Easy analog synth project
Page 1 of 1 [17 Posts]
Cfish
PostPosted: Sat Mar 19, 2016 9:54 am    Post subject: Easy analog synth project
Subject description: Mono synth project
Wanted to show a little project I put together.
Is a 16 note analog synth, using Ken Stones schematic using a 74c922 IC to matrix the keys
The EFM VCO1c schematic
And the single transistor VCA I have seen a few places on this sight.
Nothing fancy. But a great first synth project.
Will try to throw in a link to a YouTube video on the project.
https://youtu.be/N4v_UEWV_Z4
Posted Image, might have been reduced in size. Click Image to view fullscreen.[/img][/url]
(Update) the key lag in the key matrix circuit talked about in this project was drastically improved by decreasing the capacitor values at pins 5 and 6. The data sheet recommends a x10 proportenment with a minimum 100n and 10n. When I tried it at the minimum values with a quick rigged set of momentary switches it worked well, but may require higher values for other switches.
Thanks for everybodies help with that little snag.
Cfish
PostPosted: Sat Mar 19, 2016 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
The UJT in the VCO is available through many vendors on eBay, and I believe Newark has them available too.
I purchased all of my components on eBay.
Audio files: 705
PostPosted: Sun Mar 20, 2016 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
nice project,. sounds pretty good for such a simple circuit, although slightly out of tune in the higher octaves.
But the bass sounds great, might have to make me something like that myself. I think the only part I currently
don't have is the keyboard decoder IC.
Oh and what is the collector of the transistor in the decoder circuit supposed to be attached to, I assume the positive rail ?
Cfish
PostPosted: Mon Mar 21, 2016 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
it tracked a little better once I sat down with a tuner and adjusted the trims.
I would say 3 usable octaves.
Yes the collector of the transistor for the gate ties to the positive rail.
Cfish
PostPosted: Mon Mar 21, 2016 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is un update to what I have done with this project.
Instead of the 74c922 circuit to matrix the keys, I finally got a simple volt per octave key board circuit working.
This got rid of my key lag issue and you can scale it to a larger keybed if you want. I'm using it in a set of bass pedals.
( UPDATE ) I used this in a set of bass pedals and a 2 octave controller all winter long, with no problems. Turns out the radiant heat in my house is very stable at 72 degrees. Spring came and the heat is off. The house got up to 78 degrees and the span drifted substantially.
I ordered some op-amps with better temperature drift ratings to try out.
I have high hopes for the OP177 op-amp. At a glance it appears it may plug right in the IC socket and minimize the drift issue. they are about 3 dollars each at DIGI-KEY
(Another update) the OP177 opamps were a great success.
Build it with what you have, but if you need it instrument perfect these OP177's are awesome.
I had to use the heat gun to get a drift I could register.
L´Andratté
PostPosted: Mon Apr 04, 2016 4:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Cfish! Supernice synth circuit, you compiled there, I think it sounds very good/raw. I actually think I have to check it out myself! Need to get the 2646s first! Banzai says they have them.
Som3where in the video you mention a low pass filter, I didn´t get that (no native English/American speaker), would you explain?
Probably will use push buttons, need to find some playable and durable ones...
Thanks for posting Very Happy
Cfish
PostPosted: Mon Apr 04, 2016 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks L'andratte. The low pass filter I was using was just a 100k poteonometer with a .47 uf capacitor to ground. Was wired like a guitar tone knob.
would love to see some posts here about your take on the project. Good luck with it.
Cfish
PostPosted: Fri Apr 08, 2016 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is what I wound up doing with this project.
Really wasn't what I started out to do. But I'm really happy with it.
 Filesize:  1.14 MB
 Viewed:  507 Time(s)
Cfish
PostPosted: Fri Apr 08, 2016 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is the pt2399 delay circuit I wound up using in it.
Here is a link to the video of the almost finished project.
Sorry the amplifier I was using was crap.
https://youtu.be/h1drX1jdUEE
 Filesize:  1.08 MB
 Viewed:  506 Time(s)
Cfish
PostPosted: Fri Apr 08, 2016 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
To sum it all up
It works great for such an easy project.
It takes a few minutes to warm up the vco, then it stays pretty stable. I did use a matched pair of 2n3906s and bonded them together. Not sure if it helps in this particular situation or not. That's beyond my knowledge level.
I could get about 2 octaves in tune then it fell off quick. The one octave on the bass pedals is perfect on the tuner.
The trimmers on the resistor chain volt per octave key circuit I used in the pedals need to be 10 turn. I started with single turn and got it in tune. But it was a pain, and the gate signal was so touchy to get right. The 10 turns made things a lot easier.
I increased the low pass filter capacitor values more than I ever have in the pt2399 delay circuit, and added another low pass on my input buffer.
I think it's my favorite delay circuit yet. It sounds warm and natural even at long delay times.
Cfish
PostPosted: Mon Apr 11, 2016 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I decided to try this basic idea on a larger scale keyboard using the volt per octave schematic I used in the key pedals.
The span is drifting way to much with small temperature changes.
i ordered a bourns trimmer for the span adjustment. These cheep Chinese ones do seem to drift more with temperature. Fingers crossed
The bass pedals did not have a substantial temperature drift issue, however I was only trying to keep one octave perfect.
 Filesize:  1.45 MB
 Viewed:  494 Time(s)
Cfish
PostPosted: Mon Jan 09, 2017 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have recently came back to this project and am working on a desktop synth using 2 of the VCOs and 2 of the VCAs along with 2 simple transistor envelope generators, and a simple VCF. All passive components.
Should be fun
Here is the board as it looks now. That is actually almost completely populated. So I'm thinking of throwing on a 2 channel ping pong sequencer.
 Filesize:  889.01 KB
 Viewed:  358 Time(s)
PostPosted: Mon Jan 09, 2017 10:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
A ping pong sequencer? Whats that and what donyou do with it? Rolling Eyes
Cfish
PostPosted: Tue Jan 10, 2017 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Grumble
Just something to ping pong between the 2 VCOs.
This is what I came up with.
Am trying to do this as an exercise in (getting what I can from discrete components).
Only using circuits from my memory and trying to give them good purpose.
Might do a sample and hold too.
(Edit) I just noticed something. When I was testing this circuit for values to get acceptable speed range output, I used an LED in series with each 470 ohm resistor. I forgot to make value adjustments when I removed them.
 Filesize:  592.54 KB
 Viewed:  245 Time(s)
Cfish
PostPosted: Tue Jan 10, 2017 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, my memory wasn't so good.
LOL I apparently made the same mistake on both VCOs and can't seem to figure it out.
Have built that VCO schematic more than 10 times and never had it fail to work.
It should be obvious, however it's iluding me.
When I find it I'm gonna feel stupid!!!
Cfish
PostPosted: Tue Jan 10, 2017 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Found it.
And yup, stupid. Flipped B1 and B2 on the UJTs. I kept checking that, and inverting it when I flipped the board back and forth.
Cfish
PostPosted: Sun Feb 05, 2017 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
A little on the project using this concept.
All on one board, 2 VCOs 2 VCAs plus 2 Descrete EGs I posted in another place here.
Look at that board, a child could do it.
 Filesize:  1.17 MB
 Viewed:  243 Time(s)
 Filesize:  1.17 MB
 Viewed:  249 Time(s)
 Filesize:  1.17 MB
 Viewed:  214 Time(s)
