March Equinox 2016 live streaming event.
Page 2 of 4 [76 Posts]
Audio files: 638
PostPosted: Sat Mar 12, 2016 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you! I updated the schedule.
and thanks for keeping the poster up-to-date jan. (say hi to hellbo for me)
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider
Audio files: 139
PostPosted: Sun Mar 13, 2016 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
1. Preferred Start Time (Please use GMT/Military Time): 16:30
2. Set Length (30 or 60 minutes): 30 mins
3. Artist Name (For displaying on the poster): Epicyclus / Orchard
4. Chat Name (if different from artist/forum name): Skrog Productions
5. Location (City/State/Country - Optional): Southern Scotland , UK
6. Description (Style/Genre/Equipment, etc. - Optional): Dark & Sparkly sequenced modular.
Thanks , Dave.
Smile Smile Smile
epicyclus@skrogmusic.plus.com
Audio files: 638
PostPosted: Wed Mar 16, 2016 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
DON'T FORGET TO DO A STREAMTEST BEFORE THE EVENT!
The schedule with the assigned ports can be found here
PostPosted: Wed Mar 16, 2016 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
DON'T FORGET TO DO A STREAMTEST BEFORE THE EVENT![/url]
Over the past couple of weeks, I have done several stream tests. I can do another one tonight either before or after Jez's AIS in case anyone wants to listen.
rdorsche
PostPosted: Wed Mar 16, 2016 7:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
1) I will test tomorrow night (Thursday)
2) can someone verify for me that 17:30 GMT is 13:30 Eastern (USA)? We just changed out of Daylight Savings last weekend
PostPosted: Thu Mar 17, 2016 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
During standard time, EST is GMT -5. During daylight savings time ("spring ahead"), EDT is GMT-4. So, 17:30 - 4 is indeed 13:30 (aka 1:30 pm EDT).
Steve
rdorsche
PostPosted: Thu Mar 17, 2016 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks, Dr. Steve!
Audio files: 153
PostPosted: Thu Mar 17, 2016 7:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is it possible for me to get the regular Chez mosc slot?
rdorsche
PostPosted: Thu Mar 17, 2016 8:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
couldn't get an admin on tonight. hoping I'll get a little help with testing tomorrow after 5pm eastern to test my port.
p.s. why do I have such a complicated setup? (look at the chart)
Audio files: 638
PostPosted: Fri Mar 18, 2016 3:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry Robert, I waited untill 3am but had to get some sleep. If by chart you mean the port routing that looks more complicated than it is
You just connect the same way as you have done before, I just copied it from the September Equinox event. I personally prefer the
standard ports but Jan wants people that do their own shows to use it so there is no switching needed. I don't actually remember you
having done that though, so I am not sure why you got that port assigned in the first place, maybe you couldn't get another one to work ?
But I could give you a standard port for the event.
You had the regular slot but mentioned last week you would be going to Kutztown University so I took Twyndyllyngs off the schedule.
I can put it back on. I was looking forward to an hour of Antimon though so if you can start 30 minutes later that'll be great.
PostPosted: Fri Mar 18, 2016 5:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Pho, Howard--I'll let you guys sort it out, but I had to chime in here just in case. By regular time, I suspect Howard means 6pm east coast USA time, which is now GMT -4 (as of last week). By my calculation, 6 + 4 + 12 = 22:00 GMT. According to the posted schedule as of a few minutes ago, Cranial Mythos was on for 22:00 [aka 6 pm EDT]. Antimon is listed as 22:30 [aka 6:30 EDT].
If you need to move me to a later time slot , that is fine with me--I can listen to myself play live anytime, and I really want to hear Greg, Howard & Bill, and Stefan.
(And if you already have it worked out, just ignore me.)
iSteve
rdorsche
PostPosted: Fri Mar 18, 2016 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds good to me; we must have just missed each other, I was testing around 10 or 11PM my time.
I'll try testing again immediately after I get out of work and home, about 5PM EST.
