Audio files: 705
Joined: Jan 07, 2009 Posts: 1196 Location: Scottish Borders
Audio files: 155
Posted: Sun Mar 13, 2016 9:56 am Post subject:
1. Preferred Start Time (Please use GMT/Military Time): 16:30
2. Set Length (30 or 60 minutes): 30 mins
3. Artist Name (For displaying on the poster): Epicyclus / Orchard
4. Chat Name (if different from artist/forum name): Skrog Productions
5. Location (City/State/Country - Optional): Southern Scotland , UK
6. Description (Style/Genre/Equipment, etc. - Optional): Dark & Sparkly sequenced modular.
Thanks , Dave.
Audio files: 705
Joined: Aug 08, 2009 Posts: 1082 Location: Out scouting . . .
Posted: Wed Mar 16, 2016 10:05 am Post subject:
PHOBoS wrote: | DON'T FORGET TO DO A STREAMTEST BEFORE THE EVENT![/url] |
Over the past couple of weeks, I have done several stream tests. I can do another one tonight either before or after Jez's AIS in case anyone wants to listen. |
rdorsche
Joined: Jan 23, 2010 Posts: 84 Location: Syracuse, NY, USA
Posted: Wed Mar 16, 2016 7:12 pm Post subject:
1) I will test tomorrow night (Thursday)
2) can someone verify for me that 17:30 GMT is 13:30 Eastern (USA)? We just changed out of Daylight Savings last weekend |
Posted: Thu Mar 17, 2016 2:40 am Post subject:
rdorsche wrote: | 1) I will test tomorrow night (Thursday)
During standard time, EST is GMT -5. During daylight savings time ("spring ahead"), EDT is GMT-4. So, 17:30 - 4 is indeed 13:30 (aka 1:30 pm EDT).
Steve |
rdorsche
Posted: Thu Mar 17, 2016 6:19 am Post subject:
thanks, Dr. Steve! |
Joined: Jan 31, 2003 Posts: 18198 Location: Durham, NC
Audio files: 213
Posted: Thu Mar 17, 2016 7:51 pm Post subject:
Is it possible for me to get the regular Chez mosc slot? _________________ --Howard
my music and other stuff |
rdorsche
Posted: Thu Mar 17, 2016 8:54 pm Post subject:
couldn't get an admin on tonight. hoping I'll get a little help with testing tomorrow after 5pm eastern to test my port.
p.s. why do I have such a complicated setup? (look at the chart) |
Audio files: 705
Posted: Fri Mar 18, 2016 3:23 am Post subject:
rdorsche wrote: | couldn't get an admin on tonight. hoping I'll get a little help with testing tomorrow after 5pm eastern to test my port.
Sorry Robert, I waited untill 3am but had to get some sleep. If by chart you mean the port routing that looks more complicated than it is
You just connect the same way as you have done before, I just copied it from the September Equinox event. I personally prefer the
standard ports but Jan wants people that do their own shows to use it so there is no switching needed. I don't actually remember you
having done that though, so I am not sure why you got that port assigned in the first place, maybe you couldn't get another one to work ?
But I could give you a standard port for the event.
mosc wrote: | Is it possible for me to get the regular Chez mosc slot? |
You had the regular slot but mentioned last week you would be going to Kutztown University so I took Twyndyllyngs off the schedule.
I can put it back on. I was looking forward to an hour of Antimon though so if you can start 30 minutes later that'll be great. _________________ "My perf, it's full of holes!"
Posted: Fri Mar 18, 2016 5:50 am Post subject:
PHOBoS wrote: | mosc wrote: | Is it possible for me to get the regular Chez mosc slot? |
I can put it back on. I was looking forward to an hour of Antimon though so if you can start 30 minutes later that'll be great. |
Pho, Howard--I'll let you guys sort it out, but I had to chime in here just in case. By regular time, I suspect Howard means 6pm east coast USA time, which is now GMT -4 (as of last week). By my calculation, 6 + 4 + 12 = 22:00 GMT. According to the posted schedule as of a few minutes ago, Cranial Mythos was on for 22:00 [aka 6 pm EDT]. Antimon is listed as 22:30 [aka 6:30 EDT].
If you need to move me to a later time slot , that is fine with me--I can listen to myself play live anytime, and I really want to hear Greg, Howard & Bill, and Stefan.
(And if you already have it worked out, just ignore me.)
iSteve |
rdorsche
Posted: Fri Mar 18, 2016 6:00 am Post subject:
PHOBoS wrote: | rdorsche wrote: | couldn't get an admin on tonight. hoping I'll get a little help with testing tomorrow after 5pm eastern to test my port.
