Ferrite doubt
Page 1 of 1 [7 Posts]
dancelwerk
PostPosted: Fri Feb 17, 2017 12:28 am    Post subject: Ferrite doubt Reply with quote  Mark this post and the followings unread
Hi to all,
I have a doubt about what type of ferrite beads should I buy, in many projects like filters or others you can use ferrite beads instead 10ohms resistors, but ferrite beads are in Henrys, wich is the replace for this resistors of 10 ohms in Henrys?, what ferrite beads should I buy?
is that a good option?
https://www.reichelt.de/Fest-Induktivitaeten-axial/L-XHBCC-10M/3/index.html?ACTION=3&LA=446&ARTICLE=138560&GROUPID=3179&artnr=L-XHBCC+10M&SEARCH=ferrite
Thanks in advance.
Dancelwerk
Audio files: 705
PostPosted: Fri Feb 17, 2017 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Those seem to be inductors with a ferrite core, you just need simple ferrite beads like this:
http://www.newark.com/fair-rite/2773002112/ferrite-bead-axial-leaded-full/dp/29H4226
(I guess they are basically inductors too)
dancelwerk
PostPosted: Fri Feb 17, 2017 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks!!!
Audio files: 705
PostPosted: Fri Feb 17, 2017 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
btw. you can get them fairly cheap at ebay and similar places, here's an example:
http://www.ebay.com/itm/3-5x6x0-8mm-Leaded-Ferrite-Bead-Toroide-Core-Coil-Inductor-Cable-Filter-/361850473603?var=&hash=item543ff80c83:m:meqR4DA1jIBtVb0hOCLKIuQ
JovianPyx
Audio files: 224
PostPosted: Fri Feb 17, 2017 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks PHOBoS, I think this is probably a FAQ.
Time flies like a banana.
corruptio optimi pessima
wackelpeter
Audio files: 10
PostPosted: Fri Feb 17, 2017 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
These are the ones i usually order:
https://www.reichelt.de/Filter/BEAD-8-21/3/index.html?ACTION=3&LA=10030&ARTICLE=105526&GROUPID=3175&artnr=BEAD+8-21
dancelwerk
PostPosted: Tue Feb 21, 2017 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks!!
dankeschön!!