I tried using the same config I used last event I played in, tried switching the ports to any of those numbers in BUTT (9876, 8052, 9878) and even with Mike Hunter's help, he couldn't listen in on any accompanying listening port (9877, 9879... etc). Which begs the question: how does one check their connection by themselves?
At any rate, BUTT tells me I'm connected. I just can't know if it's telling the truth.
Audio files: 638
PostPosted: Fri Mar 18, 2016 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Steve, I already thought there might be some time confusion with the recent changes. I rather not make too
many last minute adjustments to the schedule though unless I can discuss it with all participants in chat at the same time.
But I could move Cranial Mythos to your slot if I get confirmation from howard that they will indeed not be at Kutztown University.
Than move Antimon up 30 minutes if he is ok with it and you after him. The 20:30 slot is also still available though so if you could do that
(yes, you mentioned a later slot) that would fill up that gap. Or move Antimon to that slot but I really would like to hear an hour Wink
Audio files: 638
PostPosted: Fri Mar 18, 2016 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
When you perform you connect to 9876 which will put you directly on the main radio channel (8052). For testing you use 9878
which you can listen to on 8054. This is one reason why I prefer the regular ports so you don have to change ports between testing
and performing. During the event this doesn't really matter though and you could just test on 9876 right away since the main radio
channel will be connected to other ports anyway.
egw
G2 patch files: 8
PostPosted: Fri Mar 18, 2016 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I think Twyndyllyngs was originally at 2300. If that doesn't work I'm willing to move.
www.gregwaltzer.com
Audio files: 638
PostPosted: Fri Mar 18, 2016 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Great! Just keep an eye on the schedule in case there are any changes. But I will post those here as well of course.
rdorsche
PostPosted: Fri Mar 18, 2016 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm all port-tested and safe to let wander in large groups now.
Queer
PostPosted: Fri Mar 18, 2016 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll try testing tonight!
Success! Tested on 8138 and all good!
https://queertunes.bandcamp.com
Audio files: 638
PostPosted: Fri Mar 18, 2016 8:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
1. Preferred Start Time (Please use GMT/Military Time): 17:00
3. Artist Name (For displaying on the poster): PHOBoS
4. Chat Name (if different from artist/forum name): PHOBoS
5. Location (City/State/Country - Optional): Moon Base
6. Description (Style/Genre/Equipment, etc. - Optional): That's not music
7. Website Address: http://phobos.000space.com/
8. Anything else you like to mention: prrrfteh bleep tjing tokkkk ping
AlBaldwin
PostPosted: Sat Mar 19, 2016 5:36 am    Post subject: Ready ... almost
Subject description: March
Connection good.
Time for the usual last-minute-fiddling with instruments.
Looking forward to it.
rdorsche
PostPosted: Sat Mar 19, 2016 6:03 am    Post subject: Re: Ready ... almost
[quote="AlBaldwin"]Connection good.
Looking forward to it.[/quote
How about that, I'm not the last-second guy this year! Smile
AlBaldwin
PostPosted: Sat Mar 19, 2016 6:39 am    Post subject: Last Second Guy Reply with quote  Mark this post and the followings unread
Dunno. We may have a race going here.
Tweak Tweak Tweak
dasz
rdorsche
PostPosted: Sat Mar 19, 2016 7:05 am    Post subject: Re: Last Second Guy Reply with quote  Mark this post and the followings unread
Tweak Tweak Tweak
dasz
Tweaking? I'm still writing out a path
PostPosted: Sat Mar 19, 2016 7:08 am    Post subject: Re: Last Second Guy Reply with quote  Mark this post and the followings unread
rdorsche wrote:
Tweak Tweak Tweak
dasz
I have most of the wires connected--power, audio, audio--and the controllers do stuff. Time to figure out the other stuff now.
AlBaldwin
PostPosted: Sat Mar 19, 2016 7:09 am    Post subject: Aha! Reply with quote  Mark this post and the followings unread
It'll be good.
