BOSS DR-110 mods
Page 2 of 2 [47 Posts]
Goto page: Previous 1, 2
am4d
PostPosted: Thu Nov 08, 2012 11:15 am    Post subject: DR-110 Reply with quote  Mark this post and the followings unread
Hey guys
I'm going to mod this 110 I've picked up and was hoping for a little advice.
Would anyone recommend using any particular apms for the individual outs or are they loud enough as it is?
Regarding the trigger inputs; Is it plausible to do this using an arduino? Only because I have one laying about. (Never used PIC before either)
I don't think you can get negative voltage from an arduino, but maybe the arduino and 4049 can achieve this? I'm thinking the arduino might not need the 4050? (What does the 4050 do?)
Failing that i'll take the PIC route, but i'm not sure where to begin with that...
I was thinking out mounting it all with *tonal* mods in a little hammond case for triggering with modular ect.
Sorry for all the vague questions
Any advice you guys can give would be swell Wink
creekree
PostPosted: Sat Nov 10, 2012 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
what do you want to use the arduino for?
adding trigger inputs to the dr110 is trivial - look at the schematics and identify the trigger input lines on the ribbon cable that connects the two boards.
to use a trigger signal with those inputs, you will need to convert it from v-trig to s-trig (which means, a simple short to ground).
use the "moog trigger converter circuit" to do that.
http://www.cyborgs.de/synthesizer/faq/V-S-Trigger.JPG
THeff
Audio files: 32
PostPosted: Sat Dec 15, 2012 7:46 pm    Post subject: Perfboard Dr-110 Voices Reply with quote  Mark this post and the followings unread
This is my second post today. The first was about the Hammond B3 Propeller, and this one is about another project I have been working on the last few weeks. I have never owned a DR-110 or played with one, so I decided to try and perfboard all of the DR-110 voices and see what they sounded like. Here is a little demo of the perfboard. I mentioned the Propeller B3 post because I am using the same MIDI file here but this time all of the instruments in the MP3 demo are from a Yamaha MU-50 except the drums. All of the drums are from the DIY DR-110 board. I used BC550 and BC560 transistors throughout except for the snare drum, that was a 2SC945 with a very high HFE.
The row of eight transistors in the top middle of the board are inverters and signal conditioners for the triggers. The blue DIP resistor array are the eight input triggers. I am going to add a small 8 pin PIC microcontroller to provide the the four sequential triggers needed for the clap voice.
Regards,
Theff
 Filesize:  132.32 KB
 Viewed:  939 Time(s)
Green Eyed Lady - DIY DR-110 Drums.mp3
 Filename:  Green Eyed Lady - DIY DR-110 Drums.mp3
 Filesize:  5.29 MB
 Downloaded:  1120 Time(s)
Dan Lavin
Audio files: 21
PostPosted: Tue Dec 18, 2012 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Theff:
That is some crazy amount of perfboarding! I thought of doing this in the past but knowing the number of connections made me sober up! Wink I ended up buying a less-than-perfect DR110 for a reasonable price and completing it that way. Feel free to use my PicAxe program to do the hand clap triggers. Nice job!
Synth DIY since 1977!
THeff
Audio files: 32
PostPosted: Tue Dec 18, 2012 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Dan,
Thanks, I started out just wanting to see what the cymbals sounded like and then couldn't stop building. I built each voice one at a time and tested them as I went along. Thanks for the PicAxe suggestion!
Regards,
Theff
richardc64
Audio files: 26
PostPosted: Wed Dec 19, 2012 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Dan Lavin wrote:
Theff:
It's hardcore Sounds authentic, too!
Revenge is a dish best served with a fork... in the eye
THeff
Audio files: 32
PostPosted: Wed Dec 19, 2012 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks richardc64!
I was surprised how good the OH, CH, and Cymbals sounded compared to most of the white noise/multi-oscillator circuits that I played with before. That's what kept me building the additional voices. Boss really did their homework when they designed the filters and VCA envelopes for the DR-110. Simple but very effective.
Theff
PostPosted: Tue Jan 08, 2013 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I love this song. It is a classic from the early '70s and it shows off your drums quite nicely.
Steve
PostPosted: Wed Jan 09, 2013 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
A beautiful,
Awe inspiring,
and, given my current, chaotic, construction circumstances,....
slightly frustrating build.
Paradigm X
PostPosted: Wed Jan 09, 2013 5:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah brilliant job THeff, awesome.
I saw your perfboarded klee too, crazy.
creekree
PostPosted: Wed Jan 09, 2013 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Holy sh.. THeff!
That is some lovely breadboarding!
Would you mind sharing the PIC code? I totally forgot about those four essential clap triggers. I modded mine years ago - and it has been on constant loan to a friend in Belgium BUT I he is coming over next month, and he will bring it back!
I think I will work on it some more then.
THeff
Audio files: 32
PostPosted: Thu Jan 10, 2013 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Guys!
I have only done a very quick and dirty version of the PIC code using a 12F675. I am going to clean it up soon and will certainly post it here when it's done.
Regards,
Theff
maxdemian
PostPosted: Sun Jun 16, 2013 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
As I am modding my DR110 at the moment I just want to add one thing that is maybe quite obviuos but I did not find any Information about it:
If you are like me not up for making a PXACE controlled Clap trigger thing,
but want the clap to be triggered externaly just go straight to the buttons on the digital board.
