  Twyndyllyngs Live Chez Mosc
The Les Hall Show
Page 3 of 4 [91 Posts]
Chestnut
PostPosted: Fri Aug 19, 2011 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
enjoyed the show
Inventor
Audio files: 267
PostPosted: Sat Aug 20, 2011 1:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Torvald wrote:
enjoyed the show
Glad you liked it, I had fun. As usual things started off slow and then got better and best toward the end of the show. I played music from a ChucK-based software linear CMOS model implementing a boolean sequencer clocked at audio rates into a block of approximately 32 linear CMOS amplifier summed to the output.
I talked about CMOS theory but just analagously using the water tower example of pipes and valves representing wires and transistors. Then we took a tour of the linear CMOS thread in the Lunetta subforum and finally I talked about the software model while modifying it and playing many examples.
It was a good time and worth a listen (just over one hour).
Les
The Les Hall Show 20110819 1655.mp3
the linear CMOS show
 Filename:  The Les Hall Show 20110819 1655.mp3
 Filesize:  59.89 MB
 Downloaded:  1551 Time(s)
PostPosted: Sat Aug 20, 2011 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Another good one with lots learned. Thanks!
Inventor
Audio files: 267
PostPosted: Tue Aug 23, 2011 10:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have decided to create a pdf file for each week's show so we can all reference the illustrations as I discuss them without having to navigate the forum. Here is last week's pdf file.
Les
TLHS Linear CMOS.pdf
Linear CMOS pdf file
 Filename:  TLHS Linear CMOS.pdf
 Filesize:  863.58 KB
 Downloaded:  1206 Time(s)
Inventor
Audio files: 267
PostPosted: Wed Aug 24, 2011 4:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is this week's circuit. I even got it to resonate with my voice, so cool! Gonna be a good show I hope...
Les
Vocal Boolan Sequencer.pdf
this week's pdf file
 Filename:  Vocal Boolan Sequencer.pdf
 Filesize:  851.45 KB
 Downloaded:  1082 Time(s)
Sonic
PostPosted: Fri Aug 26, 2011 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry I missed the show tonight, Les. Showtime always falls during the period when I make dinner for the kids. Looking forward to listening when you get a chance to upload.
Inventor
Audio files: 267
PostPosted: Fri Sep 02, 2011 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
This week's show turned out quite well, I'm sure you will enjoy it - lots of weird sounds and I even got the voice modulation working pretty well after a bit of rewiring during the show. Was lots of fun, enjoy!
Les
The Les Hall Show 20110902 1654.mp3
The show recording
 Filename:  The Les Hall Show 20110902 1654.mp3
 Filesize:  78.88 MB
 Downloaded:  1525 Time(s)
Sonic
PostPosted: Sun Sep 04, 2011 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just finished listening to this last show. Most enjoyable. Thank you. It's widened my understanding and given me some new techniques to experiment with.
Anyway, you asked for comments so here goes...
I 'm a beginner, but there was nothing in the show I couldn't understand. Don't be afraid to crank up the complexity a little. We can always pester you in the forum or the chatroom, and the more discussion generated the better surely?
I'm not sure about splitting up the show into sections. You should do whatever you enjoy best. I always appreciate any kind of instruction in electronics, but it was also enjoyable when you improvised your circuit, swapping wires and so forth. Any sort of unexpected results and discoveries are great, and are in the spirit of live transmission and lunettas in general.
I have a couple of questions. Hope you don't mind me firing them at you. If you like you could answer them on the next show, or here on the forum. Or not at all. Smile
1. How is it that the logic 'cloud' seems to add harmonic content to the signal? Is it doing anything other than rearranging and mixing square waves of various frequencies?
2. AC-coupling - this is a new concept for me. You used it a few times in this circuit. Am I right in that the reason you used it was to act as a sort of high-pass filter to isolate the higher frequencies from your voice? Assuming I haven't already got this wrong already, why is this? Would the higher frequencies of your voice more efficiently modulate the frequency of the oscillator, and if so, why?
3. What other sources of modulation input might we explore? There's voice and guitar obviously. What about intentionally picking up radio interference? (this is more a thinking aloud than a question...)
Anyway looking forward to the next one...
Richard
Inventor
Audio files: 267
PostPosted: Tue Sep 06, 2011 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Richard, thanks for the feedback - sounds like a plan! I'll answer your questions on the show.
Les
Inventor
Audio files: 267
PostPosted: Fri Sep 09, 2011 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
This week's show will be about the guitar pickup invention. Here is the pdf file.
Les
TLHS Guitar Invention.pdf
the pdf file
 Filename:  TLHS Guitar Invention.pdf
 Filesize:  392.21 KB
 Downloaded:  1073 Time(s)
Inventor
Audio files: 267
PostPosted: Mon Sep 12, 2011 1:55 am    Post subject: Reply with quote  Mark this post and the followings unread
This show was all about guitars, specifically the guitar invention that DrJustice and I created. It's finger pickin' good!
Les
The Les Hall Show 20110909 1757.mp3
the guitar show
 Filename:  The Les Hall Show 20110909 1757.mp3
 Filesize:  49.07 MB
 Downloaded:  1541 Time(s)
Sonic
PostPosted: Wed Sep 14, 2011 7:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great sounds this week Les. Really enjoyed your jamming. What was the synthesized drum sound you used? Sounded very Drexciya-ish with the strange rhythms from the boolean sequencer.
