jurekprzezdziecki
Posted: Mon May 16, 2016 1:05 am Post subject:
Module tester made with Arduino Subject description: looking for arduino module tester |
hi, anyone made it already or knows an actual project?
http://mutable-instruments.net/module_tester
how complicated it is?
thanks jurek |
Posted: Mon May 16, 2016 6:22 am Post subject:
I've built it, I don't think it's terribly complicated. Biggest hassle IMO was assembling the case
Then again, I did have to get a Bus Pirate to program it; despite assurances that it was doable by repurposing another Arduino, I couldn't get that method to work. |
jurekprzezdziecki
Posted: Mon May 16, 2016 6:26 am Post subject:
elmegil wrote: | I've built it, I don't think it's terribly complicated. Biggest hassle IMO was assembling the case
you did original design or with arduino? could you share a design? |
Posted: Mon May 16, 2016 7:41 am Post subject:
I think I may have misunderstood your question.
I used the MI Module Tester design. The internal chip is an ATMega. The design is on github, as Olivier makes all his designs open source after a period of time. You can submit the gerbers to a fabrication house (such as OSHPark) and get your own PCBs made, then build it per the instructions at the MI site.
Are you asking if making your own design is complicated? I would say not especially complicated, but it's not a trivial software job either. |
jurekprzezdziecki
Posted: Mon May 16, 2016 7:46 am Post subject:
elmegil wrote: | I think I may have misunderstood your question.
i know that. i mean just to make a similar module tester based on arduino board - not using the MI design. i would like to build an entire concept using an arduino module. |
Posted: Mon May 16, 2016 8:38 am Post subject:
I see. I thought you were asking how complicated the MI implementation was. |
jurekprzezdziecki
Posted: Thu Jul 14, 2016 3:13 am Post subject:
hi elmegil,
i have finally made the classic board based on gihub files. so far so good. the board is quite assembled but i need some assistance with programming the ATMEGA. what AVR ISP programmer do you used? what is the Bus Pirate? |