I first tried to cross the points with some transistor, but somehow this was behaving very very sensetiv and did not work for me.
So what I am using now is this optocoupler: http://www.alldatasheet.com/datasheet-pdf/pdf/88206/HP/HCPL-817.html
I also thought of using the 4016 or 4066 but I just found these optocouplers lying around, so i am using them now, works perfectly with my highly liquid md24.
Also on the clap! Smile
richy_rich
PostPosted: Fri Apr 11, 2014 12:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I've had a broken one of these kicking about for decades (seems like), I recently found this forum/thread and decided to do something with it.
This is what I ended up with Smile The logic board on mine was scrap and the power supply was b0rked (guessing someone plugged it into something they shouldn't?) I powered it up on the bench and could trigger the individual sounds using the tempo clock signal, so I figured I could salvage something out of it.
I applied most of the mods in this thread, so nothing new to report really and added individual trigger ins for each sound (and accent). I haven't got round to triggering the clap properly but probably will do at some point (enough other stuff to work on at the moment).
I put it in an old first aid box because that was the first thing I found that was roughly the right size...
Just waiting for some knobs to finish Smile
p.s. by the way hi everyone, I've been messing about with electronics and synths for as long as I can remember. I should be better at it - I got a degree in electronics in the early '90s but spent most of the time playing with synths instead Twisted Evil
 Filesize:  81.58 KB
 Viewed:  672 Time(s)
exagonal
PostPosted: Mon Oct 13, 2014 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello everyone!
I am interested in this project, and more than anything else in the program for the trigger of the CLAP.
I do not have a PICAXE but for example, I have several PIC ... you can also program in those?
How can I do since the programmer only reads ASM file?
Thanks so much!
cs1729
PostPosted: Fri Jan 23, 2015 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just got a dr-110. Probably going to do some mods since they seem easy, but I have another issue I'm trying to figure out right now.
I can't change my pattern from number 8. It's like the 8 button is being pressed all the time. I also can't access the Shift functions above 5,6,7.
Except, if I press shift+bank I get tap write, shift+start and shift+stop give me the other functions I can't access normally.
Anyone ever see anything like this before?
istel
PostPosted: Mon Feb 16, 2015 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
ahhh what a wonderful little machine, so much power in such a little box!
i did alot of mods on mine now and it is doing really good - tho it seems i somehow have broken the accent, or atleast it doesn't seem to do anything anymore. i still need a pot for the R117, thinkign to try something quite large as in the orig schems it's a 4.7 M.. just don't have anything right now and i already soldered out the resistor.
also wondered about the sn filter - i did the 50k on R80 and when you turn that all the way down it messes with the other voices in a weird glitchy way. interesting, but i can't help but wonder how it affects other parts of the circuitry? all in all it's very much as if everything influences eachother in unexpected ways in this little machine..
anyways thanks for all the descriptions!! here's a little picture of the proto version
[img][/img]
 Filesize:  204.86 KB
 Viewed:  483 Time(s)
tupinamba
PostPosted: Mon Dec 12, 2016 6:41 am    Post subject: DR-110 triggering Reply with quote  Mark this post and the followings unread
Hi!
First of all, congrats to Dan and THeff, what you have achieved is great!
I actually have two DR-110 :
One of them doesn't power up, so the idea would be to get rid of the digital part (probably the faulty one), add triggers for the sounds and make it a rack module, like Dan did.
The other one is working great, so I was thinking of just using optocouplers to trig the original pushbuttons, like maxdemian did.
What do you think of those two ideas?
Also, THeff, would you mind sharing the PIC12F675 hex file? (I don't have PICAXE chips, but I have PICs and a programmer). And is the schematic the same as the one using the PICAXE 18X that Dan made?
Thanks in advance for your help, the DR-110 is such a powerful drum machine and I want to get the most of it!
tupinamba
PostPosted: Sat Dec 24, 2016 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi again!
I ended up using 4066 to add triggers to my fully working DR-110, emulating the pushbutton triggers. It works great!
On the other hand, I'm looking for a solution for my other DR-110 (the one with the dead microprocessor).
This means converting a standard +5v trig signal into the signals that the DR-110 wants.
THeff, could you be more specific about:
1. the inverter and signal conditioner transistors for the triggers?
2. The PIC code for the clap triggers?
Thanks in advance!
tupinamba
PostPosted: Mon Feb 06, 2017 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
UP?
THeff
Audio files: 32
PostPosted: Thu Feb 09, 2017 6:14 am    Post subject: PIC Clap programming code Reply with quote  Mark this post and the followings unread
At the request of tupinamba,
I have posted a current schematic and the HEX file to program the PIC 12F675 to drive the clap triggers in the Boss Dr-110.
Regards,
THeff
 Filesize:  14.23 KB
 Viewed:  382 Time(s)
DR110_Clap_Driver.HEX
 Filename:  DR110_Clap_Driver.HEX
 Filesize:  789 Bytes
 Downloaded:  288 Time(s)
tupinamba
PostPosted: Fri Feb 10, 2017 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Amazing!
Thank you very, very much THeff!
I'll try it ASAP and write here about how it went.
