"Okita" Vocoder (Roland SVC-350) - Adding more channels?
Page 1 of 1 [12 Posts]
Broadwave
Audio files: 6
PostPosted: Thu Apr 09, 2015 9:00 am    Post subject: "Okita" Vocoder (Roland SVC-350) - Adding more channels? Reply with quote  Mark this post and the followings unread
I've just found the details for building N. Okita's 10 channel vocoder, based on the Roland SVC-350.
I'd like to double up on the channels, but I'm not quite sure if what I have in mind is the right way to go about it.
I should be able to add them simply by changing the value of the caps - as it stands, Ch1 uses 0.05 (0.047), Ch 2 uses 0.033 etc.
If I replace Ch 2's caps with 0.039 and put the 0.033 in Ch 3, then 0.027 in Ch 4 etc. then this would "fill in" the gaps of the current 10 bands, up to the desired 20.
BUT, should I also change the basic 4 pole BPF's shown, to 8 pole which would help create "space" for the extra channels... or is it just a case of changing the value of the resistors (which ones???) to narrow the bandwidth of each channel by 50%-ish.
I'm not sure where I should go from here. Any help/advice would be grateful.
Either way, I'm probably having one of my mad moments and maybe all this is bunkum Wink
 Filesize:  925.17 KB
 Viewed:  439 Time(s)
isak
PostPosted: Wed Apr 15, 2015 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Andy.
My non pro advice would be to search another vocoder project with more Channs then 10, and see how they handle things over there.
Maybe it will give you direction or an idea.
Hope it helps in some way Rolling Eyes
Isak E.
Broadwave
Audio files: 6
PostPosted: Fri Apr 17, 2015 1:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I've taken a look at other designs, particularly Senheisser & Syntovox. They both add the extra filter cells on the analysis side.
Luckily, Okita's board layout makes it easy to insert them via an add-on PCB Wink
I'll build the basic version, then tinker with it to see what happens.
isak
PostPosted: Fri Apr 17, 2015 1:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool!
Waiting to see your progress Smile
Good luck with the project!
StephenGiles
PostPosted: Fri Apr 17, 2015 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
EH Vocoder page 1
eh_vocoder_001.pdf
 Filename:  eh_vocoder_001.pdf
 Filesize:  135.55 KB
 Downloaded:  415 Time(s)
StephenGiles
EH Vocoder page 2
eh_vocoder_002.pdf
 Filename:  eh_vocoder_002.pdf
 Filesize:  120.03 KB
 Downloaded:  393 Time(s)
StephenGiles
PostPosted: Fri Apr 17, 2015 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
EH Vocoder page 3
eh_vocoder_003.pdf
 Filename:  eh_vocoder_003.pdf
 Filesize:  36.33 KB
 Downloaded:  457 Time(s)
PostPosted: Fri Apr 17, 2015 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
The NE570 has me worried. It adds clarity, from what I understand, but with one for each channel...
Smallbear lists the V571 (a NE571 clone from CoolAudio) at $3.25, for 10-24 each. The original NE570 is $5.95, and the next price break is $4 at 100 each.
Broadwave
Audio files: 6
PostPosted: Fri Apr 17, 2015 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm using the NE571 (same as the 570 but slightly different temperature specs) I got 12 of them from Futurlec $2.80 each Wink
They're used as the Envelope Follower/VCA for each channel, and compressor on the input board.
@StevenGiles - Many thanks for the EH schems, they will definitely come in handy. Okita's BPF's use different value caps, but the resistors are the same value, EH's version use the same 1% caps, but vary the resistor (but only one filter cell?)... I'll think I'll go a similar route, but keep the 4 cell idea. At least I don't need to source odd value 1% caps now, and calculating the resistor values for the extra bands will be far simpler. Looks like another order for Futurlec is on the cards - they stock all the resistors needed Wink
Much appreciated.
xpmtl
PostPosted: Fri Apr 24, 2015 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you seen this ?
http://www.sdiy.org/cbm/vocoder.htm
He added 4 channels to the Okita vocoder based on the ETI Vocoder (there's a chart in the archive with the values)...
ETI Vocoder.zip
 Filename:  ETI Vocoder.zip
 Filesize:  1011.64 KB
 Downloaded:  315 Time(s)
http://sdiy.xpmtl.net
Broadwave
Audio files: 6
PostPosted: Mon Apr 27, 2015 12:17 am    Post subject: Reply with quote  Mark this post and the followings unread
@AlanP - The good news is that NE571's work fine.
@xpmtl - Yes, I saw this and used his mod (470k resistors from pins 1 & 16 to ground) to stop bleedthrough on the VCA's - it cleans things up really well.
I've decided not to add extra channels for the time being, I wanted to get it built as per Okita's original plans to see how good it was before messing around with it... The results are in this thread.
I had no idea that Korg's VC-10 was a 20 band Vocoder - looks pretty simple too, so I *might* have a go Wink
Synth DIY Projects
Musical Doodlings
zephyrin
PostPosted: Sat Apr 16, 2016 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
i don't know if someone know it but there are a 20 bands vocoder designs by JH here
http://jhaible.com/legacy/vocoder/living_vocoder.html
Ralf from random source have sell some PCB for 100$
Perhaps it can make an other batch!
If there are someone interesting by this you can send a message to ralf on this site
http://randomsource.net/haible/vintage