Thanks for answering my questions. Most helpful. I'll be doing some reading about A/C coupling / D/C blocking I think.
Inventor
Audio files: 267
PostPosted: Thu Sep 15, 2011 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sonic, the drum sounds are ChucK models made by kijjaz. He used to make all kinds of models and I would make applications from them. I have not seen kijjaz in a while though, years really.
Les
Inventor
Audio files: 267
PostPosted: Fri Aug 17, 2012 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is an hour long show in which I tell all there is to know about the emSynth project / hobby business of ours / mine. Great if you're into inexpensive yet awesome sounding miniature modular synthesizers.
Les
The Les Hall Show 20120817 1702.mp3
All about emSynth Show
 Filename:  The Les Hall Show 20120817 1702.mp3
 Filesize:  59.64 MB
 Downloaded:  1325 Time(s)
Inventor
Audio files: 267
PostPosted: Thu Sep 13, 2012 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
a show about me and my music. pretty good one, nothing special about it.
Les
The Les Hall Show 20120824 1658.mp3
 Filename:  The Les Hall Show 20120824 1658.mp3
 Filesize:  53.93 MB
 Downloaded:  1347 Time(s)
Inventor
Audio files: 267
PostPosted: Thu Sep 13, 2012 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
If I recall correctly (its been 2 weeks) this show is Strobie old and new, go Strobie go go go go rock us out with your magic music, man! yeah!!!!
Les
The Les Hall Show 20120831 1659.mp3
 Filename:  The Les Hall Show 20120831 1659.mp3
 Filesize:  56.97 MB
 Downloaded:  1395 Time(s)
Inventor
Audio files: 267
PostPosted: Fri Sep 21, 2012 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
This was an excellent interview with Psyingo, or Phil, whose music is under the name Ruin. The music is great, the conversation wonderful, and I gained a new friend in the process - nothing better than that!
Les
The Les Hall Show 20120914 1700.mp3
 Filename:  The Les Hall Show 20120914 1700.mp3
 Filesize:  76.34 MB
Inventor
Audio files: 267
PostPosted: Fri Sep 21, 2012 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
This show turned out well, it was a news and mainly emSynth show with a great jam session at the end. Get your emSynth update here!
Les
The Les Hall Show 20120921 1700.mp3
 Filename:  The Les Hall Show 20120921 1700.mp3
 Filesize:  55.07 MB
 Downloaded:  1427 Time(s)
-minus-
PostPosted: Sat Oct 13, 2012 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Really enjoying the interview show with psyingo, and the music! I missed it when it aired and it's nice to have it posted here to listen to later. +1 to those living in poverty and confined spaces. You're not alone. More of the interview shows please Les! Great show guys!
Inventor
Audio files: 267
PostPosted: Tue Oct 16, 2012 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
great Minus, will do! Sorry I missed last week, i was in the hospital - feeling much better now.
Les
Ganzha
Audio files: 27
PostPosted: Mon Dec 31, 2012 2:47 pm    Post subject: Cool show Reply with quote  Mark this post and the followings unread
I like it very much!
Great show!
http://ziart.kz
Inventor
Audio files: 267
PostPosted: Tue Dec 27, 2016 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
OK so that last message was the end of December. 2012, and now it's the end of December 2016. I've been away for four years this time. I popped in once in a while but never really returned. Well I'm back. Back with full intent of staying put here, not letting petty differences pull me away. Here's why.
I'm faced with my own mortality. I have gained weight, a lot of weight. I now tip the scales somewhat above 500 lbs. Yeah I know. So it's lose it or lose it for me. I'm working on controllers that translate body motion into control signals. for the purpose of creating music with body language.
Succinctly put: The Les Hall Show is back!
This new 2017 edition will begin with a rambling series of recordings aimed at introducing exercise using Pure data (Pd). At Howard's recommendation I'm getting into Pd. The mosc is wise, and I obey!
So we begin with some disorganized audio soon to get better. Here goes...
Les
Inventor
Audio files: 267
PostPosted: Tue Dec 27, 2016 12:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is one of the recent recordings made yesterday. I'm not going to post them all, as that would be laborious downloading. I might put them somewhere though for public availability. Anyone know how to auto-post long segments of audio?
Les
Nicecast Archived Audio 20161226 1819.mp3
 Filename:  Nicecast Archived Audio 20161226 1819.mp3
 Filesize:  965.31 KB
 Downloaded:  524 Time(s)
Inventor
Audio files: 267
PostPosted: Tue Jan 03, 2017 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
This show was recorded with my friend Ixmal Supermarine of London, England. We talked about Shure microphones and I felt nervous the whole time for some reason. Ixmal knows more about microphones than I thought, and I know very little... Was a good show!
Les
The Les Hall Show 20170103 0454.mp3
All about Shure Microphones with Ixmal Supermarine
 Filename:  The Les Hall Show 20170103 0454.mp3
 Filesize:  32.58 MB
 Downloaded:  528 Time(s)
Inventor
Audio files: 267
PostPosted: Tue Jan 03, 2017 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh yes, I did decide what mic to get for me: The Shure MV5,
Les
https://www.amazon.com/Shure-Digital-Condenser-Microphone-Lightning/dp/B010W6W9EQ/ref=sr_1_1?s=musical-instruments&ie=UTF8&qid=1483408436&sr=1-1&keywords=mv5+mic
