo fun!! :)))- I'm still 'old school' you see!
Tom
ACHTUNG!
PostPosted: Sun Jun 19, 2005 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
PS, smiles now disabled!
ACHTUNG!
Niio2