But I could give you a standard port for the event. |
Sounds good to me; we must have just missed each other, I was testing around 10 or 11PM my time.
I'll try testing again immediately after I get out of work and home, about 5PM EST.
I tried using the same config I used last event I played in, tried switching the ports to any of those numbers in BUTT (9876, 8052, 9878) and even with Mike Hunter's help, he couldn't listen in on any accompanying listening port (9877, 9879... etc). Which begs the question: how does one check their connection by themselves?
At any rate, BUTT tells me I'm connected. I just can't know if it's telling the truth. |
Audio files: 705
Posted: Fri Mar 18, 2016 7:15 am Post subject:
Thanks Steve, I already thought there might be some time confusion with the recent changes. I rather not make too
many last minute adjustments to the schedule though unless I can discuss it with all participants in chat at the same time.
But I could move Cranial Mythos to your slot if I get confirmation from howard that they will indeed not be at Kutztown University.
Than move Antimon up 30 minutes if he is ok with it and you after him. The 20:30 slot is also still available though so if you could do that
(yes, you mentioned a later slot) that would fill up that gap. Or move Antimon to that slot but I really would like to hear an hour _________________ "My perf, it's full of holes!"
Audio files: 705
Posted: Fri Mar 18, 2016 7:24 am Post subject:
rdorsche wrote: | I tried using the same config I used last event I played in, tried switching the ports to any of those numbers in BUTT (9876, 8052, 9878) and even with Mike Hunter's help, he couldn't listen in on any accompanying listening port (9877, 9879... etc). Which begs the question: how does one check their connection by themselves? |
When you perform you connect to 9876 which will put you directly on the main radio channel (8052). For testing you use 9878
which you can listen to on 8054. This is one reason why I prefer the regular ports so you don have to change ports between testing
and performing. During the event this doesn't really matter though and you could just test on 9876 right away since the main radio
channel will be connected to other ports anyway. _________________ "My perf, it's full of holes!"
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
Posted: Fri Mar 18, 2016 7:54 am Post subject:
I think Twyndyllyngs was originally at 2300. If that doesn't work I'm willing to move. _________________ www.gregwaltzer.com |
Audio files: 705
rdorsche
Posted: Fri Mar 18, 2016 4:43 pm Post subject:
I'm all port-tested and safe to let wander in large groups now. |
Queer
Posted: Fri Mar 18, 2016 5:25 pm Post subject:
I'll try testing tonight!
Success! Tested on 8138 and all good! _________________ https://queertunes.bandcamp.com |
Audio files: 705
Posted: Fri Mar 18, 2016 8:10 pm Post subject:
1. Preferred Start Time (Please use GMT/Military Time): 17:00
3. Artist Name (For displaying on the poster): PHOBoS
4. Chat Name (if different from artist/forum name): PHOBoS
5. Location (City/State/Country - Optional): Moon Base
6. Description (Style/Genre/Equipment, etc. - Optional): That's not music
7. Website Address: http://phobos.000space.com/
8. Anything else you like to mention: prrrfteh bleep tjing tokkkk ping _________________ "My perf, it's full of holes!"
AlBaldwin
Joined: Dec 31, 2012 Posts: 45 Location: Maryland, USA
Posted: Sat Mar 19, 2016 5:36 am Post subject:
Ready ... almost Subject description: March |
Connection good.
Time for the usual last-minute-fiddling with instruments.
Looking forward to it. |
rdorsche
Posted: Sat Mar 19, 2016 6:03 am Post subject:
Re: Ready ... almost Subject description: March |
[quote="AlBaldwin"]Connection good.
Looking forward to it.[/quote
How about that, I'm not the last-second guy this year! |
AlBaldwin
Posted: Sat Mar 19, 2016 6:39 am Post subject:
Last Second Guy |
Dunno. We may have a race going here.
Tweak Tweak Tweak
rdorsche
Posted: Sat Mar 19, 2016 7:05 am Post subject:
Re: Last Second Guy |
AlBaldwin wrote: | Dunno. We may have a race going here.
Tweak Tweak Tweak
Tweaking? I'm still writing out a path |
Posted: Sat Mar 19, 2016 7:08 am Post subject:
rdorsche wrote: | AlBaldwin wrote: | Dunno. We may have a race going here.
Tweak Tweak Tweak
I have most of the wires connected--power, audio, audio--and the controllers do stuff. Time to figure out the other stuff now. |
AlBaldwin
Posted: Sat Mar 19, 2016 7:09 am Post subject:
Aha! |
It'll be good. |
