vladosh
Audio files: 46
Posted: Thu Jan 20, 2011 5:01 am Post subject:
Hi Inventor .. i have seen the chuck section here but not really sure about it .. those modules are with pic in it if i got it right .. that boolean sequencer might be a nice thing to build if it ain't very complicated do you offer a pic for it ? .. anyway i got a long way to go till i can order stuff again .. but it does sound exotic - a boolean sequencer |
Inventor
Audio files: 267
Posted: Thu Jan 20, 2011 5:14 am Post subject:
vladosh wrote: | Hi Inventor .. i have seen the chuck section here but not really sure about it .. those modules are with pic in it if i got it right .. that boolean sequencer might be a nice thing to build if it ain't very complicated do you offer a pic for it ? .. anyway i got a long way to go till i can order stuff again .. but it does sound exotic - a boolean sequencer |
Vladosh, anything that counts out a binary sequence can be a boolean sequencer, just hang some resistors off of it to create a CV output. That's as simple as it gets and you can get as complicated as you like (which I have done in software form).
The history of the BS (love that acronym) is that I started out here at electro-music knowing almost nothing about music and lots of stuff about electronics, so when I needed a sequencer I was at a loss. I didn't know about step sequencers or Baby 10's or Klee's, etc. so I just conjured up something out of my digital logic understanding mixed together with my analog understanding. Out popped a BS and the rest is, well, fun!
Since that time I have discovered that as is so often the case, the BS is a re-invention not a totally original invention, as it has been done in simpler form using diodes and other techniques from the very beginning of synthesizers. It is occasionally reinvented as well by others. The only thing I did was really explore it thoroughly in all its forms or many of them using ChucK software.
What's cool about it is it can produce extremely long sequences that do not repeat for a long time, like 256 notes or 4096 notes or whatever you want really. It does, however, repeat phrases of sound and it modifies those phrases as the song progresses too, and these features make for enjoyable listening.
If you would like to build any type of BS, just start a thread in an appropriate forum and call my attention to it. I will be happy to describe it to you there, plus it's a public record being in a post, so others can follow along too.
Good luck
the19thbear
Posted: Thu Feb 03, 2011 3:16 am Post subject:
any sound samples of the doepfer synth yet |
isak
Posted: Sat Aug 30, 2014 1:40 am Post subject:
Hi guys.
I came a cross the OneBoard farm synth, looks like fun project.
Andy,
how does it sound?
Ive tried to search the net for sound samples and the only thing I found on this synth is this post.
Is it really that "bad"? _________________ http://www.myspace.com/mgmtrance |
Broadwave
Joined: Feb 16, 2007 Posts: 347 Location: Manchester UK
Audio files: 6
Posted: Sat Sep 06, 2014 11:59 pm Post subject:
isak wrote: | Hi guys.
Andy,
how does it sound?
Is it really that "bad"? |
It's basic and raw, but "fun" to build - It was one of the first things I did when I got into SDIY. I originally intended to put together a basic Polysynth, but I got sidetracked when I realized that ARP circuits were easy(ish) to copy |
isak
Posted: Sun Sep 07, 2014 11:35 am Post subject:
thanks for replying Andy
did you finished the project?
did you had time to test it?
whats the VCO Vpp?
how does the VCF sounds/acts?
can you upload a small sound sample please?
sorry for lots of questions
i have a perfect box for this small project and i just want to make sure its worth the try.
thanks Andy. _________________ http://www.myspace.com/mgmtrance |
Broadwave
Audio files: 6
Posted: Sun Sep 07, 2014 10:14 pm Post subject:
isak wrote: |
whats the VCO Vpp?
Unfortunately, I no longer have it
But the VCO output was 5v PP (0-5v, I think) and stable over 4 octaves. The VCF was aggressive (!!!) very similar to the MS20, but the resonance was harsh and difficult to control at high settings.
There was also a little bleedthrough from the LFO to the VCO, but looking back, that could have been due to the rough PSU I built for it |
isak
Posted: Mon Sep 08, 2014 1:02 am Post subject:
Thank you Andy.
I see the ms20 design on the pcb is an LM13700 one, I saw in his site the transistors version, by reading this I was wandering is its any better sounding /acting then the LM13700 one.
mmm...any one built the other version?
http://www.aleph.co.jp/~takeda/radio/MS20clone2E.html
Thank you very much for helping out here
Isak. _________________ http://www.myspace.com/mgmtrance |
isak
Posted: Tue Dec 30, 2014 5:40 am Post subject:
Hi guys.
Can you please try to explain how the pots of the env connects?
I don't really understand from the scheme what should I do.
Let's take the decay and sustain, theres a diode that connected from the decay to the sustain, from what leg in the decay pot to what leg in the sustain pot?
About the other parameters, attack, release ...all 3 leg are connected?
Please help out, I tried everything, doesn't seems to work at all.
The scheme:
http://www.aleph.co.jp/~takeda/radio/img/farm555EG-revB.gif
Isak E. _________________ http://www.myspace.com/mgmtrance |
isak
Broadwave
Audio files: 6
Posted: Tue Nov 10, 2015 1:03 am Post subject:
Hmmm.... Instead of the sync in going to pin 6 of U2, maybe try putting it to the gate of Q2? _________________ Kronos 2-88, Kronos 61, Studiologic Sledge V2/SL, Broadwave ARP 2600EX, Broadwave 18U ARP based Eurorack Modular, Broadwave Minimoog Clone, GEM S2 Turbo.
Synth DIY Projects
Musical Doodlings |
isak
