Simmons SDS PROM images.
Page 1 of 1 [16 Posts]
reve
PostPosted: Wed Mar 10, 2010 4:37 pm    Post subject: Simmons SDS PROM images.
Subject description: Anyone hoarding images or have a list of published PROMs?
Hi Electro-Friends!
So hey, I picked up a Simmons SDS 9 kit on the cheap. It came with a couple spare EPROMs... which seriously whet my appetite for additional PROMs. But darned if I can't find a repository of Simmons binary images on the internet. I found the Oberheim and Linn stuff... but no Simmons. Heck, I can't even find an authoritative list of what OEM PROMs were available for purchase when these things were new.
The interwebs have told me that the eprom-based SDS machines used a linear data format rather than the companded format used by Oberheim, Linn and others, so I can't just burn those.
I thought maybe I could convert some of those sounds to linear, but that's not as exciting as getting copies of the official Simmons PROMs. Plus I'm fuzzy on the format. I thought the PROMs could have different sampling rates (like with the oberheims), and I'm not sure how that information is stored... if it even is. Is it just 8 bit linear PCM? Endian format? Crap, I have no idea.
So! If you have a) eprom images, b) a list of images, or c) more technical information about how to make sound into an SDS-compatible eprom image... I'd love to hear from you. Smile Or even if you have a reader and could just send me a raw binary to dissect. Smile
Thank you!!
klo
PostPosted: Sat Mar 13, 2010 11:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.simmonsmuseum.com/?area=eproms
reve
PostPosted: Tue Mar 16, 2010 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am weeping with joy.
Thank you, Klo!
Oortone
PostPosted: Wed May 29, 2013 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Are these eprom images available alsewhere? They have been removed from that site.
HansRL
PostPosted: Sat Apr 09, 2016 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Old thread but I've not found an answer elsewhere?
helge-h
PostPosted: Sat Apr 09, 2016 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
https://web.archive.org/web/20090510114833/http://www.simmonsmuseum.com/?area=eproms
I haven't tried to download anything myself.
Helge
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sat Apr 09, 2016 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a few Simmons rom images that I used in a project.
It is a collection of images from a few contemporary machines.
the Zip is here
If you want to preview before burning, you can audition the sounds via this link.
Oortone
PostPosted: Sun Apr 10, 2016 4:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Helge
Don't know if I'm doing this right but I can't download.
HansRL
PostPosted: Sun Apr 10, 2016 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Great idea Helge, but sadly no files archived.
Thanks for the files Ian. Your player where also useful. I’ve read that with Simmons 8-bit linear PCM format I only had to rename wav files to bin, or the other way around. Doesn’t work I practice as it turns out. Even though VLC have registered ‘bin’ file extension on my Win10 computer.
I’ve seen a couple of project for car computers where they replace the eprom with a parallel flash chip and a USB eraser/burner. Anyone seen similar projects for old eprom drum players?
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sun Apr 10, 2016 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
All the rom images are header-less 8 bit pcm data. I think some older audio editors (cool edit?) had an option to deal with raw audio data.
Percuter and Simmons are linear, the others are a-law.
Audio files: 278
PostPosted: Sun Apr 10, 2016 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool Edit - check (and it still works on win 8 Cool ) .. so that Adobe follow up thing probably as well .. but that's been phased out too now of course Confused
Anyway .. i could behead some files here.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Apr 18, 2016 1:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I had some free time on the weekend (when the teenagers let me near the computer) so I created the ROM browser/downloader web app.
link
I am quite pleased with the code, the app downloads the zip file and uses it's internal structure to build the groups of samples.
The rom data is deflated from the zip and converted to a wav datauri for the download link and the media player control.
The Oberheim a-law roms are converted to 12 bit samples so the wav file is 16bit for them, 8 bit otherwise.
HansRL
PostPosted: Tue Apr 26, 2016 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Ian, that page of yours looks great. I'm a bit slow, could you please clarify. All files availably are now compatible with Sims and Dyns? No longer for Lins and other with compressed format?
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Apr 26, 2016 3:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I wasn't sure is anyone would be interested in conversions so the rom downloads are just byte for byte copies of the original rom images.
Only the Oberheim rom images use the a-law compression so I guess the others are interchangeable (assuming they fit, you can't put put a 27128 into a 2764 socket).
The code expands the a-law data to 16bit and I have a 16 bit linear pcm to a law converter already written. If enough people think it would be useful, i can add a third download link so that all roms have a wav, linear and a-law version. Perhaps an option where you can select your own wav files and have them converted to both rom image types?
The drum machines use something like a 555 oscillator as a sample clock which is variable from about 15-30kHz. The range might vary depending on the type of sound associated with the specific rom type.
HansRL
PostPosted: Tue Apr 26, 2016 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Idea
Not sure how you would secure how files fade out in a usefull manner? You might have to make an online editor?
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Apr 27, 2016 10:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have updated the app so that it will create a linear version of the a-law images under the link alt-samplename.bin
The news/info updates are now moved to a blog so they don't mess up the app too much.
