  Muied Lumens Frequencies
CGS89 x2 SOLVED!
oozitron
PostPosted: Wed Sep 23, 2015 6:09 pm    Post subject: CGS89 x2 SOLVED! Reply with quote  Mark this post and the followings unread
EDIT: Yes this works fine but you use the RSP pad, not the RST one.
GS#1 Step9 OUTPUT goes to GS#1 HOLD and to GS#2 RSP
GS#2 Step9 OUTPUT goes to GS#2 HOLD and to GS#1 RSP
CLOCK goes to both GS#1 and GS#2
RESET button goes to RSB on GS#1
This thing is fabulous. I need to build a few more Smile
Thanks Ken!!!
Is it possible to join two CGS89 Gate Sequencers to make a 16 step unit?
I just want a Clock in and a Reset button, no need for length controls or reset jacks for this project.
I have two CGS89s built, but I can't figure out how to wire them into a dedicated 16 step.
I connected the Step9 Out of each one to the other's Reset In, and fed the clock to both, but they both run at the same time. I connected Step9 Out of each to it's own Hold In, but that didn't help.
Is it possible to do this? And if so how the hell do you wire it?
thanks! Drew
