agustindead
Joined: Jul 22, 2015 Posts: 33 Location: Big City, bright lights
Posted: Sun May 01, 2016 3:57 pm Post subject:
Troubleshooting Ian Fritz AD/AR |
Hi! I'm looking for some help with this build... I've built a dual Ian Fritz AD/AR as per Bugbrand's layout (http://electro-music.com/forum/phpbb-files/fritzdualadar_builddoc_283.pdf) with a small modification leaving out the "long" and "truncate" switches (with their associated capacitor and two diodes) and adding an eurorack power connector. I'm attaching the modified PCB.
What happens is the following: if I trigger any of the envelopes, I get just a pulse out, as if both pots were always at minimum, regardless of the settings. The only way I can get it working is if I use VERY high resistances to control attack and decay times... I discovered this by accident, gently touching the wires going to the pots and using my own skin as a variable resistance. (This sounds pretty cool for a live act, yes, but I'd rather be able to use the module normally as well... )
It happens exactly the same with both halves, so I'm assuming it has something to do with the power supply, component choice or my layout. Sadly, I've check everything at least thrice and can't find anything... So, if someone more experienced could tell me where to look, I'd be pretty grateful.
I'm using 4148's for the diodes and I've checked with a couple of op-amps with no luck...
Thanks in advance!
Description: |
Filesize: |
469.36 KB |
Viewed: |
182 Time(s) |
Cfish
Posted: Sun May 01, 2016 5:28 pm Post subject:
If it's happening on both sides, I would check each rail voltage to ground at the opamps first thing. I test with all opamps removed from the pin sockets so I don't slip and let the magic smoke out. |
agustindead
Posted: Sun May 01, 2016 10:32 pm Post subject:
Thanks for the quick reply! I'm getting full +/-12v at both op-amps.
Any other ideas? |
Joined: Nov 23, 2015 Posts: 1294 Location: Netherlands
Posted: Sun May 01, 2016 11:12 pm Post subject:
Re: Troubleshooting Ian Fritz AD/AR |
agustindead wrote: | leaving out the"truncate" switches (with their two diodes) |
I'm not sure, but are the A/D slopes truncated when the switch is on? In that case, leaving out the diodes, the A/D times are always truncated...
Try putting back the two left out diodes. |
agustindead
Posted: Mon May 02, 2016 3:10 pm Post subject:
Grumble wrote: | agustindead wrote: | leaving out the"truncate" switches (with their two diodes) |
Seems like it's the other way around though: http://electro-music.com/forum/topic-21723.html
Quoting Ian:
Quote: | The "truncate" function cuts off the long tails of the envelopes. For use in VCO frequency chiffs, etc. You can leave the switch and the diodes below it out ... just connect the diodes to the left together and to the opamp output. |
Posted: Tue May 03, 2016 1:25 am Post subject:
Ok, tried to figure out the design, especially what the diodes do, but I couldn't |
wackelpeter
Audio files: 10
Posted: Tue May 03, 2016 11:06 am Post subject:
could it be that the electrolytics that charge and discharge the envelope voltage out are reversed or missing ground connection? _________________ https://soundcloud.com/bastian-j |
roglok
Posted: Sat May 07, 2016 7:46 am Post subject:
wackelpeter wrote: | could it be that the electrolytics that charge and discharge the envelope voltage out are reversed or missing ground connection? |
or maybe simply too small - 4n7 (4.7nF) instead of 4u7 (4.7uF)? |
wackelpeter
Audio files: 10
Posted: Sat May 07, 2016 10:03 am Post subject:
roglok wrote: | wackelpeter wrote: | could it be that the electrolytics that charge and discharge the envelope voltage out are reversed or missing ground connection? |
maybe this... but "normally" electrolytes aren't that small, right or not?
best would be to post a photo of the components side and the soldering side of the pcb... _________________ https://soundcloud.com/bastian-j |
agustindead
Posted: Tue May 10, 2016 6:08 pm Post subject:
Sorry guys, I didn't get notified about these last replies and only saw them when I came to post a little audio clip of the really-really short times I'm getting.
Yes! I thought those "4.7" non polarized caps in Ian's schematic were 4n7, and that's what I used. I now see the silly mistake (and the notes in BugBrand's archive ). Thanks for pointing it out, I'll change them and confirm! |
agustindead
Posted: Tue May 10, 2016 6:44 pm Post subject:
Aaaaaaand it works! Is there a way to describe the pleasure of adding a new working module to your synth??
Thanks guys!! wackelpeter and roglok you nailed perfectly! |
