masterofstuff124
Joined: Sep 21, 2015 Posts: 23 Location: Miami, Florida
Posted: Fri Apr 15, 2016 5:30 pm Post subject:
Power Supply? |
Ive found this http://imgur.com/7GoweSG and this http://imgur.com/KDKUCXB
What is the difference. How should I go about making power supplys for my projects. the smaller the better in most cases. Ive avoided meanwell from concerns about grounding. not sure how to do all the elaborate safety ground wiring stuff.
the first strip layout powers my entire eurorack. |
Joined: Mar 11, 2014 Posts: 746 Location: New Zealand
Posted: Sat Apr 16, 2016 12:15 am Post subject:
I'd hesitate to use tantalums for power supplies -- IIRC, they short when they die.
The only circuit difference between the two is the extra pair of big input caps.
If you have a spare track at top and bottom, might be an idea to add a resistor and LED, both as a power indicator, and as something to keep the regulator working (as the MFOS website says, some regulators need some load to actually regulate.)
Heat is a big factor -- you want good size heatsinks on the regulators, and room for air to move through. Especially as the load increases. |
masterofstuff124
Posted: Sat Apr 16, 2016 6:44 pm Post subject:
Can I safely use the same value electros in place of the tantulum?
for the large ones Could I go for lower value caps i.e. smaller caps(or even lower rating 25v?) for the 4700uf or 3300 in the smaller layout.
My next build im planning on using the second design to power a Benjolin and +- and gnd out so i can interface it with breadboard circuits; a poor mans NS1 (http://www.sound-machines.it/product/ns1nanosynth/)
I found a 250mah 12v ac wall wart. planning on using that. Ill most likely lay the large caps Horizontal along with the 7912 and 7812 on heatsinks. Trying to work on small contained instrument builds so i want a compact power supply. |
