I guess it is a Ringmodulator
Page 1 of 1 [18 Posts]
gabbagabi
PostPosted: Sun Jan 29, 2017 4:11 am    Post subject: I guess it is a Ringmodulator Reply with quote  Mark this post and the followings unread
Hi Guys,
i need your knowlegde about Ringmodulators, cos i have developed something but i need confirmation if iam on the right track.
As far as i know RM´s are four quadrant multipliers, so they can handle on both inputs positive and negative signals,
which is the main difference to "normal" VCA which normaly can not handle negative signals on the CV input.
First i needed a visual reference, so i did a excel calculation with two sinewaves (F * 9F) multiplied by each other.
Then i simulated my idea (with 1khz and 9 khz )and the visual results are matching well.
So i guess it looks not bad, but i want u to tell me if the results can be interpreted as Ringmodulation.
thanks in advance!
 Filesize:  190.31 KB
 Viewed:  746 Time(s)
Audio files: 278
PostPosted: Sun Jan 29, 2017 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes ring modulation is four quadrant multiplication.
The output of your simulation looks like it does that (except for the glitches that seem to happen when both signals are zero).
gabbagabi
PostPosted: Tue Jan 31, 2017 1:28 am    Post subject: Reply with quote  Mark this post and the followings unread
good, now it seems that the circuit worth further investigation,
thx Blue Hell,
cheers bb
gabbagabi
PostPosted: Sun Aug 13, 2017 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
my latest approach to the ringmod quest
please proof me wrong , it looks to simple
cheers
gabbagabi
 Filesize:  70.85 KB
 Viewed:  779 Time(s)
Audio files: 278
PostPosted: Sun Aug 13, 2017 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
To me that looks like a balanced modulator alright - which is yet another name for the same thing.
See the 1496 internals - for instance.
gabbagabi
PostPosted: Mon Aug 28, 2017 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
my posted schemo above is only looking nice and works fine in the simulation, may if u match the tranis u get better results in reality.
my new attemp sounds much nicer, i used the single Transistor VCA i posted here, i happent that there was a deafzone, i had to add an offset to get rid of her. but when i see offset-cancelation - i see atomaticly a modulation opportunity, so i added a deafzone modulation pot.
i did not included input attentuators in the schemo nor on breadboard
soundsample1: bell-like sound where i crank the deafzone-pot from min to max, no EFX used
soundsample2: small bellsound with just a tiny amount of reverb and delay
cheers, bb
 Filesize:  96.63 KB
 Viewed:  811 Time(s)
Ringmod_test.mp3
 Filename:  Ringmod_test.mp3
 Filesize:  328.57 KB
 Downloaded:  958 Time(s)
some small bell tones.mp3
 Filename:  some small bell tones.mp3
 Filesize:  2.1 MB
 Downloaded:  1009 Time(s)
gabbagabi
PostPosted: Mon Aug 28, 2017 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
alanwilder has asked me what a vca has to do with a rinmod. I thought i will post an explanation of the circuit here, cos for me it was hard to find a good one when i was going to be interrested in ringmods.
Ringmodulation is also called 4quadrant multiplikation, so far so good.
A normal VCA does 2 Quadrant multipikation. Means if there is a CV and a signal present to output swings up and down, the cv paints the shape. BUT the cv is only positive. If apply a negative cv to the vca it will be mute to output. see pic1
If we put a second vca that can react on negative CV (eg by inverting the cv) AND mix those 2 signals together we have a maschine that makes , i guess, 2 Quadrant Multiplikation. that means the output will swing up and down, even there where before silence, like a copy of the active part pasted into the muted part. see pic2
now the only thing we have to do for have ringmodulation is to invert the phase of the second part we hav created, which can be easily done by an inverter. see pic 3. between the shape in pic2 and 3 is only a little difference when the cv is going thru zero and a important that in the "second" part the phase is shifted - like the wave is going backwards.
pic 4 shows the concept in blocks
any corrections and additions welcome.
 Filesize:  16.34 KB
 Viewed:  17058 Time(s)
 Filesize:  6.59 KB
 Viewed:  623 Time(s)
 Filesize:  7.73 KB
 Viewed:  674 Time(s)
 Filesize:  7.5 KB
 Viewed:  630 Time(s)
gabbagabi
PostPosted: Mon Aug 28, 2017 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
MO SOUND!
