vladosh
Audio files: 46
Posted: Mon Apr 11, 2016 1:12 am Post subject:
Yamaha GX VCF (untested layout) |
this is pcb for MOTM Yamaha GX VCF , the schematics are shared on the MOTM page , it's still untested layout using BCM847 and BCM857 pairs instead of the variety of transistor chips in the original MOTM schematic ,pcb size is 100x100mm ,if for some reason i need to remove the layout just notify me ,SSM is written on the pcb only for orientation it is actually a BCM857
Description: |
Filesize: |
814.28 KB |
Viewed: |
637 Time(s) |
Description: |
Filesize: |
32.63 KB |
Viewed: |
564 Time(s) |
_________________ http://synthacks.blogspot.com/ шематикс |
vladosh
Audio files: 46
Posted: Thu Dec 14, 2017 9:07 am Post subject:
here is a working layout for the Yamaha GX ,just finished and found some errors ,now it's fixed ,i used J201 for the FET ,it is sourse - gate - drain > placement on the diagram
Description: |
Filesize: |
830.99 KB |
Viewed: |
536 Time(s) |
Description: |
Filesize: |
297.7 KB |
Viewed: |
450 Time(s) |
LFLab
Joined: Dec 17, 2009 Posts: 497 Location: Rosmalen, Netherlands
Posted: Thu Dec 14, 2017 9:20 am Post subject:
Nice!
So you used an adapter for the BCM's (you can only get them in SMT, right?)?
Link to the schematic? this can probably shrunk quite a bit if going to SMT for everything, interesting!
Found it: http://synthtech.com/docs/MOTM-485_manual.pdf |
vladosh
Audio files: 46
Posted: Thu Dec 14, 2017 9:55 am Post subject:
its range is kind of narrow ,at least on mine ,but the resonance is why i want to keep it _________________ http://synthacks.blogspot.com/ шематикс |
vladosh
Audio files: 46
BCM is only SMD ,i used adapters from 258's pdf here on forum _________________ http://synthacks.blogspot.com/ шематикс |
gabbagabi
Joined: Nov 29, 2008 Posts: 652 Location: Berlin by n8
Posted: Mon Dec 18, 2017 5:59 am Post subject:
lot of work!
i really like how u draw the resistors, i will do it from now on the same way.
btw i never heard about that filter, thx for bringing it in |
vladosh
Audio files: 46
