3rd run for Thomas Henry's 555-VCO and Controller LFO
Page 4 of 4 [88 Posts]
muziekzen
PostPosted: Sun Jun 26, 2016 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
elmegil wrote:
Any of the pots that are voltage dividers should be able to be any value you care to use. Lower than 100K will consume a bit more current overall, but I don't have any reason to expect that would be a problem.
Thank you!
beepboop
PostPosted: Fri Aug 26, 2016 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Always late to the party. If anyone has any spare 555-VCO PCBs gathering dust I would love to purchase them and give them a good home.
PostPosted: Fri Aug 26, 2016 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
thonk re-stocks soon, and they ordered 20% more main PCBs than adapter PCBs/Panels Very Happy
ETA 2nd half september
Tech Budday at Random*Source
beepboop
PostPosted: Fri Aug 26, 2016 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Fantastic Very Happy
stahlblau
PostPosted: Thu Jul 06, 2017 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
The building notes says:
2)
when powering from 12V:
R13 = 2k
R27 = 22k
R33 = 137k
I don't have any 137k Sad . Can i keep the 100k instead? Or would it be better to take an 120k or 150k (wich i have lying around) to get even closer?
Many thanks
PostPosted: Thu Jul 06, 2017 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
2)
R13 = 2k
R27 = 22k
R33 = 137k
Many thanks
the higher R33 the higher the ramp level. i would go for 120k. the 150k would not hurt either.
stahlblau
PostPosted: Thu Jul 06, 2017 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
super Matthias! many thanks Very Happy
Aurelius
PostPosted: Sat Nov 25, 2017 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Does anyone have for sell the fonitronik 555vco panel?
PostPosted: Sat Nov 25, 2017 3:04 am    Post subject: Reply with quote  Mark this post and the followings unread
i don't have any left.
however, you might want to drop thonk an email and just ask him. maybe he is willing to sell just the front panel.
philpeery
PostPosted: Tue Dec 05, 2017 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Aurelius, I have a couple 555-VCO panels you can have. My modular is 5U so I don't need them. Send me a PM and we will work out the details.
Phil
MapacheRaper
PostPosted: Wed Aug 29, 2018 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Im building one of the PCBs. I have a tempco doubth: could I use 2x 1k 3000ptc instead of the 2k 3500ppm?
I have opened a thread
http://electro-music.com/forum/post-436410.html#436410re
in the TH room for if someone knows the answer. Any bit is appreciated Wink
PostPosted: Wed Aug 29, 2018 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
it's okay.
but you could also use just one of your 1k and change the other values from 100k to 49.99k.
or just buy the correct one from thonk.
MapacheRaper
PostPosted: Wed Aug 29, 2018 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
it's okay.
That´s perfect. I´ll go for the 49.99k. Danke!