ALARM.mp3
 Filename:  ALARM.mp3
 Filesize:  1.48 MB
 Downloaded:  973 Time(s)
Audio files: 213
PostPosted: Mon Aug 28, 2017 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I verified your ringmod with 2 vcas t and it is indeed a balanced modulator. I have never seen this configuration before. Congrats. Something new, to me at least. Very Happy
Now if you can come up with a linear frequency shifter without a phase shift network you would be my hero.
A frequency shifter just gives the sum and difference frequencies separately, whereas the balanced modulator gives both together. Every analog circuit I have seen uses 90 degree phase shift networks, and digital implementations use a complicated Hilbert transform. (Don't try too hard because this may not be possible). Twisted Evil
gabbagabi
PostPosted: Tue Aug 29, 2017 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you.
A new thing to think about constantly comes in the very right moment.
I will deliver this frequenzy shifting mobile, or die wihle trying Smile
You already explaint it , but i could not get it.
Do you have a prefered source where i can learn what it is, best works for me is a optical reference - input waveform - output waveform.
Or what is the most "simple" one u know?
cheers, bb
gabbagabi
PostPosted: Tue Oct 03, 2017 5:21 am    Post subject: Reply with quote  Mark this post and the followings unread
hi guys,
i dont know what went wrong in my post below from Mon Aug 28, 2017
i have played around on the breadboard with the same circuit again, but gave it a little bit more time and found out that it works not bad.
while playing it came to my mind that the signal attentuator which i normally put in front of the signal-in is kind of useless because with the cv attentuator and the offset u can archieve the same results, so i left it out and have more space on the PCB later. Iam not entirely shure here - any thoughts?
the RM/VCA goes above unity gain and i added a distortion option
the spikes on the top end of the saw in the example scope are coming from the vco and not from the RM
 Filesize:  128.51 KB
 Viewed:  607 Time(s)
 Filesize:  118.44 KB
 Viewed:  522 Time(s)
Audio files: 213
PostPosted: Sat Oct 14, 2017 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent work. BTW, function is misspelled on your schematic.
gabbagabi
PostPosted: Sat Nov 18, 2017 5:06 am    Post subject: Reply with quote  Mark this post and the followings unread
thx!
find attached a simplyfied-Version-Simulation.
ps: the k in function is to show what is in my opinion misspelled in english Smile
I am still thinking about that frequency-shifting-thing - but it is a hard nut - thx for the challenge.
 Filesize:  103.99 KB
 Viewed:  430 Time(s)
gabbagabi
PostPosted: Wed Mar 07, 2018 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
another RM
after gasboss broad this VCA back in my field of view
http://electro-music.com/forum/topic-33190-75.html
 Filesize:  103.38 KB
 Viewed:  420 Time(s)
 Filesize:  2.61 MB
 Viewed:  370 Time(s)
gabbagabi
PostPosted: Fri Oct 26, 2018 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
with the help of MapacheRaper i finally understood the JHaible Ringmodulator
http://electro-music.com/forum/posting.php
 Filesize:  136.8 KB
 Viewed:  286 Time(s)
gabbagabi
PostPosted: Sat Oct 27, 2018 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
i guess i posted it already somewhere else, but ....
one very simple Ringmod, a switching one, which will give u of course a diiferent sound as a classical one Smile
and two mods for this, a ringmod with PWM Shocked and a double-switch to swop the inputs
this could also be used as a VCA for rectangular waves
 Filesize:  68.78 KB
 Viewed:  286 Time(s)
 Filesize:  89.19 KB
 Viewed:  266 Time(s)
 Filesize:  71.85 KB
 Viewed:  270 Time(s)
gabbagabi
PostPosted: Sat Oct 27, 2018 3:30 am    Post subject: Reply with quote  Mark this post and the followings unread
and again something about: "how i can use VCA as RM"
single VCA:
u could rectify the CV/carrier and always when the carrier is negative u turn the phase of the vca-output
double VCA: same idea as some post above but maybe better to read
 Filesize:  49.6 KB
 Viewed:  273 Time(s)
 Filesize:  36.71 KB
 Viewed:  251 Time(s)
MapacheRaper
PostPosted: Sat Oct 27, 2018 6:15 am    Post subject: Reply with quote  Mark this post and the followings unread
So, now that you understand it, maybe you can explain it to us? Laughing
Edit: Ok, I see you have done it... The synchronicities are strong in this one....
